Lpc2000
I2C code for LPC2148
2006-03-06 by Sutton Mehaffey
I am trying to use a RAMTRON Serial Memory chip using I2C.  I have
grounded the Address lines for a 000 address as well as the WP (write
protect line).  Does someone have a small I2C sample code showing how
to manipulate the SDA and SCL lines properly and feed the data?  Does
the I2C code have to use an interrupt?  If no, is it preferable?  Just
looking for options and a few hints as I experiment with I2C for the
first time.  Thanks.
Sutton
RE: [lpc2000] I2C code for LPC2148
2006-03-06 by Bruce Paterson
> have grounded the Address lines for a 000 address as well as
> the WP (write protect line).  Does someone have a small I2C
> sample code showing how to manipulate the SDA and SCL lines
> properly and feed the data?  Does the I2C code have to use an
> interrupt?  If no, is it preferable?  Just looking for
> first time.  Thanks.
From memory the Ramtron's are identical communications to s serial
Eeprom (just faster). I have used the I2C on an 8051 to talk to a
Ramtron and it's pretty standard stuff. You might be able to find
something already around on the web.
Bruce
Re: I2C code for LPC2148
2006-03-07 by philips_apps
Just
> first time.  Thanks.
> Sutton
Sutton,
    There are many examples in the "Files" area, check the one
uploaded by Philips Apps.
2006-03-08 by ashishbhopale1
hi bruce,
   there is a document from philips for a 8051 microcontroller which
explains all about the interface philips provides for its I2C
controller.u can refer to it as i have done my work refering to the
same document.search for the document 8XC552_562OVERVIEW_2.it has all
the info .
 >>ashish
Re: [lpc2000] Re: I2C code for LPC2148
2006-03-08 by Sushil Rana
Dear All,
I am starting with ARM , please guide me what to do in the begining, i am
having experience in microcontrollers 8 and 16 bits.
waiting for urs response
Sushil
