Lpc2000
Where to find real datasheet for 2129 ?
2006-03-29 by tinia0
I'm looking for detailed datasheet for Philips 2129 ARM processor
(particularly seeking more info about its CAN module).
Last projects were on Microchip's products, so maybe I got a bit used
to exhaustive docs. Where do you guys find needed informations ?
Thanks in advance,
regards,
Rob.
Re: [lpc2000] Where to find real datasheet for 2129 ?
2006-03-29 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, March 29, 2006 2:11 PM
Subject: [lpc2000] Where to find real datasheet for 2129 ?
> Hi,
There should be a separate users guide, with a lot more info.
Leon
Leon Heller, G1HSM
leon.heller@...
http://www.geocities.com/leon_heller
2006-03-29 by Ake Hedman, eurosource
tinia0 wrote:
> Hi,
> Thanks in advance,
> regards,
> Rob.
Agree that compared to Microchip the site is rely bad. Search for
"lpc2129 user manual" and you find it. Sometimes a direct link works so
you can try this as well
http://www.semiconductors.philips.com/pip/LPC2129.html.
LPC is a good complement to the PIC so it is worth it though..... ;-)
/Ake
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavagen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 0533 146
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
tinia0 wrote:
> Hi,
> Thanks in advance,
> regards,
> Rob.
Sorry wronf direct link in my previous mail. It should be
http://www.semiconductors.philips.com/acrobat/usermanuals/UM_LPC21XX_LPC22XX_2.pdf
Cheers
/Ake
Re: Where to find real datasheet for 2129 ?
2006-03-29 by brendanmurphy37
If you navigate to the main product page at
http://www.semiconductors.philips.com/pip/LPC2119FBD64.html
you should see it (eventually!) towards the bottom of the page
under "Support & tools" - you're looking for the User Manual.
--- In lpc2000@yahoogroups.com, "Ake Hedman, eurosource" <akhe@...>
wrote:
> tinia0 wrote:
> > Hi,
used
> > Thanks in advance,
> > regards,
> > Rob.
works so
> /Ake
2006-03-29 by Tennessee Carmel-Veilleux
On Mar 29, 2006, at 8:11 AM, tinia0 wrote:
> Hi,
For the CAN module, you must look at the SJA1000 datasheet to get all
the details, especially about bit timing. The LPC2129 CAN module is an
SJA1000 on the ARM bus. The datasheet is at:
http://www.semiconductors.philips.com/acrobat/datasheets/SJA1000_3.pdf
Also, see CANBTR.py at:
http://groups.yahoo.com/group/lpc2000/files/Tools/
It's a tool I have programmed in Python (http://www.python.org) to
calculate the best CANBTR value for a particular bitrate. Just change
the constants at the beginning of the file to your values and it should
give accurate results. It has been tested several times with the
LPC2129.
Best Regards,
2006-03-29 by lpc2100_fan
Well, the module on the LPC2129 has some similarities with the SJA1000
but it is most definitely not the same!
Bit timing is something that might not be implementation specific, so
using tools that work for the SJA1000 could also work for the LPC2129
but you do yourself a favor applying the Users Manual to your software
development rather than the SJA1000 documentation.
There is a good software example in the files section how to use the
CAN.  LPC2_CAN_Examples
Regards, Bob
--- In lpc2000@yahoogroups.com, Tennessee Carmel-Veilleux
> > Hi,
---snip ---
---snip ---
RE: [lpc2000] Re: Where to find real datasheet for 2129 ?
2006-03-29 by Joel Winarske
The IP in the LPC2129 CAN controller is based on the SJA1000.  It's a 32-bit
variation of the SJA1000.
These guys wrote the LPC2 CAN examples floating around:
http://www.esacademy.com/faq/calc/sja1000.htm
There's also further CAN code for the LPC2 in their MicroCANopen demo code.
Joel
