Lpc2000
Problems on first board
2006-03-10 by Thiago Takehara
I´m burning a blinky program on LPC2144 and can´t make it work, even if I can burn it on internal flash. I´ve succesfully tried this code on MCB2140, so I thought it would work on my board.
I have made a simple board with LPC2144, 10MHz xtal, MAX232, reset source and a good voltage source. I´ve verified all the VDD's, VSS's and verified my EINT1's, TRACESYNC's and others pull -up and -downs. My reset source maintains low level on reset pin for at least 280ms.
I don't know how to compare my burned code and the original one on my PC, because this function on LPC2000 Flash Utility V2.2.3 doesn't work, so I've uploaded and downloaded again the same code on my board and on MCB2140 and compared both with WinHex, and both was identical. I gave a look on the Interrupt Vector's checksum and confirmed it is ok.
It's the first time I burn a code on this new board, and I don't know if I have to do anything different at first burn, something like writing a word for a specific register / memory position, and haven't find any information regarding this issue on Philips' UM10139.
Why can´t my code run if I can burn it on flash? If someone knows anything that can help me, my thanks in advance.
Regards.
Thiago Takehara
Computer Engineer
Engworks Industrial LTDA - R&D Division
Re: [lpc2000] Problems on first board
2006-03-10 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Friday, March 10, 2006 11:00 AM
Subject: [lpc2000] Problems on first board
I\ufffdm burning a blinky program on LPC2144 and can\ufffdt make it work, even if I
can burn it on internal flash. I\ufffdve succesfully tried this code on MCB2140,
and a good voltage source. I\ufffdve verified all the VDD's, VSS's and verified
Why can\ufffdt my code run if I can burn it on flash? If someone knows anything
Have you tried JTAG, if your board has the connector on it?
Leon
Unfortunatelly, I don't have a JTAG and don't have any connector for this type of debugger on my board.
Thiago Takehara
Computer Engineer
  To: lpc2000@yahoogroups.com
  Sent: Friday, March 10, 2006 8:15 AM
  Subject: Re: [lpc2000] Problems on first board
  Leon
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
        Pic microcontrollers
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
