Writing to Flash
2004-03-12 by rhpascaldodo
Hi, I'm very new to ARM and LPC. I read that very writing into the Flash must be done via the onchip bootloader which resides alsp in the Flash. This is true for download via the serial port and also for write accesses by the application. Question: Is there way to write into the Flash without using the Bootloader? I think of building a very specialized Bootloader which works on the SPI, I2C or TCP/IP. I read in this forum that it is possible to destroy the Bootloader content and then the chip becomes an OTP :-) And here should be the way to write some RAM parts via JTAG, download a small loader into the RAM also via JTAG and then let the CPU jump into this loader which then at least can download a new firmware and (maybe) also a new bootloader into the bootloader section. Any hints or links? Rolf
