Lpc2000
Anyone had a problem with port0.3 ?
2006-04-03 by sam_pr
When port0.3 is set as output, when writing '0' to that bit the ouput
goes '0', but, when writing '1' it seems that it becomes either input
or tristate so it voltage looks floating.
Anyone encountered such problem?
Thanks
Sam Pr
Re: Anyone had a problem with port0.3 ?
Forgot to say that i'm using the LPC2138
ouput
input
> Thanks
> Sam Pr
2006-04-03 by charlesgrenz
  Open collector output for the I2C.
regards,
Charles
> ouput
> input
> > Thanks
> > Sam Pr
Re: [lpc2000] Anyone had a problem with port0.3 ?
2006-04-03 by Robert Adsett
Quoting sam_pr <sam_pr@...>:
Isn't that one of the IIC I/Os?  See
http://www.open-research.org.uk/ARMuC/LPC2100Tips.html
Robert
Hello,
I know it has the abilty of I2C but I have configured it to GPIO, in
this case it is supposed to give 'real' '1' or am I wrong.
Sam
ouput
input
> Thanks
> Sam Pr
2006-04-03 by c.barbaro
It is an open collector even if you use it as simple GPIO.
(Same problem occurred to me...)
Carlo
> Hello,
> Sam
> ouput
> input
> > Thanks
> > Sam Pr
2006-04-04 by sam_pr
Thank you,
Finally found the mystery, I got a reply from PHILIPS support.
The pin description in the user manual and in the data sheet are
different...  and I, ufortunately, used the user manual.
One should compare these two manuals while designing.
Sam
ouput
input
> Thanks
> Sam Pr
