Lpc2000
Entering ISP mode from user code?
2006-03-17 by Mukadder CEYHAN
as explained in AN10356 and here:
http://www.compuphase.com/lpc2100_isp.htm
for entering from user code to bootloader mode.
But after entering the user code what should be done?
The "LPC2000 Flash Utility" program from philips does
not  give any response when entered isp mode from my
code in LPC2138.
What am I missing? If so, what is the correct
provedure?
thanks..
Do You Yahoo!?
http://mail.yahoo.com
Re: [lpc2000] Entering ISP mode from user code?
2006-03-17 by K B Shah-lascaux
May be you need to look at PLL settings and processor speed ...
The Bootloader assumes certain speed of core for communication correctly with UART, you you change this by enabling pll  you  will fail to communicate.
kb
  To: lpc2000@yahoogroups.com
  Sent: Friday, March 17, 2006 8:34 AM
  Subject: [lpc2000] Entering ISP mode from user code?
  code in LPC2138.
  provedure?
  thanks..
  Do You Yahoo!?
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
        Pic microcontrollers
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
  Checked by AVG Free Edition.
  Version: 7.1.385 / Virus Database: 268.2.4/283 - Release Date: 16/03/2006
this is not applicable solution, because the isp mode
requires no pll activated, it runs only with crystal
above 10 MHz.To enter isp mode pll must be deactivated
if it is actively running.
I do not know the erros but searching for the
solution...
> processor speed ...
> kb
>   ----- Original Message -----
>   From: Mukadder CEYHAN
> code?
> done?
> does
> my
>   code in LPC2138.
>   provedure?
>   thanks..
>   Do You Yahoo!?
> protection around
>   YAHOO! GROUPS LINKS
> email to:
> removed]
Do You Yahoo!?
protection around
Do You Yahoo!?
