Lpc2000
Makefile help?
Makefile help?
2006-04-06 by volunteer_sysu
I am quite new to LPC2000. When I was trying to building up a
program, I encountered some problems. Would you please do me a
favour, thank you very much!
The problem is some errors occurred when I made the Makefile. The
errors are as follows.
$ make
arm-linux-gcc -arm-32-msoft-float-mno-fpu -c -o startup.o startup.S
startup.S: Assembler messages:
startup.S:69: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:72: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:75: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:78: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:81: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:84: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:119: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:120: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:128: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
startup.S:129: Error: internal_relocation (type: OFFSET_IMM) not
fixed up
make: *** [startup.o] Error 1
And codes where errors occurred are as follows.
StackInit:
	mov	r0, lr
/* build the SVC stack */
	msr	cpsr_c, #0xd3
	ldr	sp, _svc_stack
/* build the IRQ stack */
	msr	cpsr_c, #0xd2
	ldr	sp, _irp_stack
/* build the FIQ stack */
	msr	cpsr_c, #0xd1
	ldr	sp, _fiq_stack
/* build the ABT stack */
	msr	cpsr_c, #0xd7
	ldr	sp, _abort_stack
/* build the UND stack */
	msr	cpsr_c, #0xdb
	ldr	sp, _undefined_stack
/* build the SYS stack */
	msr	cpsr_c, #0xdf
	ldr	sp, _usr_stack
/* return back */
	mov 	pc, r0
I did defined the variables: _svc_stack, _irq_stack, ..., in the
link file and allocated them to a specific address by using such an
expression: _svc_stack=.; ,what's wrong? Help! Thanks again for your
attention.
Best regards,
Kevin
Re: Makefile help?
Sorry, there are some simple mistakes.
The reason why all these errors occurred is an "=" missing in the
instructions.
ldr sp, _svc_stack
it should be:
ldr sp, =_svc_stack
Kevin
--- In lpc2000@yahoogroups.com, "volunteer_sysu" <volunteer01@...>
> $ make
> fixed up
> fixed up
> fixed up
> fixed up
> fixed up
> fixed up
> fixed up
> fixed up
> fixed up
> fixed up
> StackInit:
> 	mov	r0, lr
> 	msr	cpsr_c, #0xd3
> 	ldr	sp, _svc_stack
> 	msr	cpsr_c, #0xd2
> 	ldr	sp, _irp_stack
> 	msr	cpsr_c, #0xd1
> 	ldr	sp, _fiq_stack
> 	msr	cpsr_c, #0xd7
> 	msr	cpsr_c, #0xdb
> 	msr	cpsr_c, #0xdf
> 	ldr	sp, _usr_stack
> /* return back */
> 	mov 	pc, r0
an
your
> attention.
> Best regards,
> Kevin
