Lpc2000
problems with programs larger than 4K with Keil MCB2140
2006-02-27 by nicolkb1
I am using a Keil MCB2140 with the Evaluation version of the compiler
when my program gets over 4K there is a problem downloading to the
device.  Here is two sample outputs of the out Build Window in the
IDE.  The first one is successful. The next one is 8 bytes larger and
is unsuccessful.
Has anyone seen this before?  The compilier gives a warning about a
16k limit.
Output 1 - successful
Build target 'LPC2100'
assembling Startup.s...
compiling Test.c...
compiling Timer.c...
compiling Sensor.c...
compiling Stepper.c...
compiling Support.c...
compiling prthead.c...
linking...
Program Size: data=1732 const=24 code=4068
".\Obj\Test" - 0 Error(s), 0 Warning(s).
Load "C:\\Keil\\ARM\\Examples\\Test\\Obj\\Test.ELF"
Erase Done.
Programming Done.
Verify OK.
MISSING DEVICE (R003: SECURITY KEY NOT FOUND)
Running in Eval Mode
*** Restricted Version with 16384 Byte Code Size Limit
*** Currently used: 4092 Bytes (24%)
Output 2 - unsuccessful
compiling Test.c...
linking...
Program Size: data=1732 const=24 code=4076
Erase Done.
Programming Done.
Contents missmatch at: 00001000H  (Flash=FFH  Required=1EH) !
Contents missmatch at: 00001002H  (Flash=FFH  Required=2FH) !
Contents missmatch at: 00001003H  (Flash=FFH  Required=E1H) !
Verify Failed!
Re: [lpc2000] problems with programs larger than 4K with Keil MCB2140
2006-02-27 by Sagaert Johan
hi
I guess you should set the programming algorithm to the correct flash size:
in Options for target
    tabsheet utilities
        ulink debugger settings
            -> choose a larger flash size then the one selected.
Hope this helps
Johan
  To: lpc2000@yahoogroups.com
  Sent: Monday, February 27, 2006 5:44 PM
  Subject: [lpc2000] problems with programs larger than 4K with Keil MCB2140
  is unsuccessful.
  16k limit.
  compiling Test.c...
  linking...
  Erase Done.
  Programming Done.
  Verify OK.
  compiling Test.c...
  linking...
  Erase Done.
  Programming Done.
  Verify Failed!
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
        Pic microcontrollers
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-03-01 by Saravanakumar S
Hi ,
        If you are using the Keil Evalution version,then Code limit is
only 16k.
Up to 16k you can you can use the Keil compiler.It is very easy to see
Program ouputs.
When your code size exceeds 16k,then you seperate tyour program as 2
modules.Write your program in seperate module.
Merge both modules in a single program,compile in it in the GCC Compiler
.You will get different compilation files like ELF,Hex,BAk...etc
Then you can download it your target module.
Dont include the startup file in GCC compiler.ok.It will automatically
built own startup file.
Keil compiler has Limitation.MCB2140 has no limitation.Ok Just try this
one................
If you are not satisfied with this point.Send a mail, i will explain
details.
is unsuccessful.
16k limit.
compiling Test.c...
linking...
Erase Done.
Programming Done.
Verify OK.
compiling Test.c...
linking...
Erase Done.
Programming Done.
Verify Failed!
Yahoo! Groups Links
