Lpc2000
LPC2106 flash utility problem
2006-02-27 by Michal Krestan
I need to help with programming LPC2106 via LPC2000 flash utility. I've got board with one LPC2106 connected via UART0 to COM1. P0.14 is pulled low, power supply pins are in limits but I can't sucesfully connect with flash utility. Always I get message "Cannot communicate with test board". X1 and X2 pins are connected to 7.3728MHz resonator. If I measure data between PC and LPC2106 it has some response on flash utility requests, but no success:-( I had several pcs of this hardware working, but this one doesn't work. I've changed LPC2106 with new one but still with the same result.  Does anybody have idea how to fix this problem?
            Michal
Re: [lpc2000] LPC2106 flash utility problem
2006-02-27 by Tom Walsh
Well, you don't have to use any software to connect to the LPC2106.  All
you really need is a terminal program, something like minicom or
hypercom will work.  Just set them to 8 bits no parity and no
handshake.  Then start pressing the "?" key, eventually, the processor
will see the "?" and send you "Synchronized".  When it does that, you
respond with the same thing: "Synchronized".  You are now linked.
TomW
>            Michal
>Yahoo! Groups Links
  To: lpc2000@yahoogroups.com
  Sent: Monday, February 27, 2006 1:10 PM
  Subject: Re: [lpc2000] LPC2106 flash utility problem
  I've tested this you described bellow. I'll get always response "Sychronized", when I'm sending "?" character, but after this, if I'll type my response "Synchronized", I'll get back for each character typed some unknown response in form of several random characters.
          Michal
  TomW
  >            Michal
  >Yahoo! Groups Links
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
        Pic microcontrollers
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-02-27 by Robert Adsett
Use a faster crystal?
The minimum frequency specced for serial ISP programming is 10MHz (Pg 26 of
the LPC2106 data sheet).
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2006-02-27 by Xtian Xultz
Em Seg 27 Fev 2006 09:05, Michal Krestan escreveu:
>             Michal
Maybe isnt the frequency of your crystal?
The datasheet says the LPC2106 must have a crystal from 10 to 25MHz, and maybe
the Flash program expects at minimum a 10MHz crystal to program the UART0 of
the LPC.
I suggest to you to change the crystal to see if it works.
  Sent: Monday, February 27, 2006 2:17 PM
  I've tried to use 11.0592MHz crystal, but with same result:-(
              Michal
  the LPC.
  YAHOO! GROUPS LINKS
2006-02-28 by Robert Adsett
> I've got
> X1 and
> between PC
> doesn't
Well, it had to be checked.  Have you tried connecting with a
terminal?  Scoped the lines?  Marginal transceivers and bad connections
have been reported as causing problems.
> and maybe
> UART0 of
>   the LPC.
Actually the datasheet says the minimum frequency is 1MHz, but 10MHz is
needed for serial ISP. Some sort of limitation on their autobaud routines
maybe?
Robert
2006-02-28 by Xtian Xultz
Em Ter 28 Fev 2006 00:12, Robert Adsett escreveu:
> > I've got
> >   > test board".
> > X1 and
> > between PC
> > doesn't
> > and maybe
> > UART0 of
> >   the LPC.
> maybe?
> Robert
Sorry if this messages dont help, but I am really happy, because the first
board I made (entirelly), solded (by hand, with iron solder) worked just
fine, the ISP worked fine from the first time. Everybody here (in Brasil) is
playing the carnival and I here working, but I am happy too. I used a 10MHz
crystal, and had no problemas with ISP. I used a simple MAX232 powered with
5V and I had no problems.
2006-02-28 by mfrazier@governors-america.com
Are you using a purchased development board or one that you made yourself?
If it's a purchased board, which one is it and who made it?
Mike
Em Ter 28 Fev 2006 11:26, mfrazier@... escreveu:
> Thanks,
> Mike
First I buyed a development board from a brazilian vendor called Elaxys
(www.elaxys.com.br), I am using the EX_LPC_M01 wich is just nice, and cheap
(for brazilian prices, our import taxes are simply abusive and a board
assembled here become much more cheaper). With that board I made a few
firmwares, and the board comes with a CDROM that contains tha gnuarm ready to
use in Linux and Windows (of course, I use Linux), a lot of libraries made by
Elaxys wich is MIT licensed (as seen on
http://www.elaxys.com.br/produtos/lpc/ex-lpc-lib1/ but unfortunatelly only in
portuguese) wich have nice functions, like one to made an routine a ISR (I
cound not find how to do it in gnuarm alone, I can only made an ISR with
these libraries), I buyed an Wiggler JTAG and comes in the CD too a program
to connect GDB to the paralell port (the program is called exmon and can be
downloaded from the Elaxys site).
With that baord I tested the ISP program from Philips, and lpc2isp. Then I
designed my own board, uploaded some firmwares and I am testing right now.
It is now really nice to develop im my board, because I made an ISP header
that have an ON-OFF switch to power the entirelly board, and another switch
that puts P0.14 low. And a DB9 caonnector to connect to the computer serial
port. So, When I power the board with the ISP switch on, I load the firmware.
Then I power off, turn the ISP switch off, turn the board on and the firmware
runs, very nice.
I developed a lot with PIC microcontrollers, using Microchip ICSP but I
allways had to plug and unplug the ISCP connector, the ISP is just great.
Ah! another neat feature, I use UART1 in my system, and I use UART0 as a
debug-out (I send bytes like opcodes to show me what the firmware is doing)
so I use the same serial connection to read these caracters in minicom.
Really nice...
2006-02-28 by Michal Krestan
I'm using my own board. I've replaced LPC2106 with another one from second fully functional board and I had no more problem with booloarer and flash utility. It seems I had two partly damaged devices. I've replaced two LPC2106 without success and after third replacement from fully functional board I had no more problems.
            Michal
  Sent: Tuesday, February 28, 2006 3:26 PM
  Mike
  YAHOO! GROUPS LINKS
