Sten,
Thanks for the link to the #14601 discussion.
So it looks like my functions...
//exception handling functions
void IRQ_Routine (void) {while (1) ;}
void FIQ_Routine (void) {while (1) ;}
void SWI_Routine (void) {while (1) ;}
void UNDEF_Routine (void) {while (1) ;}
.... as seen above will operate quite happily so long as I do not
call any sub routines from them, I think I can live with that!!
Spurious ints..
To handle the spurious ints I will simply load up the VicDefVectAddr
reg with a benign function address that will simply allow a spurious
int to go some where and return back to the main code. The function
feed into the VivDefVectAddr reg will the defined using the
attribute_(interrupt) compiler command.
These Arm machine + the Gcc enviroment are quite a bit to get a handle
on :).
I also found this link which is sort of related to the #14601 on how
ints are handled, discussion # 9721.
Thanks for you time and efforts in replying.
Grant
NZ
It looks like I will opt to not call any other function inside my
"IRQ","SWI" attributed interrupts and leave my vectored interrupts
with "interrupt" attributed interrupt to do my busy subroutine calls.
--- In lpc2000@yahoogroups.com, Sten <list@...> wrote:
> gtechnzltd wrote:
> > Hi there,
> > Any advice on exception handling. Do you think this is the best
> > using the GCC tools.
> > 1: Define the exception handles and functions in main, EG:
> > //prototype exception handling functions
> > void IRQ_Routine (void) __attribute__ ((interrupt("IRQ")));
> > void FIQ_Routine (void) __attribute__ ((interrupt("FIQ")));
> > void SWI_Routine (void) __attribute__ ((interrupt("SWI")));
> > void UNDEF_Routine (void) __attribute__ ((interrupt("UNDEF")));
> > 2: In the start up file define the vectors to the functions in
main EG:
> > Undef_Addr: .word UNDEF_Routine /* defined in main.c */
> > SWI_Addr: .word SWI_Routine /* defined in main.c */
> > PAbt_Addr: .word UNDEF_Routine /* defined in main.c */
> > DAbt_Addr: .word UNDEF_Routine /* defined in main.c */
> > IRQ_Addr: .word IRQ_Routine /* defined in main.c */
> > FIQ_Addr: .word FIQ_Routine /* defined in main.c */
> > Is this all there is to exception handling?
> > Comments welcome.
> > Regards
> > Grant
> > NZ
> Hello,
> one week ago we had a discussion about correct code generation using
gcc in conjunction with
> __attribute__((interrupt("IRQ"))). See message #14601.
> I explored that if you do not call any other functions from an ISR
gcc (4.0.1, 4.1.0) produces
> correct entry/exit code. Otherwise you can get a lot of trouble. In
this thread there are someShow quoted textHide quoted text
> different solutions to avoid it.
> Sten
> Do you need a tiny and efficient real time
> operating system (RTOS) with a preemtive
> multitasking for LPC2000 or AT91SAM7?
> http://nanortos.net-attack.de/
> Or some open-source tools and code for LPC2000?
> http://www.net-attack.de/
