Still trying UART0 Interrupts - almost there
2006-02-28 by f lee
I've spent a lot of time trying to get this UART Interrupt to work. Not enough I suppose. What have I missed?
This is written for the OLIMEX 2148 compiles and runs under GCC and uses the Phillips std LPC214x.h
I hope this will be useful to others who have tried and failed!
Thanks for your help!
Flee
#include "LPC214x.h"
#define OSCILLATOR_CLOCK 60000000
#define OVERRUN_ERROR 0x02
#define RECEIVE_RDY 0x01
#define PLOCK 0x400
#define VIC_VECTCNTL_EN (1 << 5)
#define VIC_CHANNEL_UART0 6
#define CPSR_IRQ_EN_MASK 0x00000080
Function declarations
void Initialize(void);
void feed(void);
void set_interrupts(void);
void initUART0( unsigned int baud );
unsigned char getchUART0( void );
unsigned char putchUART0( unsigned char txChar );
unsigned char getTimedCharUART0( void );
void IRQ_Routine (void) __attribute__ ((interrupt("IRQ")));
void FIQ_Routine (void) __attribute__ ((interrupt("FIQ")));
void SWI_Routine (void) __attribute__ ((interrupt("SWI")));
void UNDEF_Routine (void) __attribute__ ((interrupt("UNDEF")));
void UART0_Handler(void) __attribute__ ((interrupt("IRQ")));
Global Variables
unsigned char hostInterface;
unsigned long baud0;
unsigned long baud1;
unsigned char TxByte0;
unsigned char RxByte0;
volatile char dummy;
unsigned long status;
MAIN
int main (void)
hostInterface = 0xFF;
baud0 = 9600;
TxByte0 = 0x2e; // TxByte for UART 0
int j; // loop counter (stack variable)
// Initialize the system
Initialize(); // Initialize the PLL
U0IER &= 0x0; // disable all Interrupts U0IER : 0xE000C004
VICVectAddr0 = (unsigned long) UART0_Handler; //the address where uart 0 service routine starts
VICVectCntl0 = VIC_VECTCNTL_EN | VIC_CHANNEL_UART0; // (0x20? | 6) uart interrupt
VICIntEnable = (1 << VIC_CHANNEL_UART0); // (1 << 6)
initUART0(baud0); // Init Serial Port1
dummy = U0IIR; // read IrqID - required to get interrupts started
status = VICIRQStatus;
U0IER |= 0x1; // enable RBR Interrupts set bit 0 for UART0 RBR Interrupts
// set io pins for led P0.7
IODIR0|= 0x00000C00; // pin P0.7 is an output, everything else is input after reset
IOSET0= 0x00000C00; // led off
// endless loop to toggle the leds
while (1)
for (j = 0; j < 500000; j++ );
IOPIN0= 0x00000800;
IOPIN0= 0x00000400;
IOPIN0= 0x00000000;
IOPIN0= 0x00000C00;
// write and read UART 0
putchUART0(TxByte0); // lets us know the port is functioning
PLLCFG=0x24; // 60Mhz Setting Multiplier and Divider values
feed();
PLLCON=0x1; // Enabling the PLL
feed();
while(!(PLLSTAT & PLOCK)) ; // Wait for the PLL to lock to set frequency
PLLCON=0x3; // Connect the PLL as the clock source
feed();
// Enabling MAM and setting number of clocks used for Flash memory fetch (4 cclks in this case)
MAMCR=0x2;
MAMTIM=0x4;
VPBDIV=0x1; // Setting peripheral Clock (pclk) to System Clock (cclk)
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
// Divisor has to be redivided if the VPB changes
// Also, MultDiv values to correct for errors are not used
unsigned int divisor = OSCILLATOR_CLOCK / (baud * 16);
//R.M - COMPILES! - had to explicitly include libgcc.a library in makefile
// Sets Baud Rate
// U0LCR Register [bit7][bit6] [bit5] [bit4] [bit3] [bit2] [bit1][bit0]
// DLAB Set Stick Even Par Stop Word Length
// Break Parity Par Sel Enable Bits
U0LCR = 0x83;
// U0CLR = U0CLR | SET_DLAB | SET_PARITY | WORD_LENGTH;
// U0DLL Divisor Latch LSB - 8 bit data
U0DLL = divisor & 0xFF;
// U0DLM Divisor Latch MSB - 8 bit data
// unsigned int divisor = OSCILLATOR_CLOCK / (baud * 16);
// = 60000000 / (9600 * 16) =
U0DLM = (divisor >> 8) & 0xFF;
U0LCR &= 0x7F; // Clear DLAB Bit
U0FCR |= 0x01; // Set the fractional divide
PINSEL0 = (PINSEL0 & ~0xF) | 0x05;
// When U0LSR THRE bit is set, the U0THR is empty and can be written
while ( !(U0LSR & 0x20) );
// DLAB in U0LCR must be clear to access this register, this register
U0THR = txChar;
//when U0LSR's DR bit is 1, the UART RBR register has valid data
//while (U0LSR_bit.DR == 0);
//if(U0LSR & RECEIVE_RDY)
return U0RBR;
//else
// return 0x3A;
/* Stubs for various interrupts (may be replaced later) */
while (1) ;
while (1) ;
while (1) ;
while (1) ;
// we will need to test what the interrupt is.... if we get it working
putchUART0(getchUART0());
/* Acknowledge IRQ */
// now clear the interrupt
VICVectAddr = 0;
Yahoo! Mail
Bring photos to life! New PhotoMail makes sharing a breeze.
