Lpc2000
Availabilty of redesigned LPC213X and LPC229X chips
2006-03-02 by alipowsky
Since juli 2005 we ask our Philips FAE and business contacts in
germany for a date, when redesigned chips of the LPC2134/6 and the
LPC2292 will be available.
The bugs around the timer/match/pwm ISR issue and the bugs in the CAN
controller have now turned into blocking points concerning the release
of some of our projects.
Every time we asked, we have got later dates, but not exact
information was given til today.
As we now have to make the decision to switch to another ARM-7
manufacturer.
Before we go this unpleasant and expensive way, we would like to ask,
 whether anybody around here, has some secure informations about the
redesign schedules for the above mentioned cpu's.
Thanks
Andreas
Re: [lpc2000] Availabilty of redesigned LPC213X and LPC229X chips
2006-03-02 by Karl Olsen
---- Original Message ----
To: <lpc2000@yahoogroups.com>
Sent: Thursday, March 02, 2006 7:16 PM
Subject: [lpc2000] Availabilty of redesigned LPC213X and LPC229X chips
> manufacturer.
The LPC213x bugs have been fixed in the LPC214x, which is software
compatible, and pin compatible except for pin 10 and 11.
Karl Olsen
Re: Availabilty of redesigned LPC213X and LPC229X chips
2006-03-03 by unity0724
...Ummm.....also...
Questions of when philips is going to mask rom the 2 silicons:
LPC2114-LPC2294 and LPC213x-LPC214x, and default JTAG to DISABLE.
Though after so many heated arguments on flash protection and
conclusion of the 2 silicons are hack-proof, fortifying the read
protection will enhance users'/public's confidence.
=> At least, with JTAG default as off,  we will not have any more
such discussions here and I think everybody will be happy!! :)
Can philips please help to MaskRom + JtagOff the chips??
Many Thanks and I will switch from LPC2103 back to LPC2124.
CAN
release
> manufacturer.
ask,
> Thanks
> Andreas
2006-03-03 by Vimal Amin
We are also facing funny timer isr behaviour.
I have written TImer ISR to generate one_sec bit and toggle an LED.
In main I dump a message on LCD display, and increment a step_number.
when quantity of this step crosses 20 or so, timer stops working, LED
stops toggling.
We are using keil and LPC2132.
I want to know what is exact problem you are fcing. Is it same as my
problem?
2006-03-03 by Jayasooriah
Yes Philips, please plug the hole(s) that do(es) not exist :)
 > Regards
Send instant messages to your online friends http://au.messenger.yahoo.com
Polling for data reception
2006-03-04 by Manisha
hi all,
i am designing a USB driver code in LPC2148 board. whenever the USB port
receives any data, it generates an interrupt.
However, i want to design my code by polling method, i dont want any extra
running context i.e an extra ISR. but as i found in the manual the bit in
the endpoint interrupt status register only indicates the reception. is
there any other bit or other CSR(Control status register) where i can get
indication for data reception and use that bit for polling?
Thanks for going through the problem.
please help me if anyone has any idea.
Manisha
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s)and may contain confidential or privileged information. If you are not the intended recipient, please notify the sender or administrator@...
Re: [lpc2000] Polling for data reception
2006-03-04 by Richard Duits
You can always use the VICRawIntr register to poll the status of any
interrupt, even those that are not enabled.
Richard.
Manisha wrote:
> hi all,
> Regards
> Manisha
> administrator@...
RE: [lpc2000] Polling for data reception
Hi Richard,
thanks a lot for the reply.
i was going through this VICRawIntr register. but, somehow i got confused
about the bits. the 22nd bit is for USB, but, for which interrupt, is it
specific for data in endpointOUT or it can be any inetrrupt. i could not
find any specific about this. it will be helpful for me if you share
something more about this.
again thanks a lot.
regards
Manisha Kalita
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of Richard Duits
Sent: Saturday, March 04, 2006 2:24 PM
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] Polling for data reception
Richard.
Manisha wrote:
> hi all,
> Regards
> Manisha
> administrator@...
Yahoo! Groups Links
2006-03-04 by Bertrik Sikken
Manisha wrote:
> hi all,
You can have a look at my open-source USB stack for the LPC214x
(see http://sourceforge.net/projects/lpcusb )
This code currently also uses the interrupt bit polling method.
The USB interrupt is not connected to the VIC and only the USBDevIntSt
register is polled.
In case the DEV_STAT interrupt bit is set, the code issues a Get Device
Status command to get the device event (reset, connect, suspend).
In case the EP_SLOW interrupt bit is set, the code can find out
exactly which endpoint(s) caused the interrupt by reading USBEpIntSt.
Each logical endpoint consists of two physical endpoints (for IN and
OUT), and each physical endpoint has a bit in the USBEpIntSt register.
Bertrik
I don't know anything about the USB controller, because I never used an
LPC214x. All I know that you can poll if an interrupt routine would be
called if you enabled the interrupt, by reading the VICRawIntr register.
Richard.
Manisha wrote:
> Hi Richard,
> again thanks a lot.
> regards
> Manisha Kalita
> Of Richard Duits
> Regards,
> Richard.
> Manisha wrote:
> > hi all,
> extra
> bit in
> can get
> > Regards
> > Manisha
Thanks Richard
actually i wanted to avoid any Interrupt routine.
anyway, i think i can use other interrupt status register bits also without
enabling them.
regards
Manisha.
Of Richard Duits
Sent: Saturday, March 04, 2006 5:42 PM
Richard.
Manisha wrote:
> Hi Richard,
> again thanks a lot.
> regards
> Manisha Kalita
> Of Richard Duits
> Regards,
> Richard.
> Manisha wrote:
> > hi all,
> extra
> bit in
> can get
> > Regards
> > Manisha
Yahoo! Groups Links
[lpc2000] indication for complete data transmission to USB host
Hi all,
Thanks for helping me in solving the issue regarding polling for reception
of data.
now, i am stuck in an other problem. i want an indication whenever my USB
data gets transmitted succesfully to the host. in Atmel they provide one
TXCOMP bit which is set whenever the USB host receives any data and
acknowledges for the same. however, in lpc i have only TxENDPKT bit which
indicates only transfer of data to the endpoint FIFO. i want indication for
complete transfer.
can anyone help me in this regard?
regrads
Manisha
RE: [lpc2000] indication for complete data transmission to USB host
i think the problem i stated lately can be solved by checking USB Endpoint
Interrupt Status register (0xE009 0030).
any suggestion from your side will be helpful for me.
regards
Manisha.
Of Manisha
Sent: Saturday, March 04, 2006 5:53 PM
Subject: [lpc2000] indication for complete data transmission to USB host
Hi all,
of data.
complete transfer.
regrads
Manisha
Yahoo! Groups Links
