Lpc2000
real time clock
real time clock
2006-03-07 by ebarker123
I'm using the lpc2138:
Q. How do you read the clock registers without risk of 'rollover'?
For example, I know of clocks that have a dual-port ram between the
actual internal clock registers and the registers that appear in the
address space. You can disable/enable updating the dual-port ram,
thereby allowing the muliple clock registers to be read without risk
of 'rollover'.
As best as I can determine, there are bits that will start/stop the
lpc2138 clock. Are these really bits that enable/disable a dual port
ram, or does it really stop the clock?
It it really stops the clock then that is unfortunate.
A workaround is to run a sub-second timer routine that reads the
second counter, waiting for it to increment, then you can read the
rest of the consolidated registers without fear of rollover.
ebarker123
Re: real time clock
2006-03-07 by unity0724
Umm...  Why not just setup the second tick interrupt from RTC??
Store/Update Time/Date value every second to somewhere.
Background task (Non-ISR code) remembers to disable interrupt
when reading the Time/Date data structure..    Help??  :)
> ebarker123
Re: real time clock
That would certainly solve the problem. What I'm really interested in
knowing (so that probably makes this a Phillips question) is whether
or not the enable is opens and closes a dual-port ram, or does it
realy stop the clock.
Ed
> > ebarker123
