Linking Error....iButton Test program Robert Adsett's Port
2006-04-05 by ocnek1
Hello all!! Let me first say I'm pretty new at GNUARM so please be somewhat kind... Now to my problem. I was tring to use Robert Adsett's ibutton test port with my WinARM installation. Everything seems to go fine then I get this Linking error. I have no clue how to fix this, so if someone could point it out or point me in the right direction it would be great. I did not make a ibutton library I just included the .c files in my make file. I would like to compile the ibutton port into a librar file but that is another problem :) Thanks, Oc. Linking: test1.elf arm-elf-gcc -mcpu=arm7tdmi -I. -g -DROM_RUN -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=test1.o -std=gnu99 -MD -MP -MF .dep/test1.elf.d test1.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\ownet.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\lpcses.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\owerr.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\ioutil.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\lpclnk.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\owtran.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\crcutil.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\rawmem.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbshaee.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbeprom.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbnv.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbappreg.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbnvcrc.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbscrcrc.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbscrex.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbsha.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbscree.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbscr.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbee77.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbscrx77.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\mbee.o C:\WinARM\arm-elf\include\arch\philips\ibutton\common\pw77.o build/crt0.o --output test1.elf -nostartfiles -Wl,-Map=test1.map,--cref -lm -lc -lnewlib-lpc -lm -Tbuild/LPC210x_ROM.ld c:/winarm/bin/../lib/gcc/arm-elf/4.1.0/../../../../arm-elf/lib\libc.a(makebuf.o): In function `__smakebuf':makebuf.c:(.text+0x110): undefined reference to `isatty' collect2: ld returned 1 exit status make.exe: *** [test1.elf] Error 1
