Lpc2000
Couple of newbie questions (LPC2294)
2006-04-04 by flocheckv10
I recently bought the IAR kickstart kit for LPC2294 (came with a
phytec board, PCM023 header + HD200). I hope someone can help me
answer these questions..
1.
When I try the philips LPC2000 flash utility I get the error "can't
communicate with target board". There are two buttons on the HD200
board, one reset and one boot. Isn't it correct that I can force the
chip in ISP mode by pressing both and releasing in the order reset,
boot? I have tried various communication speeds (still there is auto
baud detection so shouldn't matter) and different serial cables, but
the problem remains.
2.
With the kickstart kit I got this J-link debugger. With this one I
can start a debug session in internal flash/ram. My question here is
about the program signature. Do I have to add it myself or does the
J-link do that for me? The reason I ask it that if I stop the debug
session and recycle the power to the board my program is not
running. Tried with the Blinky sample app (simple LED flashing
program).
3.
When it comes to external flash (4Mb mounted on the PCM023). Lets
assume I want to program this with a serial cable from a stationary
computer. As I understand it right now I have to write my own
flashloader that must be uploaded to internal flash/internal RAM
first (by the LPC2000 flash utility for example). Then I can
communicate with this new flash loader with some other serial
program to write external flash.
4.
What is the correct output file format from IAR for the LPC2000
flash utility. I have tried project->options->linker->output format
to "intel-extended" and format variant "none" and in output file I
have override default checked and changed the name to .hex. Since
the flash utility does not work (see question 1) I can't say if this
format will work, will it?
Thanks
/noob
