Lpc2000
interrupts + Keil + LPC2294
2006-03-21 by grodo2k
Hello
could someone be so kind and say, what is wrong in following code? Or
maybe it is ok, but it doesn't work... I want trigger an interrupt
using UART0. I am using Keil. (UART0 is ok, it sends a string from tab).
thanks in advance
int i,j;
char tab[] = "UART0 is working properly";
void UART0INT() __irq
	IO0CLR |= 0x20000;  //clr P0.17 (it's a LED)
	for(i=0;i<5;i++)
		for(j=0;j<50000;j++){}
	send_char_u0('A');
	VICVectAddr = 0x00000000; //dummy write
int main(void)
	PLL_ON();
	LED_init();
	VPBDIV = 0x1;
	UART0_init();
	IO0SET |= 0x20000;  //set P0.17
	send_string_u0(tab);
	VICIntSelect = 0x00000000;
	VICVectAddr0 = (unsigned) UART0INT;
	VICVectCntl0  = 0x26;	//UART0
	VICIntEnable = 0x40;		//bit 6 = UART0
	while(1)
	return 0;
RE: [lpc2000] interrupts + Keil + LPC2294
2006-03-21 by Andrew Berney
we could do with the function UART0_init from your code, however I suspect
your problem is that you're not reading U0IIR to clear the UART IRQ. You
also have a huge delay inside your IRQ which kind of defeats the point of
using it. Have a look at the description of U0IIR register.
Here is a working example from a 2129 which should work equally well on your
chip with minor modification:
void main(void)
  // init the serial ports
  init_serial();
  // main loop
  while(1)
    for(;;);
void init_serial (void)    	// Initialize Serial Interface
  //UART0
  VPBDIV  = 0x00000001;	    //Set PClk to 60Mhz
  PINSEL0 = 0x00000005;     //Enable TxD0, RxD0
  U0LCR   = 0x00000083;     //8 bits, no Parity, 1 Stop bit
  U0DLL   = 0x00000084;     // 9600 Baud Rate @ 60MHz VPB Clock
  U0DLM   = 0x00000001;
  U0LCR   = 0x00000003;     // DLAB = 0
  U0IER   = 0x00000001;     //enable rx data available interrupt
  VICVectCntl1 = 0x00000026;
  VICVectAddr1 = (unsigned)uart0_irq;
  VICIntEnable |= 0x00000040;
  U0FCR   = 0x00000001;		//Enable FIFO & trigger level to 1 bytes
static unsigned int U0IIR_copy;
void uart0_irq(void) __irq
  //check for a character from the UART0 RX FIFO
  if((U0LSR & 0x01) == 0x01)  //if there is a character
    toggle_LED(1);		//do this to suit your board
  //exit ISR
  U0IIR_copy = U0IIR;
  VICVectAddr = 0x00000000; 	//dummy write to re-enable interrupt for next
time
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of grodo2k
Sent: 21 March 2006 11:38
To: lpc2000@yahoogroups.com
Subject: [lpc2000] interrupts + Keil + LPC2294
Hello
thanks in advance
int i,j;
	for(i=0;i<5;i++)
	send_char_u0('A');
int main(void)
	PLL_ON();
	LED_init();
	VPBDIV = 0x1;
	UART0_init();
	while(1)
	return 0;
Yahoo! Groups Links
2006-03-21 by Grodo Grodo
Thank you, I'll try it and say if it works by me.
Andrew Berney <amb@...> wrote:          Hi,
  void main(void)
    init_serial();
    // main loop
    while(1)
      for(;;);
    //UART0
    U0DLM   = 0x00000001;
    //exit ISR
    U0IIR_copy = U0IIR;
  time
  Of grodo2k
  Hello
  thanks in advance
  int i,j;
        for(i=0;i<5;i++)
        send_char_u0('A');
  int main(void)
        PLL_ON();
        LED_init();
        VPBDIV = 0x1;
        UART0_init();
        while(1)
        return 0;
  Yahoo! Groups Links
          SPONSORED LINKS
                                                        Microcontrollers                                          Microprocessor                                          Intel microprocessors        Pic microcontrollers
    YAHOO! GROUPS LINKS
Yahoo! Travel
 Find  great deals to the top 10 hottest destinations!
2006-03-26 by Grodo Grodo
Andrew, thank you very much ;) In fact I am working with CrossWorks but  I coudn't trigger any interrupt there, so I thought, maybe I will do it  in Keil. But it didn't work either. Now it is working ;) It helped me  much, thanks again ;)
Grodo Grodo <grodo2k@...> wrote:          Thank you, I'll try it and say if it works by me.
    void main(void)
      init_serial();
      // main loop
      while(1)
        for(;;);
      //UART0
      U0DLM   = 0x00000001;
      //exit ISR
      U0IIR_copy = U0IIR;
    time
    Of grodo2k
    Hello
    thanks in advance
    int i,j;
          for(i=0;i<5;i++)
          send_char_u0('A');
    int main(void)
          PLL_ON();
          LED_init();
          VPBDIV = 0x1;
          UART0_init();
          while(1)
          return 0;
    Yahoo! Groups Links
            SPONSORED LINKS
      YAHOO! GROUPS LINKS
  Yahoo! Travel
          SPONSORED LINKS
    YAHOO! GROUPS LINKS
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
