Hello,
Lat time I tried to use LPC with CAN. I found out a major issue with
extended frames.
Is this going to be fixed anytime soon?
I tried to do what the errata suggested and realized that the work
around is useless in a real world application. Unless I am missing
something here.
Anyone knows anything about this?
Gus
Have you looked at the errata sheet for CAN?
You can only use one transmit buffer.
The big one is the loosing arbitration when sending a message will
corrupt the data. I tried to use the work around mentioned by the
errata then I realized this will render the module useless for real
life application
We have a major project going but using 4 x CAN is a must and these
bugs must be fixed or we will have to move on to something else.
Gus
with
> > extended frames.
> Refresh my memory, what major issue?
> Joel
> life application
Yes I'm familiar with the errata sheet. My point being there is nothing in
particular about extended frames.
Joel
Hi all,
Are all the LPC2xxx chips affected bu these CAN issues ?
Thanks
> > life application
nothing in
