I2C help for LPC2148
2006-03-07 by Sutton Mehaffey
Just learning to play with I2C. I am trying to address a RAMTRON Serial RAM chip and am having some difficulty getting proper responses from it. I have the chip addressed as 000, to make it easy on the electrical hookups. My first trial is to READ data from a particular (selective) memory location. By reading, and if I understand it correctly, I need to do the following: 1. Issue a START command 2. Read the I2C0STAT register to determine the code. 3. An 0x08 means that START command was sent. 4. If 0x08 is received, issue a command thru I2C0DAT that contains the chip select ID and the Device address. Mine is 1010000x, where 'x' is read (1) or write (0). In this case A0. 5. Clear SI bit. 6. Read the I2C0STAT register to determine the code. 7. Should be either 0x18, 0x20, or 0x38 according to the manual. Here's the result: After issuing a START command, I do get a 0x08 in the I2C0STAT register (indicating START sent). Then, I put the chip address in the I2C0DAT register (0x40) which includes the Write bit in Bit 0. I, then, clear the SI bit. But, I still get an 0x08 in the I2C0STAT register. I can never get anything else. I tried clearing the SI bit before putting the address on the bus, but still I get an 0x08. Any ideas what I am doing wrong in the sequence? Thanks. Sutton
