1x PLL or turn it off?
2006-04-04 by unity0724
Some opinions needed: If I'm running CPU clock at 18MHz with an external 18MHz crystal, which is more reliable (over full temperature/voltage range): - Switch off the PLL (clock source from external crystal/OSC) - Turn on 1x PLL (Clock source from PLL VCO/CCO) Regards
2006-04-04 by Robert Adsett
At 01:12 AM 4/4/2006 +0000, unity0724 wrote: >Some opinions needed: >If I'm running CPU clock at 18MHz with an external 18MHz crystal, >which is more reliable (over full temperature/voltage range): >- Switch off the PLL (clock source from external crystal/OSC) >- Turn on 1x PLL (Clock source from PLL VCO/CCO) The PLL almost certainly can't be more reliable than the oscillator since it uses the oscillator as an input. I'd just use the oscillator and leave the PLL off. You do gain in having a simpler circuit and marginally simpler software but I doubt it makes a great deal of difference in reliability. More noticeable would be a reduction in power requirements and perhaps EMI. On the other hand unless there is a real difference in reliability why bother with the PLL Robert " 'Freedom' has no meaning of itself. There are always restrictions, be they legal, genetic, or physical. If you don't believe me, try to chew a radio signal. " -- Kelvin Throop, III http://www.aeolusdevelopment.com/
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@...> wrote: > > At 01:12 AM 4/4/2006 +0000, unity0724 wrote: > >Some opinions needed: > >If I'm running CPU clock at 18MHz with an external 18MHz crystal, > >which is more reliable (over full temperature/voltage range): > >- Switch off the PLL (clock source from external crystal/OSC) > >- Turn on 1x PLL (Clock source from PLL VCO/CCO) > > The PLL almost certainly can't be more reliable than the > oscillator since it uses the oscillator as an input. I'd just > use the oscillator and leave the PLL off. You do gain in > having a simpler circuit and marginally simpler software > but I doubt it makes a great deal of difference in > reliability. More noticeable would be a reduction in power > requirements and perhaps EMI. > > On the other hand unless there is a real difference in > reliability why bother with the PLL > > Robert > Umm... Somehow I thought of PLL/VCO with low pass filter might: - Reject any noise, glitch, short pulses on the oscillator (e.g., there might be a surge/lightning nearby affecting the OSC, but not the PLL) - PLL/VCO gives 50% duty cycle clock to CPU Any idea which clock source is more stable?? Regards
