Question for Philips_apps
2006-04-03 by dave_baker_100
Hi, I'm using a LPC2214 & have connected the XCLK pin to a single input of another IC which needs to be sync'd with the CPU. I'm driving XCLK at 59MHz and I'm seeing an almost sinusoidal waveform ~2v pk-pk going between 0.5v & 2.5v which is very marginal. Is the XCLK pin capable of driving a 10pF input located 15mm away from the XCLK pin ? Thanks Dave Baker
2006-04-03 by Joerg Schulze-Clewing
Hello Dave, > > I'm using a LPC2214 & have connected the XCLK pin to a single input of > another IC which needs to be sync'd with the CPU. I'm driving XCLK at > 59MHz and I'm seeing an almost sinusoidal waveform ~2v pk-pk going > between 0.5v & 2.5v which is very marginal. Is the XCLK pin capable of > driving a 10pF input located 15mm away from the XCLK pin ? > 10pF represents around 270ohms at that frequency. I am not familiar with the LPC2214 but that doesn't seem like much of a load for a uC. Are you sure it's only 10pF? Lift the pin of the other IC and look again. If still sinusoidal the trace capacitance might be a bit high. If your scope probe is suspect you could use a resistive divider into a 50ohm coax and hook that to a fast scope (at least 1GHz) with the scope input terminated with 50ohms. The divider should have a ratio of 5-10, not more to avoid stray capacitances that could otherwise foul up things. If your trace is longer than an inch or two you may need a controlled impedance trace and a terminator at the target IC. Regards, Joerg http://www.analogconsultants.com/
Joerg Thanks for the suggestions. Using a very short ground probe I've got an improved waveform 2.5V pk- pk but asymmetrical, where the fall time is approx 3ns and the rise time is about 8ns. Removing the load improves the risetime and I get ~3v pk-pk. My scope has a 200MHz b/w & I've looked at a 70MHz clock on another board & I'm seeing a nice clean squarewave so I'm happy that the scope isn't giving a false picture. It does seem that the XCLK pin is having a hard time driving the load. I've doubled checked the datasheet & the load input capacitance is 10pF max. The clock trace is on the top layer & is ~15mm long, 12mil wide with no vias. There is a groundplane on the next layer. Do you have any other suggestions ? Regards Dave --- In lpc2000@yahoogroups.com, "Joerg Schulze-Clewing" <joergsch@...> wrote: > > Hello Dave, > > > > > I'm using a LPC2214 & have connected the XCLK pin to a single input of > > another IC which needs to be sync'd with the CPU. I'm driving XCLK at > > 59MHz and I'm seeing an almost sinusoidal waveform ~2v pk-pk going > > between 0.5v & 2.5v which is very marginal. Is the XCLK pin capable of > > driving a 10pF input located 15mm away from the XCLK pin ? > > > > 10pF represents around 270ohms at that frequency. I am not familiar > with the LPC2214 but that doesn't seem like much of a load for a uC. > Are you sure it's only 10pF? > > Lift the pin of the other IC and look again. If still sinusoidal the > trace capacitance might be a bit high. If your scope probe is suspect > you could use a resistive divider into a 50ohm coax and hook that to a > fast scope (at least 1GHz) with the scope input terminated with > 50ohms. The divider should have a ratio of 5-10, not more to avoid > stray capacitances that could otherwise foul up things. > > If your trace is longer than an inch or two you may need a controlled
> impedance trace and a terminator at the target IC. > > Regards, Joerg > > http://www.analogconsultants.com/ >
Hello Dave, > > Using a very short ground probe I've got an improved waveform 2.5V pk- > pk but asymmetrical, where the fall time is approx 3ns and the rise > time is about 8ns. > Again, I don't know the LPC2214 but 3nsec is possibly all it can do. Usually the output devices in a CMOS chip are similar so I don't quite get why rise and fall times are different, at least not if you are driving a CMOS chip with it. Looking at table 10 in the datasheet it appears that the LPC's outputs are symmetrical in device geometry. With symmetrical CMOS on both sides uneven rise and fall times typically happen when you run into a substrate diode, for example when the supply voltages are different. > Removing the load improves the risetime and I get ~3v pk-pk. My scope > has a 200MHz b/w & I've looked at a 70MHz clock on another board & I'm > seeing a nice clean squarewave so I'm happy that the scope isn't > giving a false picture. It does seem that the XCLK pin is having a > hard time driving the load. > A brief look at chapter 9 of the datasheet states 10nsec for the ports, not sure if that holds for XCLK but should be less. I don't know your configuration but a look at the fosc section could indicate that you are really pushing it with those 59MHz. If you are running at 3.3V supply then 3Vpp isn't all that bad. Table 10 states that worst case a port is 400mV off the respective rail at 4mA source resp. sink. This indicates that the output devices should be 100ohms or less. Into a 10pF load that would be about a couple nsec to swing well past the opposite digital threshold (time constant of 1nsec). Considering that whatever drives it internally isn't infinitely fast you might be looking at 3nsec or more. This still does not explain your 8nsec rise time. Something must be in the circuit that wants to hold it down. > I've doubled checked the datasheet & the load input capacitance is > 10pF max. The clock trace is on the top layer & is ~15mm long, 12mil > wide with no vias. There is a groundplane on the next layer. > 15mm is next to nothing, less than a pF depending on the prepreg between plane and layer. So there should not be any worries there. > Do you have any other suggestions ? > I'd try the coax and divider trick to eliminate the scope probe uncertainty. Changing the length of the ground made a difference as you had seen. At 50MHz there should not be a ground clip at all, the coax shield should tie into ground less than 5mm from where you want to measure. I use a Philips FET probe for that which came with a large supply of custom solderable coax jacks. The datasheet is a bit skimpy and I could not link to a family spec anywhere. The Philips web site is IMHO not a very efficient site. If you didn't do the layout yourself I'd take a hard look at the Gerber plots. More than once have I seen leftover stubs where the layouter wanted to go another route, decided otherwise and left a piece of the old trace in there. The DRC won't squawk since it's not connected to a third node but it adds capacitance. Regards, Joerg http://www.analogconsultants.com/
2006-04-04 by dave_baker_100
Joerg Again, thanks for your advice. I too am a bit surprised about the 8ns rise time. The XCLK signal is driving a FPGA global clock which has configurable voltage input thresholds - 3.3v CMOS, TTL, etc. I've tried selecting different standards but the result is the same. I don't think the scope is influencing things significantly as I've observed faster & better quality waveforms. However I'm keen to try the coax connector & divider trick you described. I'm not 100% clear of the configuration though. Could you talk me through the setup ? Regards Dave wrote: > > Hello Dave, > > > > > Using a very short ground probe I've got an improved waveform 2.5V pk- > > pk but asymmetrical, where the fall time is approx 3ns and the rise > > time is about 8ns. > > > > Again, I don't know the LPC2214 but 3nsec is possibly all it can do. > Usually the output devices in a CMOS chip are similar so I don't quite > get why rise and fall times are different, at least not if you are > driving a CMOS chip with it. Looking at table 10 in the datasheet it > appears that the LPC's outputs are symmetrical in device geometry. > > With symmetrical CMOS on both sides uneven rise and fall times > typically happen when you run into a substrate diode, for example when > the supply voltages are different. > > > > Removing the load improves the risetime and I get ~3v pk-pk. My scope > > has a 200MHz b/w & I've looked at a 70MHz clock on another board & I'm > > seeing a nice clean squarewave so I'm happy that the scope isn't > > giving a false picture. It does seem that the XCLK pin is having a > > hard time driving the load. > > > > A brief look at chapter 9 of the datasheet states 10nsec for the > ports, not sure if that holds for XCLK but should be less. I don't > know your configuration but a look at the fosc section could indicate > that you are really pushing it with those 59MHz. If you are running at > 3.3V supply then 3Vpp isn't all that bad. Table 10 states that worst > case a port is 400mV off the respective rail at 4mA source resp. sink. > This indicates that the output devices should be 100ohms or less. Into > a 10pF load that would be about a couple nsec to swing well past the > opposite digital threshold (time constant of 1nsec). Considering that > whatever drives it internally isn't infinitely fast you might be > looking at 3nsec or more. This still does not explain your 8nsec rise > time. Something must be in the circuit that wants to hold it down. > > > > I've doubled checked the datasheet & the load input capacitance is > > 10pF max. The clock trace is on the top layer & is ~15mm long, 12mil > > wide with no vias. There is a groundplane on the next layer. > > > > 15mm is next to nothing, less than a pF depending on the prepreg > between plane and layer. So there should not be any worries there. > > > > Do you have any other suggestions ? > > > > I'd try the coax and divider trick to eliminate the scope probe > uncertainty. Changing the length of the ground made a difference as > you had seen. At 50MHz there should not be a ground clip at all, the > coax shield should tie into ground less than 5mm from where you want > to measure. I use a Philips FET probe for that which came with a large
> supply of custom solderable coax jacks. > > The datasheet is a bit skimpy and I could not link to a family spec > anywhere. The Philips web site is IMHO not a very efficient site. > > If you didn't do the layout yourself I'd take a hard look at the > Gerber plots. More than once have I seen leftover stubs where the > layouter wanted to go another route, decided otherwise and left a > piece of the old trace in there. The DRC won't squawk since it's not > connected to a third node but it adds capacitance. > > Regards, Joerg > > http://www.analogconsultants.com/ >
2006-04-04 by Joerg Schulze-Clewing
Hello Dave, > > I don't think the scope is influencing things significantly as I've > observed faster & better quality waveforms. However I'm keen to try > the coax connector & divider trick you described. I'm not 100% clear > of the configuration though. Could you talk me through the setup ? > There are several nice instruction sets on the web, like this more elaborate probe: http://www.emcesd.com/1ghzprob.htm I usually forego the resistor to GND and the caps since a well terminated coax provides a 50ohm load just by itself. This seems to be what Maxim described in one of their app notes: http://www.maxim-ic.com/appnotes.cfm/appnote_number/3699 The simplest "probe" would just contain one 450ohm SMT resistor, or 453ohms since that is the closest value you can find in the usual 1% category. It must be a low-inductance resistor which most of them are nowadays. When you solder that in series with the center conductor of a coax you have a 1:10 divider, assuming 50ohm coax which is properly terminated at the scope. Use a small SMT cap in series if you want to avoid any DC draw. Make it as neat as you can and as short as practical. Very important is a short connection to ground. Below 100MHz you can get away with 1/2". Then place a jar on the counter where people can "donate" a girl scout cookie or something delicious. Because everyone in the lab will want to borrow your new probe at some point. Regards, Joerg http://www.analogconsultants.com/
Joerg Thanks for info - I'll let you know how I get on Regards Dave > > Hello Dave, > > > > > I don't think the scope is influencing things significantly as I've > > observed faster & better quality waveforms. However I'm keen to try > > the coax connector & divider trick you described. I'm not 100% clear > > of the configuration though. Could you talk me through the setup ? > > > > There are several nice instruction sets on the web, like this more > elaborate probe: > http://www.emcesd.com/1ghzprob.htm > > I usually forego the resistor to GND and the caps since a well > terminated coax provides a 50ohm load just by itself. This seems to be > what Maxim described in one of their app notes: > http://www.maxim-ic.com/appnotes.cfm/appnote_number/3699 > > The simplest "probe" would just contain one 450ohm SMT resistor, or > 453ohms since that is the closest value you can find in the usual 1% > category. It must be a low-inductance resistor which most of them are > nowadays. When you solder that in series with the center conductor of > a coax you have a 1:10 divider, assuming 50ohm coax which is properly > terminated at the scope. Use a small SMT cap in series if you want to > avoid any DC draw. Make it as neat as you can and as short as practical. > > Very important is a short connection to ground. Below 100MHz you can > get away with 1/2". > > Then place a jar on the counter where people can "donate" a girl scout
> cookie or something delicious. Because everyone in the lab will want > to borrow your new probe at some point. > > Regards, Joerg > > http://www.analogconsultants.com/ >
