Lpc2000
newlib usage
newlib usage
2006-03-23 by Pranav Mocha
Hello all,
First of all I would like to thank the moderator for allowing me join this group. Being a newbe, I have some pretty basic questions-
1. To get functions such as printf, sprintf etc., does one have to link newlib? if so how can link newlib?
2. Is newlib to be used as a standard library? and how/where can I get the list of functions and their prototypes?
I am sorry for asking such basic questions, but having worked on Keil and turbo c, i could not really get GCC right. Thank you all in advance.
Pranav
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
Re: [lpc2000] newlib usage
2006-03-23 by Robert Adsett
Quoting Pranav Mocha <parnay56@...>:
It's one of several libraries that will provide that function.
Yes it is meant to be used as a standard libary.  Function Prototypes are
available in any standard C library reference.  Basically it implements the C
standard library functions for ANSI C90.
It does, however, need to have interface functions provided so it can adapt to
different processors and boards.  One example is newlib-lpc
http://www.aeolusdevelopment.com/Articles/download.html
> advance.
You might want to start with something like WINARM to limit the number
of things
you need to learn at one time.
Robert
Another newlib question
2006-03-24 by alex svetek
Hello all,
I am also starting with ARM's (LPC2138) and i would like to know if I can use newlib-lpc for my processor.
Alex
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2ยข/min or less.
Re: [lpc2000] Another newlib question
2006-03-24 by Robert Adsett
You should be able to.  I haven't seen a 2138 specific link file but it
shouldn't be too hard to modify an existing one for the different memory
map.  Newlib-lpc uses a few link time defined symbols to determine  where
to place the heap among other things.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to chew
a radio signal. "  -- Kelvin Throop, III
2006-03-25 by Tom Walsh
alex svetek wrote:
>Hello all,
I use newlib, it drives the RDCF2 FAT filesystem for the SD card, and
newlib functions are used extensively throughout the code: memcpy,
strncmp, etc.  I don't use newlib-lpc only out of how I write code, I
would prefer to write my own extensions to a library so that I can
quickly fix any problems later rather than spend time learning what
someone else wrote.
Newlib is essentially a foundational library of common functions:
memcpy, strcmp, strcpy, etc.  It also embodies higher level code such as
printf, scanf, etc.  For myself, I use the file streams logic (fopen,
fread, fputs) to implement a FAT 12/16 filesystem layer.  Rather than
write my own stream code, it is more convenient to use what is already
there.
Details on building a set of development tools is at:
http://www.openhardware.net/?title=ARM%20Thumb%20tools%20for%20LPC2000&dir=ArmTools&file=ThumbToolchain.html
newlib is also used with the LPC2106 processor on my board.
TomW
RE: [lpc2000] Another newlib question
2006-03-25 by Joel Winarske
Hi Alex,
In addition to Tom's info this is a good reference:
http://billgatliff.com/drupal/node/25
Also the Ethernut project has a good number of examples for implementing
driver stubs that is applicable to implementing newlib.
http://www.ethernut.de/
Joel
