How to find LPC2000 and LPC3000 documents on the Philips website
2006-03-29 by philips_apps
Hi, please accept our apologies for the sometimes difficult navigation on the Philips website. To find the documents, it is most important to use a good starting point. http://www.philips.com/microcontrollers/ is definitely the best you can use. In the box located in the center of the page you will find the best links to the LPC families. The words marked with "link" are the active links. ------------ Copy of website text ------------ From the smallest 8-bit to the highest performing 32-bit ARM products, we drive the industry as an innovation leader with our high-integration and costeffective "LPC3000", "LPC2000", "LPC900", "LPC700", and "80C51" microcontroller families. Be sure to visit our "support section". --------- End of Copy of website text ------------- Detailled information about a product can be found in the USERS MANUAL, which is intended for the software developer, parametric data such as power numbers, timings are found in the DATA SHEET. --------- Shortcuts ----------- For information on all LPC2000 products go here: http://www.standardics.philips.com/products/lpc2000/all/ Click the green "+" sign and get access to Users Manual and Application Notes which are called "Support Docs" Philips Apps
