Lpc2000
Do not over-feed the Watchdog (?)
2006-04-03 by Danish Ali
Can someone point me to a definitive / application reference for the Watchdog
circuit used in the LPC2xxx - )one that is better than the user manual for
LPC2292)
I recently started trying to use the watchdog in the LPC2292.
Knowing no better, I decided to feed the watchdog once every time
I went round my event loop. I was careful to disable* interrupts before
writing 0xAA and 0x55 to WDFEED, and then re-enable the interrupts
afterwards. But I could not get the watchdog to behave - it would cause
interrupts no matter what (long) duration I set for the period (for
debugging I did not enable the reset, and I placed a
breakpoint in a Watchdog interrupt routine).
Typical periods I tried were around 1 to 10 seconds, with the PCLK at
60 MHz.
*using the macros provided in Crossworks. Note also that my spurious
interrupt routine merely writes to VICVectAddr and returns.
But if I placed a breakpoint in my event loop, and (from the debugger)
said "continue" before the watchdog timed out, the watchdog would not
interrupt.
My main event loop is pretty tight - it mostly looks to see if data have
arrived in buffers (put there by peripheral interrupt-service-routines).
Only when enough data are available will time-consuming calculations
be performed.
Seeing that the system did work if I placed a manual delay between
watchdog feeds, I tried only feeding the watchdog once every keyboard
scan (polled from a timer flag in the event loop, no faster than once
every ten milliseconds). This seemed to work fine, and continues to
work now I have enabled the watchdog reset.
And the watchdog does cause a reset if I deliberately enter an endless
loop.
Does this fit with the experience of others?
What constitutes over-feeding of the watchdog? Is it documented anywhere?
(It is possible that I do not understand what is going on).
I invite comments.
Danish
Re: [lpc2000] Do not over-feed the Watchdog (?)
2006-04-04 by Tom Walsh
That is suspicious!  I would look very carefully at the assembly
language being generated by the compiler to ensure what I said in C
actually is being done in assembler (opcode level).  Never assume.
TomW
Re: Do not over-feed the Watchdog (?)
2006-04-04 by Danish Ali
Hi Tom,
Good point, particularly as I hadn't included any source code
let alone the resulting assembly code.
When you view my watchdog feed routine, note that I do not
have anything set up to cause a FIQ. (I have not yet decided
which of my interrupt routines should be fast).
I don't have the hardware to hand (it is on its way back from
a trade show in Germany) where the system seemed to work. But
I had nothing hanging off the diagnostics port so I don't
know that for sure.
Danish
The C source code is:
void Watchdog_Feed(void) {
/* This code DOES NOT WORK if FIQ is used */
/* read IRQ status. If it is enabled, disable it
   feed watchdog
   restore IRQ status */
	int irqStat;
	asm volatile (
		" mrs r0, cpsr\n"
		" mov %0,r0\n" : "=r" (irqStat) : : "r0" );
/* bit 7 of cpsr is set to disable IRQ */
	if (128 & ~irqStat)
		__ARMLIB_disableIRQ();
	asm volatile (
		"WDFEED = 0xE0000008\n"
		" LDR r0, =WDFEED\n"
		" MOV r1,#0xAA\n"
		" MOV r2,#0x55\n"
		" STRB r1,[r0]\n"
		" STRB r2,[r0]\n" : : : "r0", "r1", "r2");
	if (128 & ~irqStat)
		__ARMLIB_enableIRQ();
with the crossworks IRQ enable and disable routines being:
  <__ARMLIB_enableIRQ>:
   	E92D0001   stmfd sp!, {r0}
   	E10F0000   mrs r0, cpsr
   	E3C00080   bic r0, r0, #0x00000080
   	E12FF000   msr cpsr_cxsf, r0
   	E8BD0001   ldmfd sp!, {r0}
   	E12FFF1E   bx lr
  <__ARMLIB_disableIRQ>:
   	E3800080   orr r0, r0, #0x00000080
   	E12FFF1E   bx lr
The full disassembly of Watchdog_Feed is:
   	E1A0C00D   mov r12, sp
   	E92DD800   stmfd sp!, {r11-r12, lr-pc}
   	E24CB004   sub r11, r12, #0x00000004
   	E24DD004   sub sp, sp, #0x00000004
	int irqStat;
	asm volatile (
   	E1A03000   mov r3, r0
   	E50B3010   str r3, [r11, #-16]
		" mrs r0, cpsr\n"
	if (128 & ~irqStat)
   	E51B3010   ldr r3, [r11, #-16]
   	E1E03003   mvn r3, r3
   	E2033080   and r3, r3, #0x00000080
   	E3530000   cmp r3, #0x00000000
   	0A000000   beq 0x000033E8
   	EB001A7D   bl 0x00009DE0 <__ARMLIB_disableIRQ>
	asm volatile (
   	E3A0028E   mov r0, #0xE0000008
   	E3A010AA   mov r1, #0x000000AA
   	E3A02055   mov r2, #0x00000055
   	E5C01000   strb r1, [r0]
   	E5C02000   strb r2, [r0]
		" MOV r1,#0xAA\n"
		" MOV r2,#0x55\n"
		" STRB r1,[r0]\n"
	if (128 & ~irqStat)
   	E1E03003   mvn r3, r3
   	0A000000   beq 0x00003414
   	EB001A6C   bl 0x00009DC8 <__ARMLIB_enableIRQ>
   	E24BD00C   sub sp, r11, #0x0000000C
   	E89D6800   ldmfd sp, {r11, sp-lr}
   	E12FFF1E   bx lr
