> From: lpc2000@yahoogroups.com
> [mailto:lpc2000@yahoogroups.com]On Behalf
> Of Sutton Mehaffey
> Sent: Sunday, March 05, 2006 4:24 PM
> To: lpc2000@yahoogroups.com
> Subject: [lpc2000] Re: ADC input leakage current
> Tom,
> I expect to put a tantalum cap of perhaps 1uf or so on the voltage
> divider junction and sample very infrequently, perhaps once per
> second. Perhaps it is "no worries" about what the analog input leakage
> current is in such circumstances. If it is 4ua then the offset on a
> 100k source Z would be only about 40mv and reflected up the divider
> for a 15 volt max reading would equal a measurement error of about
> 200mv which is NOT inclusive of resistor tolerance errors. However,
> if the leakage were actually specified and I knew the polarity of the
> analog input leakage current (and it did not change direction under
> any circumstances) I would be able to design for a typical setting
> with knowledge of the worst case parameters.
> Without such information, It is a "shot in the dark" as to what the
> unit-to-unit error spread in production will be. I do not like to use
> pots or select-at-test resistors. I would much rather have a fully
> characterized part.
> As to the option of a unity gain amp in front of the input.. Added
> cost, plus the added power drain make that option unattractive unless
> I cannot get it to work otherwise.
> Sutton
> --- In lpc2000@yahoogroups.com, Tom Walsh <tom@...> wrote:
> > Sutton Mehaffey wrote:
> > >Does anyone (or Philips Techs) know the max input current
> leakage of
> > >the ADC channel input pins?
> > >The LPC2148 datasheet says that the input leakage current
> is max 4uA,
> > >but I am thinking that this MAY apply just to the digital
> signal pins.
> > >We are trying to use one of the ADC channels in conjunction with a
> > >very accurate voltage divider for determining battery voltage for a
> > >battery powered application.
> > >We need the actual SPECIFICATION max of the input leakage current
> > >(and the polarity if it can be depended upon) so as to be able to
> > >calculate a worst case error.
> > Just some observations from the peanut gallery, FWIW. I, too, have
> > noticed, what appears to be, a definate avoidance of giving
> complete
> > spec's regarding pin loading / source / sink current for
> the LPC2000
> > processors. I generally see DC specs which contain a lot
> more detail
> > than that of the LPC2000s. IMHO, this is deliberate?
> > If they are using an approximation technique for measuring
> the voltage,
> > you may not have a consistant load presented by the ADC input.
> Assuming
> > that they are using a fixed resistance ladder with FET
> switches gating
> > the samples within the ladder may not be the case.
> Therefore, the act
> > of performing a conversion may present you with a varying load?
> > I mean, if you are *that* sensitive to changes in load,
> then why not
> > eliminate them (Philips) from the unknowns and use a unity gain
> buffer?
> > Place a simple op amp buffer between your voltage divider
> and the input
> > to the ADC. Something with a FET input. Done. BUT, you still have
> the
> > Common Mode spec of the op amp to contend with...
> > Otherwise, you may have to lower the "source" resistance
> (increase the
> > current through the divider) such that it is 10..20 times
> the max load
> > presented by the ADC input? Look at it this way, if the voltage
> divider
> > is drawing 1ma and the input to the ADC is @ 0.004ma
> (source vs load
> > ratio of 250), how much shift in the voltage would you see
> if the ADC
> > input varied by 4ua (connect / disconnect)? Having a load
> 1/250th of
> > the source is pretty darn negligable! Kirchoff's Law...
> > If you are *that* sensitive to the 4ua load, perhaps your
> units would
> > need to be individually calibrated to match the processor's
> ADC input
> > load, op amp common mode, etc.. With the degree of accuracy you
> > suggest, this is probably the case in any event.
> > Regards,
> > TomW
> > Tom Walsh - WN3L - Embedded Systems Consultant
> > http://openhardware.net, http://cyberiansoftware.com
> > "Windows? No thanks, I have work to do..."
