Lpc2000
Olimex LPC-H2138, need help
2006-03-01 by George_Yeoh
I was trying to upload into flash from Philips Flash Utility software,
and it always complaints that the board coul not be connected.
I have tested the serial port with other harware, it works.
I have try all the baud rate available on the Flash Utility.
I make sure the BSL is on.
But...
I'm using a USB to serial convertor, could it be the problem?  E.g.
low voltage, ...
Re: Olimex LPC-H2138, need help
2006-03-01 by Sutton Mehaffey
I was told by Keil that the Flash Utility wouldn't work with their
2140 and 2130 eval boards with a serial-USB adapter.  I don't know
about the Olimex board.
Sutton - dodge1955
> But...
> low voltage, ...
