> USB RAM "uncloaked".
> Yes, it is LPC 2148 issue, not a toolset's.
> Obviously, if one uses USB peripheral, it has to be powered up.
> That is done by PCONP=0x8000 0000;
> or at the end of startup by this:
> ldr r0, =PCONP
> mov r1, #0x80000000
> str r1, [r0]
> The (side) effect is that it *also enables* the 8kb of USB RAM
> (at 0x7FD00 0000). No wonder no one else noticed it before!
> As soon as the RAM comes online it is filled with random values.
> It might need to be cleared/init.
> Now, this tidbit explains those crashes if one places stack(s) there
> (in a linker file) without powering up USB.
> The RAM is unavailable, you can "write" to it (not getting data
> abort), but when you read it you get zeros.
> Not good for stack operation.
> It would be nice to have have this RAM segment initialized to zero
> by segment_init, but I did not have time to mess with this.
> Maybe someone else might have an idea.
> There are no secrets, only mysteries. Now, cross this one out, please.
> Next! :-;
> Roger
> --- In lpc2000@yahoogroups.com, "shergtu" <shergtu@...> wrote:
>>> I have found so far, that by making changes to linker file, RAM is
>>> there available for RD/WR, but C-Spy will *not* show anything but
>>> zeros; it treats it as ROM, any overtyped value is ignored.
>>> I have downloaded JARM.DLL ver 3.14, replaced my 2.74c, with no
>>> difference in behavior.
>>> Is anybody outhere able to see in C-Spy the USB_DMA RAM as RAM?
>>> I appreciate your feedback.
>>> BTW, EWARM 4.31A is out, have not tested it, yet.
>>> My observations were for ver. 4.30A.
>>> Thanks!
>>> Roger
>> Hi Roger,
>> Thanks for your input on this too.
>> For what it's worth, I'm using Keil / uVision 3 with the ARM
>> development tools, and I only read back zeros as well.
>> I first noticed the problem with USB RAM when my code crashed in ISRs
>> while running directly out of flash, no JTAG or debugger at all.
>> Turns out the writes to the IRQ stack (i.e. IRQ mode R13 set to point
>> into USB RAM) went into the great bit bucket, so when popping the LR
>> from the stack, PC = 0x0000.0000 and off we go....
>> (One thing that is frustrating, I guess it was a design choice by the
>> engineers at Keil -- if in the debugger I modify (for example) memory
>> 0x7FD0.1000 to a value of 0x55, it shows the change -- until I step
>> the next instruction. Then it changes the displayed value back to
>> 0x00. Um, is there a reason the value isn't read back by the
>> debugger immediately after it is written, so that what is displayed
>> reflects what is *really* in the memory? I'm willing to wait the
>> extra few usec/msec for that benefit. :-) )
>> I was hoping to just "manually" carve/manage the 8K USB RAM block
>> myself for things like task & interrupt stacks, ring buffers, etc...
>> In other words I wanted to avoid scatter/gather linker files, and
>> compile-time locating of structures.... at run time I'll just point
>> into the USB RAM and carve it up.
>> I'm actually shocked that no one else has tried to use the USB RAM
>> for something other than USB (at least no one has chimed in that
>> effect).
>> I'll keep you posted on what I find.
