Lpc2000
C question
C question
2006-03-15 by heedaf
I have a newbie question.  In the following code
    void ADC0Handler (void) __irq
What does __irq do?  I've never seen this before.  It comes from the
Kiel ADC sample listed Philips website.
Dewayne
Re: C question
2006-03-15 by elektrknight
__irq is telling the compiler that the  "void ADC0Handler (void)" is
not an ordinary function that you can call but an interrupt handler.
Typically interrupt handlers are getting called in response to some
hardware event, in this case the ADC0Handler will service interrupts
generated by the ADC0 unit.  If you follow the code you will notice
that the  ADC0Handler is installed as the irq handler by the
install_irq function called by the ADCInit. If you are curious, you
will notice that install_irq takes address of the ADC0Handler and
stuffs it into an empty  slot in VIC (Vector Interrupt Handler)
associating it with the interrupt number (channel) corresponding to
the ADC0 unit.
 So the question is how does the ADC0Handler gets called if it is
never called directly from the code?  Consider the situation when ADC0
is done with the A/D conversion and wants attention from the CPU.  To
get it,  ADC  asks VIC to generate interrupt on VIC channel ADC0_INT ,
in turn VIC will look through all of the slots for a matching handler.
 If it finds one it will then interrupt the CPU and make it jump to
the address in the slot which in this case will be ADC0Handler!
 Since, the interrupt handler can be called at any time the compiler
needs to know that to generate code that is a bit different then for
the normal functions and __irq is doing that.
 I hope this will help you a bit but this is just a beginning and as
always devil is in (a lot of) details that I did not mention. If you
want to learn more check  ARM  and Philips  documentation, look for
exception handling and interrupts.
thanks,
elektrknight
> Thanks,
> Dewayne
Re: [lpc2000] C question
2006-03-17 by Jack Key
The Keil CA Compiler implements the keywords __irq and __fiq. With the __fiq keyword the compiler does not save the CPU registers R8 - R12, since the ARM CPU implements separate registers in the FIQ mode.
  This is what the keil help says. Above that I do not know anything more than the obvious fact that __irq tells the function that it is an irq interrupt. Then you may ask what is the use of the register VICIntSelect. I too dont know the answer for that. Anyways, hope my effort was of any help.
  Jack.
Dewayne
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors     Pic microcontrollers
  YAHOO! GROUPS LINKS
 Yahoo! Mail
 Use Photomail to share photos without annoying attachments.
RE: [lpc2000] C question
2006-03-17 by Andrew Berney
I am guessing that it's simply a keyword to inform the compiler gracefully
that it will need to apply a sub of 4/8 bytes from the Link Register before
it returns from the IRQ function.
The reasoning being that having entered an FIQ/IRQ the link register will
contain the address of the discarded instruction + 4, this way the compiler
understands it needs to put in a SUBS R15, R14, #4 instruction rather than
simply copying R15 back onto R14 as per a SWI. That said in the case of a
data abort the exception will actually have occured one instruction after
the execution of the instruction that threw the exception, in this case we
need to go back 2 instructions and therefore apply: SUBS R15, R14, #8.
Following this its plain sailing - simply restoring the user mode and
copying the SPSR to the CPSR and we're back to processing user code at the
point where we were interrupted.
Andy
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of Jack Key
Sent: 17 March 2006 13:28
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] C question
  Jack.
Dewayne
  SPONSORED LINKS
microcontrollers
  YAHOO! GROUPS LINKS
 Yahoo! Mail
Yahoo! Groups Links
Re: C question
2006-03-18 by heedaf
So is the "__" in __irq specific to the compiler since it gives me
an error in CrossStudio?
gracefully
Register before
register will
compiler
rather than
case of a
instruction after
case we
#8.
and
code at the
> Andy
Behalf
> Of Jack Key
the __fiq
since the ARM
anything more
irq
VICIntSelect. I
any help.
>   Regards,
>   Jack.
> Thanks,
> Dewayne
>   SPONSORED LINKS
microprocessors     Pic
> microcontrollers
>   YAHOO! GROUPS LINKS
Service.
>  Yahoo! Mail
Re: [lpc2000] Re: C question
2006-03-18 by Robert Adsett
Actually the whole thing is compiler specific.  One of the reasons I write
my own interrupt prologs in and epilogs in assembly.  The main reasons
being control and safety.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
[lpc2000] Compiler vs cross compiler
2006-03-20 by malhotra_umang@yahoo.com
hey friends,
  I want to know a fact...
  what is the difference between a compiler and a cross-compiler
  please help me find out...
  Thanks...
  Umang Malhotra
 Yahoo! Mail
Re: [lpc2000] Compiler vs cross compiler
2006-03-20 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Monday, March 20, 2006 3:33 PM
Subject: [lpc2000] Compiler vs cross compiler
> hey friends,
A cross-compiler generates code for a different CPU than the the one that it
is running on. Most compilers for embedded systems are cross-compilers.
Leon
RE: [lpc2000] Compiler vs cross compiler
2006-03-20 by Paul Curtis
Leon,
> > hey friends,
> the one that it
> cross-compilers.
Actually, not quite true.
There are native compilers (aka hosted compilers in ISO C speak) which
generate code for direct execution on the processor and operating system
on which the compiler is hosted.  For example, MS VC generating Win32
apps is a native compiler, as is the Ultra compiler on OS-9 which
generates code for 68K/386/PPC-based OS-9 systems, as is the classic cc
compiler shipped with many older Unicies.
A cross compiler generates code that cannot be directly executed on the
host because either (a) it targets a different processor or (b) it
targets a different OS.  An example of this type of compiler is your
regular embedded C compiler provided by IAR, RAL, GHS, and so on.  But
there are (many) non-commercial never-to-be-seen cross compilers that
are used internally (for instance, I always used to build our Modula-2
products on a Sun-3, but they targeted transputers, ARMs, 386s and 68Ks
on various operating systems, I never built them native).
There are also things that are difficult to categorize, such as Apple's
recent introduction of Universal Binaries, for instance.
Paul Curtis, Rowley Associates Ltd   http://www.rowley.co.uk
CrossWorks for MSP430, ARM, AVR and now MAXQ processors
2006-03-20 by Tom Walsh
Paul Curtis wrote:
>Leon,
>>>hey friends,
>>the one that it
>>cross-compilers.
Heh, you should try it sometime, it will quickly convince you that a
compiler running natively on an embedded platform is a horrible idea.
:P  I tried that with an SA1100 running @ 166MHz, terribly slow!
TomW
2006-03-20 by Micron Engineering
malhotra_umang@... ha scritto:
> hey friends,
>   Thanks...
>   Umang Malhotra
A cross compiler is a compiler that produce object code for a different
cpu/calculator then the cpu of the calculator where it is runnig.
So if you have a compiler running on your PC that may produce object
code for an ARM processor, that compiler is a cross compiler.
>  Yahoo! Mail
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.2.4/283 - Release Date: 16/03/2006
2006-03-20 by David Hawkins
>>hey friends,
>>  Thanks...
Its what you get when you feed your compiler bad code.
[lpc2000] RISC vs CISC
2006-03-21 by malhotra_umang@yahoo.com
Hi friends..
  I have a few more questions..
1. Differences between SPI and I2C serial interfaces .
2. what is pipelining in embedded
3. what is difference b/w harward and von-newman architectures.
4. RISC vs CISC
5. Interrupt latency...
 Yahoo! Mail
Re: [lpc2000] RISC vs CISC
2006-03-21 by Micron Engineering
> Hi friends..
> 4. RISC vs CISC
let study, learn and study....good luck
>  Yahoo! Mail
Version: 7.1.385 / Virus Database: 268.2.6/286 - Release Date: 20/03/2006
RE: [lpc2000] RISC vs CISC
2006-03-21 by Paul Curtis
> 4. RISC vs CISC
Please, do your own assignments.
2006-03-21 by Tom Walsh
malhotra_umang@... wrote:
>Hi friends..
>4. RISC vs CISC
Ah, nearly April, time for the students to be finishing up on projects...
TomW
2006-03-21 by Xtian Xultz
Em Ter 21 Mar 2006 10:58, malhotra_umang@... escreveu:
> Hi friends..
I2C - Multiple devices on one bus, SPI - one device and one master
I2C - Only two signals (data & clock), SPI - three signals (but in some
situations can be only two)
I2C - Not so fast, SPI - a little bit more fast
I2C - Not so easy protocol, SPI - very easy protocol (I made a SPI port in
firmware because I needed to interface two SPI devices in one LPC2106)
Take a look at "Insiders Guide to LPC2106
Damn, search for a book.
> 4. RISC vs CISC
Are you kidding?
I'm tired.
2006-03-21 by FabioDB
SPI: More devices and one master
I think that is not a good solution to implement a software SPI on GPIOs.
I have driven 8 devices with only one SPI port of LPC2106 only enabling
CS of related device
And I have tested SPI comunication up to 11 Mbps!
2006-03-21 by Mark Norton
Try Google my friend.  A simple search on "von neuman"
returns some of the information that you require.  Try
this:
http://www.bores.com/courses/intro/chips/6_mem.htm
--- malhotra_umang@... wrote:
> Hi friends..
> architectures.
> 4. RISC vs CISC
>  Yahoo! Mail
> attachments.
> removed]
Do You Yahoo!?
http://mail.yahoo.com
2006-03-21 by Onestone
>Hi friends..
>4. RISC vs CISC
Not while I'm busy...
Al
> Yahoo! Mail
>Yahoo! Groups Links
Re: RISC vs CISC
2006-03-21 by Ken Wada
1. SPI is a four-wire interface, I2C is a two-wire interface.
Check the Philips website for a complete description for the I2C
interface. The SPI interface is very much like a simple 8-bit shift
register with parallel load.
2. Read this article! http://en.wikipedia.org/wiki/Pipeline_(computer)
3. Both architectures address how data is moved to/from the execution
unit. Harvard used multiple busses, (high connectivity), von-Neumann
uses single bus, (low connectivity). Harvard is used in devices such
as DSP's, 8051. von-Neumann is typically used by PowerPC type
processors.
4. RISC = Reduced Instruction Set Computing; CISC = Complex
Instruction Set Computing. Google RISC and CISC, or enter these
acronyms in Wikipedia; www.wikipedia.org
5. Interrupt latency == the amount of time it takes for the silicon
state machine to pre-empt the current process to enter into the
interrupt condition. It can also mean the amount of time it takes to
process the interrupt. It has also been used to describe the amount of
time it takes to save/restore the context.
Now That I Have Entertained You ...> PLEASE find the information and
learn this stuff yourself!!!
Ken Wada
--- In lpc2000@yahoogroups.com, <malhotra_umang@...> wrote:
> Hi friends..
> 4. RISC vs CISC
>  Yahoo! Mail
Paul Curtis wrote:
>Hi,
>>4. RISC vs CISC
Interesting to note just how many people on this list were eager to help
him with his college paper...
TomW
2006-03-25 by Xtian Xultz
Em Ter 21 Mar 2006 12:08, FabioDB escreveu:
I understand, but my problem is that my SPI devices are 25 cm away (in another
board) from the board with my uC. So, I have two boards with SPI devices
attached to my CPU board, with flat cables, and I could not have another line
in the flat cable with the CS signal, so, I needed to write the SPI protocol
in firmware...
