IAP questions (LPC2101) - conserving flash
2006-03-11 by shergtu
Hi, I searched before posting & didn't find what I was looking for, hopefully this isn't old territory. I will be using the 2101 in a new design. 2k SRAM, 8k flash (2x4k blocks) It seems as though the minimum amount that can be programmed at once (IAP) is 256 bytes, and that the RAM-->flash copy command is what does it. I need to use a portion of the flash as a non-volatile memory, presumably through IAP at run-time. Let's assume that my code uses approx. 7k of the 8k of the on-chip flash, and that the block of info I need to save is 64 bytes in size. There can't be any sector erasing, since code is in both sectors. The last 1k of flash leaves enough room for 16 "chunks" of 64 bytes each.... in reality, over the life of the product, there will probably only be a handful (2..3...4) updates of this block. [Anyway, these numbers (7k boundary, 64 byte block) are still TBD, I'm just trying to talk through an example....] So here is what goes through my mind, can anyone tell me "that should work", "you're insane", etc... - I'll need to dedicate (or at least share) a 256-byte chunk of RAM to go back & forth with flash, i.e. I can't use IAP to write only 64 bytes - I'll (re-write) 0xFF's to the later "virgin" parts of flash, and with each update I'll fill in the next 64 byte chunk. So in other words, the first time I write the 64 byte block, it will be written to offset 7k in flash, and I'll use IAP to write a 256 byte block from RAM, with the first 64 bytes being "valid", and the last 192 bytes being 0xFF. The second time I write the block (i.e. the first update in the field), I will read 256 bytes from flash at flash offset 7k into RAM, fill in bytes 64-127 (0-based) with the new info, keeping the "stale" data in the first 64 bytes (or maybe zeroing them out... TBD), and still leaving the last 128 bytes as 0xFF. As the need arises, I can continue to march down the flash part, only clobbering 64 bytes at a time, taking care to keep the rest at 0xFF until I need to change them. Does that make sense? Is it clear what I'm trying to do? Any (many?) flaws in the approach? Thanks a lot for your input.
