Lpc2000
Acceptance filter
Acceptance filter
2006-03-14 by David Mercier
I have the following code to add extended IDs in the acceptance filter but I
can't get it to work.
May somebody help me to find the problem ?
Or anybody has some code that I could use to get it work ?
Best regards
David Mercier
int16_t canSetFilter (uint16_t canPort, uint32_t canID)
  uint16_t p, n;
  uint32_t buf0, buf1;
  uint32_t *pAddr;
  AFMR = AF_ACCEPT_ALL; // Allow modif on Acceptance Filter
  if (mCANFilter >= MAX_FILTERS)
    return 0;
  // Filters must be sorted by interface, then by priority
  canID &=   0x1FFFFFFFL; // Mask out 29-bit ID
  canID |= (canPort << 29); // Put can_port info in bits 29, 30, 31
  // new filter is sorted into array
  p = 0;
  while (p < mCANFilter) // loop through all existing filters
    // If ID at position p is bigger than the one we need to insert
    if ((mCANFilterList[p].MsgID) > canID)
      break;
    p++;
  // move all remaining entries one row up
  for(n = mCANFilter; n > p; n--)
    mCANFilterList[n].MsgID = mCANFilterList[n-1].MsgID;
  // insert new filter here
  buf0 = mCANFilterList[p].MsgID; // save current entry
  mCANFilterList[p].MsgID = canID; // insert the new entry
  mCANFilter++;
    p++;
    buf1 = mCANFilterList[p].MsgID;
    mCANFilterList[p].MsgID = buf0;
    buf0 = buf1;
  // Now work on Acceptance Filter Configuration
  // Set CAN filter for 29-bit extended identifiers
  p = 0;
  // Set pointer for Standard Frame Individual
  // Standard Frame Explicit
  SFF_sa = p;
  // Set pointer for Standard Frame Groups
  // Standard Frame Group Start Address Register
  SFF_GRP_sa = p;
  // Set pointer for Extended Frame Individual
  // Extended Frame Start Address Register
  EFF_sa = p;
  pAddr = (uint32_t *)&AFRAM;
  for (n = 0; n < mCANFilter; n++)
    *pAddr = mCANFilterList[n].MsgID;
    p += 4;
    pAddr++;
  // p is still pointing to end of table;
  // last entry must contain unused filters
  *pAddr = 0xF7FFF7FF;
  p += 4;
  // Set pointer for Extended Frame Groups
  // Extended Frame Group Start Address Register
  EFF_GRP_sa = p;
  // Set ENDofTable
  // End of AF Tables Register
  ENDofTable = p;
  // Acceptance Filter Mode Register, start using filter
  AFMR = AF_ON;
  return 1;
RE: [lpc2000] Acceptance filter
2006-03-14 by Joel Winarske
> I can't get it to work.
What are the values of AF_ACCEPT_ALL and AF_ON in your code?
Joel
Re: [lpc2000] Acceptance filter
2006-03-15 by David Mercier
Sorry about that !
#define AF_ON               0
#define AF_OFF              1
#define AF_ACCEPT_ALL       2
> but
> Joel
>  SPONSORED LINKS
>   Microcontrollers<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ>
> Microprocessor<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=9jjd2D3GOLIESVQssLmLsA>  Intel
> microprocessors<http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw>   Pic
> microcontrollers<http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw>
> YAHOO! GROUPS LINKS
>    -  Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000>"
>    on the web.
>    -  To unsubscribe from this group, send an email to:
>     lpc2000-unsubscribe@yahoogroups.com<lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>    -  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>    Service <http://docs.yahoo.com/info/terms/>.
