ebarker123 wrote:
>Thanks for you excellent reply. Is this for the GNU compiler ?
>I failed to mention that I'm using the Keil compiler.
>I've determined that the following directives do the trick.
>#pragma NOINIT
>char states[100]; /* Uninitialized Variable */
>#pragma INIT
>char array[100]; /* Initialized Variable */
Well, that would work with Kiel, I guess. I don't use a Keil dev
system, my system is GNU compiled from source. YMMV.
TomW
>Ed
>--- In lpc2000@yahoogroups.com, Tom Walsh <tom@...> wrote:
>>ebarker123 wrote:
>>>Here is the scenario.
>>>I have an MCB2138 eval board. I have a menu talking on a serial port.
>>>Using the menu, I can set and print a variable called 'mytemp'.
>>>I set the value to say, 456, and print that out.
>>>I press reset and the value is changed to 0.
>>>Where/How is this variable getting changed. My application requires
>>>that we be able to press reset, and the SRAM contents not change.
>>Look in your crt0.s file, bss sections are zeroed there. 'bss' data is
>>data which you declared globally and did not provide a value for.
>*ALL*
>>C code systems initialize the bss data section, all, this is a
>>requirement of the C language.
>>If you want to create memory which is part of the code but is not
>>initialized, add a section attribute to it and then place the section
>>into the linker ld script. For example:
>>char myString [8] __attribute__((section ("noinit")));
>>in the linker script, place a new section AFTER the bss. You want to
>>avoid placing this in front of "__bss_end__ = . ;"!
>>================= begin LPC2106ROM.ld ===============
>> /* .bss section which is used for uninitialized data */
>> .bss (NOLOAD) :
>> __bss_start = . ;
>> __bss_start__ = . ;
>> *(.bss)
>> *(COMMON)
>> . = ALIGN(4);
>> } > RAM
>> . = ALIGN(4);
>> __bss_end__ = . ;
>> PROVIDE (__bss_end = .);
>> .myvars (NOLOAD) :
>> *(noinit)
>> } > RAM
>> .stack ALIGN(256) :
>> . += STACK_SIZE;
>> PROVIDE (_stack = .);
>> } > RAM
>> _end = . ;
>> PROVIDE (end = .);
>>================== snip ====================
>>Note the new region called ".myvars" in the script? That is where I
>>will put the "noinit" section.
>>To make sure that all is well, look at the symbol file produced by the
>>linker. In my case it is main2106.sym, in it I look at the memory
>>location of '__bss_end__' and 'myString'. Here is a snippet of my
>>symbols file:
>>============= begin main2106.sym ===============
>>400092e2 B serial1ParityMode
>>400092e4 B tx1Buffer
>>40009ae8 B Words
>>40009dec B WordCnt
>>40009df0 A __bss_end__
>>40009df0 B myString
>>4000ae00 A end
>>4000ae00 A _end
>>4000ae00 B _stack
>>================= snip =====================
>>Actually, that is the very end of the symbol file. The variable
>>myString is placed at the end of the RAM. Adding more data to this
>new
>>section is quite easy now, simply assign the same attribute to each:
>>struct BIG_DATA abort_info __attribute__((section ("noinit")));
>>int timeAborted __attribute__((section ("noinit")));
>>Hope this helps,
>>TomW
>>Tom Walsh - WN3L - Embedded Systems Consultant
>>http://openhardware.net, http://cyberiansoftware.com
>>"Windows? No thanks, I have work to do..."
>Yahoo! Groups Links
