Lpc2000
code problems when connecting ARMs and TFT LCD screens
2006-03-29 by thal_munki
I am attempting to link an ARM microcontroller (LPC2103) and a color
TFT LCD screen (LP104V2 , 640x480 , TTL interface). The screen's
datasheet is found here: www.larwe.com/technical/datasheets/lp104v2-w.
pdf
The code I'm using to run the screen is shown below
Code:
#include <targets/LPC210x.h>
long pixel_number=0;        //Horizontal position of scan
long row_number=0;          //Verical position of scan
long delay_variable=0;
#define DCLK    0x00000004      //P0.2
#define HSYNC   0x00000008   //P0.3
#define VSYNC   0x00000010   //P0.4
#define DTMG    0x00000020   //P0.5
#define DATA    0x00000040   //P0.6 (This is blue data only)
#define button  0x00008000      //P0.15
static void
ledInit()
  IODIR |= 0x04000000;
  IOSET = 0x04000000;
static void
ledOn(void)
  IOCLR = 0x04000000;
static void
ledOff(void)
  IOSET = 0x04000000;
void
delay(int d)
  for(; d; --d);
void LCD_config(void){      //Configure GPIO for LP104v2
        IODIR=0xFF;   //P0.0 : P0.7 set to outputs
   IOCLR=0x00;   //P0.0 : P0.7 LOW
   pixel_number=0;
   row_number=0;
   IOSET=HSYNC;   //H sync high
   IOSET=VSYNC;   //V sync high
        IOSET=DATA;     //Data high
void LCD_page(void){        //Scan a page into LP104v2
    IOCLR=VSYNC;       //Lower V sync
    for(delay_variable=0; delay_variable<3397; delay_variable++);
                            //64uS delay
    for(delay_variable=0; delay_variable<554347; delay_variable++);
                        //1.02mS delay
    do{
        IOCLR=HSYNC;   //Lower H sync
        for(delay_variable=0; delay_variable<200; delay_variable++);
                            //3.77uS delay
        for(delay_variable=0; delay_variable<100; delay_variable++);
                            //1.89uS delay
        IOSET=DTMG;    //DTMG high
        do{
            IOSET=DCLK;    //Data clock high
            IOCLR=DCLK;    //Data clock low
            pixel_number++; //Increment pixel count
        } while (pixel_number<639);
        pixel_number=0;
        for(delay_variable=0; delay_variable<49; delay_variable++);
                            //0.94uS delay
        row_number++;  //Increment line number
    } while (row_number<478);
    for(delay_variable=0; delay_variable<190217; delay_variable);
                            //0.35mS delay
    row_number=0;  //Reset line counter
int
main(void)
  MAMCR = 2;
  ledInit();
  ledOn();
  delay(100000);
  ledOff();
  delay(100000);
  LCD_config();
  while (1)
    LCD_page();
  return 0;
I attached the data line to the Blue LSB on the LCD screen
(Theoretically this will produce a dark blue when high). The only
problem is that this is not happening. Nothing happens. I know the ARM
is running and the startup code is correct because it flashes the
status LED as stated in the code, and I know the LCD is functional
because for a fraction of a second it goes dark (this is not a result
of the ARM, it happens whenever power is applied to the screen. Where
have I gone wrong? help, anyone?
Re: code problems when connecting ARMs and TFT LCD screens
2006-03-30 by unity0724
Umm...
This is a panel with LCD glass driver (shift register drivers)
only. For 640x480, the data rate is:
    640(H)*480(V)*50(Refresh rate)=15,360,000
You need to clock data in at 15MHz clock rate for non-
multiplexed data lines (Color input lines).
Question: Does the LPC2103 has enough speed??
You have to refresh LCD at min 50Hz as the glass panel
normally keep toggling it's substrate voltage (every VSync).
For testing purpose, May be you can try with...
(light only 320x240 of the panel, for quick testing)
- HSync is normally tied to "latch clock" of the shift register
  driver => shift in 320 bits/data and clock it once
- VSync is normally tied to the line decoders and clear control of
  line counter.  Try Refresh 240 lines first
  => Toggles every 240 HSync pulses.
Hope it helps. LPC2103 do not have enough power, neither enough
RAM/ROM size to drive the 640x480 LCD directly...
Good luck...
color
> pdf
> Code:
> static void
> ledInit()
>   IOSET = 0x04000000;
> static void
> ledOn(void)
>   IOCLR = 0x04000000;
> static void
> ledOff(void)
>   IOSET = 0x04000000;
> void
> delay(int d)
>   for(; d; --d);
>    pixel_number=0;
>    row_number=0;
>                             //64uS delay
delay_variable++);
>                         //1.02mS delay
>     do{
delay_variable++);
>                             //3.77uS delay
delay_variable++);
>                             //1.89uS delay
>         do{
>         pixel_number=0;
delay_variable++);
>                             //0.94uS delay
>                             //0.35mS delay
> int
> main(void)
>   MAMCR = 2;
>   ledInit();
>   ledOn();
>   delay(100000);
>   ledOff();
>   delay(100000);
>   LCD_config();
>   while (1)
>     LCD_page();
>   return 0;
ARM
result
Where
Re: [lpc2000] code problems when connecting ARMs and TFT LCD screens
2006-03-30 by Peter Jakacki
Read page 9 of the lcd data sheet, you will have to satisfy the min and
max DCLK of 21MHz to 32MHz :-o
You are not even using fast I/O anyway but you won't get that update
rate in software, certainly not C, you will have to hand craft it in
assembler. If you are not adept in hardware or assembler you should give
up now (really).
As always .... RT*M and with this sort of stuff don't even bother unless
you have a scope handy and know how to use it.
*Peter*
> pdf
> Code:
> static void
> ledInit()
>   IOSET = 0x04000000;
> static void
> ledOn(void)
>   IOCLR = 0x04000000;
> static void
> ledOff(void)
>   IOSET = 0x04000000;
> void
> delay(int d)
>   for(; d; --d);
>    pixel_number=0;
>    row_number=0;
>                             //64uS delay
>                         //1.02mS delay
>     do{
>                             //3.77uS delay
>                             //1.89uS delay
>         do{
>         pixel_number=0;
>                             //0.94uS delay
>                             //0.35mS delay
> int
> main(void)
>   MAMCR = 2;
>   ledInit();
>   ledOn();
>   delay(100000);
>   ledOff();
>   delay(100000);
>   LCD_config();
>   while (1)
>     LCD_page();
>   return 0;
2006-03-30 by thal_munki
ok, what about this screen http://www.goldmine-elec-products.com/
prodinfo.asp?number=G13752
-- In lpc2000@yahoogroups.com, "unity0724" <unity0724@...> wrote:
> Umm...
> Good luck...
> Regards
> color
> > pdf
> > Code:
> > static void
> > ledInit()
> >   IOSET = 0x04000000;
> > static void
> > ledOn(void)
> >   IOCLR = 0x04000000;
> > static void
> > ledOff(void)
> >   IOSET = 0x04000000;
> > void
> > delay(int d)
> >   for(; d; --d);
> >    pixel_number=0;
> >    row_number=0;
> >                             //64uS delay
> delay_variable++);
> >                         //1.02mS delay
> >     do{
> delay_variable++);
> >                             //3.77uS delay
> delay_variable++);
> >                             //1.89uS delay
> >         do{
> >         pixel_number=0;
> delay_variable++);
> >                             //0.94uS delay
> >                             //0.35mS delay
> > int
> > main(void)
> >   MAMCR = 2;
> >   ledInit();
> >   ledOn();
> >   delay(100000);
> >   ledOff();
> >   delay(100000);
> >   LCD_config();
> >   while (1)
> >     LCD_page();
> >   return 0;
> ARM
> result
> Where
