Lpc2000
Example of C and inline ASM in a file?
2006-04-07 by ah_sandiego
Can someone post a simple example of C and inline ASM in a single
file. I use the LPC2148 but any LPC board example would be helpful.
AH
Re: Example of C and inline ASM in a file?
2006-04-07 by Danish Ali
Hi AH,
You don't mention which C compiler you use. This makes
a big difference to how you include inline assembly code.
Attached is an example of something that gcc likes (as
supplied with Rowley Crossworks).
Key points:
volatile should discourage the compiler from re-ordering
and optimising the assembly away. But so fat I have not
turned on the optimiser.
C merges the assembly code into a single line, so you must
supply the "\n" to separate assembly instructions.
The subroutine relies on the fact that FIQ does not (yet)
occur in my system.
I do not fully understand the information you should put
in the : : : sections.
The first couple of lines of assembly code pass a value from
assembly to C, using the %0 and the "=r" (irqstat) phrases.
The last part is registers you use (warning the compiler not
to rely on values in those registers remaining constant).
void Watchdog_Feed(void) { /* NOT fiq safe! */
	int irqStat;
	asm volatile (
		" mrs r0, cpsr\n"
		" mov %0,r0\n" : "=r" (irqStat) : : "r0" );
	if (128 & ~irqStat)
		__ARMLIB_disableIRQ();
	asm volatile (
		"WDFEED = 0xE0000008\n"
		" LDR r0, =WDFEED\n"
		" MOV r1,#0xAA\n"
		" MOV r2,#0x55\n"
		" STRB r1,[r0]\n"
		" STRB r2,[r0]\n" : : : "r0", "r1", "r2");
	if (128 & ~irqStat)
		__ARMLIB_enableIRQ();
Hope this helps,
Danish
> Thanks,
> AH
2006-04-07 by brendanmurphy37
In the long run, using in-line assembler is probably not a good idea.
It is very compiler specific, and you need to have a good
understanding of how the particular compiler interacts with the
assembler.
If you need to use assembler you can invariably do it in a separate
function, callable from 'C' (or the other way round where assembler
calls a 'C' function). Just make sure you stick to the ATPCS (ARM-
Thumb Procedure Call Standard), which is very simple for simple
functions, and you'll be OK (see ARM site for details on this).
You don't mention why you're using assembler: if it's for efficiency
reasons, try compiling with maximum optimisation first and taking a
look at the code produced.
Brendan
> Thanks,
> AH
2006-04-07 by ian.scanlon
> Thanks,
> AH
Depending on the compiler optimization levels, inline asm has minimal
benefit for size or speed.  Inline asm also limits portability for
hardware and compilers. Even if you think it will never be an issue...
What are you goals for this? A few bytes? A save a bit of time- 50ns?
100ns? Access to a hardware specific feature or registers? It will be
difficult to beat the compiler for speed and/or density.  The ARM was
designed for compilers and the compilers are very good at
optimization.
There are several good 'c' solutions but it really depends on what
you are doing. "Function Inlining" (check your compiler options) will
avoid the timer overhead of calling a function.
This is from the IAR C reference:
"Function inlining means that a simple function, whose definition is
known at compile time, is integrated into the body of its caller to
eliminate the overhead of the call. This optimization, which is
performed at optimization level High, normally reduces execution
time, but increases code size. The resulting code might also be
difficult to debug."
If it is execution speed you are after, time the C function with a
some io bit toggling either side of the call with an oscilloscope.
Then add up the execution time of your hand written instructions and
compare.*  Expect better results from the compiler code.
If it is size, compare the size of the C function in the map file
with the size of your hand written code.*
If it is access to the hardware, use the compiler extensions or
pragma.
*(both of these techniques introduce some inaccuracy but the results
will be close. Let's not start a debate on the finer points of
measurement)
~Ian
Re: [lpc2000] Re: Example of C and inline ASM in a file?
2006-04-07 by Robert Adsett
Quoting "ian.scanlon" <scanlon.design@...>:
>> Thanks,
>> AH
Indeed, I've yet to see a good reason to use inline assembler on any processor
and that's doubly true for the ARM.
Robert
Indeed! Which begs the question:
Can anyone put forward a good argument (and example) for the use of in-
line assembler for an ARM-based system?
Personally, I can't think of one.
Brendan
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@...>
processor
> Robert
2006-04-07 by rtstofer
OK, I'll bite!  I have used inline assembly in cc5x (sort of C for the
PIC) to control exactly the number of cycles in a delay routine.  No
active interrupts in this code.  I suppose it could be done in C but
that would change with compilers and optimization.
There are times...  Not many, perhaps, but they do exist.
Richard
2006-04-08 by jayasooriah
Hello AH.  Thanks for your very short and simple question:
If you wanted to branch to an address stored in a variable (pointer),
"addr" in arm or thumb mode as appropriate, you could use the
following statement:
>  asm volatile (" bx %0" : : "r" (addr));
The ":" syntax in ASM constructs is specific to GCC (AFAIK) and it is
used as a way of getting the instruction generator to do what you want
it to do. The following reference is a good start:
  http://www.ethernut.de/en/documents/arm-inline-asm.html
Hope this helps.
Jaya
2006-04-08 by Robert Adsett
An argument for assembly yes, but I don't see it as an argument for inline
assembly.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2006-04-09 by Boris Estudiez
> assembly.
> Robert
One advantage of inline assembly is that you don't have to worry
about of the calling convention used by the compiler (such as ATPCS
or APCS).
Boris Estudiez.-
Contacteme en:
* Mail(1): stk@...
* Mail(2): 43824@...
* Mail(3): slicetex@...
* Website: http://stk.freeshell.org
EOF
2006-04-09 by Stephen Pelc
> assembler on any processor and that's doubly true for the
> ARM.
When you need efficient access to ideas not supported by the
programming language. These are usually things like the state of
the Carry and Overflow flags. Using assembler rather than high
level kluges can improve performance by factors of 2..5,
depending on CPU.
A client of ours performs financial calculations using 128 bit
integers. The difference between their app and the competition's
floating point app for part of the Hong Kong airport
construction was US dollars 10,000,000. The on-screen
recalculation performance was important, so they coded the quad-
integer routines.
Stephen
Stephen Pelc, stephen@...
MicroProcessor Engineering Ltd - More Real, Less Time
133 Hill Lane, Southampton SO15 5AF, England
tel: +44 (0)23 8063 1441, fax: +44 (0)23 8033 9691
web: http://www.mpeforth.com - free VFX Forth downloads
2006-04-09 by Robert Adsett
> > ARM.
>depending on CPU.
>integer routines.
OK, but how is that an argument for making the assembler inline?  I do see
uses for assembler, I am just of the opinion, informed by my experiences,
that inline assembler causes more problems than it fixes.
Robert
> > assembly.
> > Robert
>or APCS).
An argument yes, but I don't think  a good one.  In the same time, or less,
that it takes to figure all the peculiarities of how inline interacts with
the main code (if indeed it's documented even close to properly) you can
learn the calling conventions of the compiler and do a 'proper' assembly
routine.  And the resulting code is a whole lot less fragile.
If you are serious about embedded work then at some point you have to learn
the calling conventions anyway so you've not saved any effort.
Robert
2006-04-09 by brendanmurphy37
Robert,
I agree completely. I'd much rather spend time figuring out the
calling conventions for a particular platform (which as you point
out, you need to know anyway) than learning some obscure syntax and
set of rules for some compiler-specific non-standard feature like in-
line assembler.
Until you're faced with it, it's too easy to ignore portability
issues. However, even a brief review of the problems people have
reported to this group over the past while will show how common
those issues are. In-line assembler, "__irq" and "__fiq" function
modifiers, bit-masks to access hardware registers, take your pick. I
think they're all best avoided.
To take another example given recently, I can easily imagine
implementing a set of math functions for 128-bit numbers in
assembler for efficiency reasons, and calling them from some
application. When you want to (or more likely are forced to) move to
a different target platform, all you have to do is re-code the small
number of lower-most level assembler functions, instead of re-
writing an entire application.
None of this is to say that any of these features don't or can't be
made work, and if it suits then fine. Just be aware that most of
them have more than their fair share of capacity to bite at some
stage down the line.
Finally, to the original questioner that started this thread I'd
recommend reading the relevant compiler's documentation for an
example, as it is typically compiler dependent on how it operates.
Brendan
C for the
routine.  No
in C but
argument for inline
> > > assembly.
> > > Robert
ATPCS
> >or APCS).
or less,
interacts with
you can
assembly
to learn
> Robert
restrictions,   be
chew a
2006-04-10 by jayasooriah
Dear Robert, let me address an advocacy issue here ...
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@...> wrote:
> I do see uses for assembler, I am just of the opinion, informed
> by my experiences, that inline assembler causes more problems
> than it fixes.
My experience tells me otherwise.  Inline assembler has its place just
like any other feature *provided* one understands how to use it before
one does.
If you can give us some examples of where it has caused more problems
than it fixed, I might be able to explain what I think went wrong.
The original question that started this thread was quite simple and
specific.  A couple responded to the point with examples.
It is interesting those who go on and on against inline assembly have
not come up with examples.  My guess is that these posters do not know
enough enough about inline assembly to use it effectively or to come
up with examples of their own.
Jaya
2006-04-10 by brendanmurphy37
Jaya,
I think your suggestion is misplaced: why would you think that
anyone pointing out the pitfalls of a particular feature doesn't
understand it?
Somone asked for an example of a feature, to which there were three
basic responses:
- Provide an example, as asked. This has the merit of answering the
direct question, but is of limited use otherwise
- Point out that the feature is compiler-specific, and it's best to
look up the particular compiler's documentation. Personally, I think
it is always more useful if someone looking for information is told
where to find it themselves rather than being spoon-fed the answer.
Hence, I'd suggest this is actually a more useful answer.
- Point out some of the pitfalls of the feature, the main one being
that it is a very non-standard, non-portable feature. This to my
mind is more useful again, as it puts forward people's experience
from which people can benefit, and provides information that is not
readily available elsewhere.
There's nothing inherently wrong with the feature, just that there
is usually (always?) a less error prone and simple way of achieving
the same result.
As for an example of the pitfalls, I gave one in my last post, based
on a suggested use of the feature from a previous poster (to
implement 128-bit numbers).
You don't have to take anyone's advice or learn from their
experience: there's noone forcing it on anyone. You certainly don't
have to use it as yet another opportunity to disparage other's hard-
one experience, insult their capabilities and promote yourself yet
again as the font of all knowledge.
Best wishes
Brendan
--- In lpc2000@yahoogroups.com, "jayasooriah" <jayasooriah@...>
> --- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@>
> > than it fixes.
just
before
> one does.
problems
have
know
come
> Jaya
2006-04-10 by Stephen Pelc
> From: Robert Adsett <subscriptions@...>
If I only needed a few instructions, and the register usage is
well documented, then inline assembler is less of a maintenance
nightmare than an external routine in another file.
Stephen
--- In lpc2000@yahoogroups.com, "brendanmurphy37" <brendan.murphy@...>
> understand it?
Your interpretation is misplaced.
I asked Robert for an example of inline assembler that "causes more
problems than it fixes".
If you have one, put it up for discussion.  If not, I have nothing
more to say to you.
Jaya
RE: [lpc2000] Re: Example of C and inline ASM in a file?
2006-04-10 by Paul Curtis
Jaya,
> "causes more problems than it fixes".
> nothing more to say to you.
You're acting like a spoilt child.
Something concrete:
void do_something_nasty(void)
  // I need to do something fast without a call, I need a register,
  // so I'll pick r5 as the/ code generator seems it's not using that
  // one when I run it under the debugger.
  asm("ldr r5, =0x12345678");
  // Now do soemthing with r5 because I did something above.
There is just so much wrong with the above it's untrue.  I'm happy to
say I've never used inline assemler.  If you need that crap, it's
because you have a toolset that doesn't have intrinsics for what you
want to do.
Paul Curtis, Rowley Associates Ltd   http://www.rowley.co.uk
CrossWorks for ARM, MSP430, AVR, MAXQ, and now Cortex-M3 processors
Jaya,
I've already provided an example of where it can cause problems:
If you have an application that makes extensive use of processing on
128-bit numbers using in-line assembler (as someone suggested) , what
happens when you want to port that application to another
environment? Bit of a problem, I think.
All I suggested for this case was to implement a few core functions
in assembler in a separate compilation unit (i.e. file) and re-code
that for the new environment. No need to touch the application itself.
Jaya, I'm well aware that others take a different view and have
different experiences to draw on and will come to different
conclusions about how to use particular features. All I'm and others
are doing is pointing out some potential pitfalls.
There's no need to be abusive about it!
Brendan
P.S. you might want to correct some of the factual errors in your own
writings on your Web site, before attacking others so aggressively.
--- In lpc2000@yahoogroups.com, "jayasooriah" <jayasooriah@...> wrote:
> --- In lpc2000@yahoogroups.com, "brendanmurphy37" <brendan.murphy@>
> > understand it?
> more to say to you.
> Jaya
Sorry I must have missed it becuase it was not clear.
> on 128-bit numbers using in-line assembler (as someone suggested),
> what happens when you want to port that application to another
Which environment are you switching to? What is the problem?
Examples of simple needs where inline assembly meets the requiremnt
well have been presented here.  If there is a problem, I like to know
what it is in specific terms.
Jaya
Jaya,
I fear I'm repeating myself: the problem isn't that in-line assembler
doesn't work, the problem is that it is completely non-standard and
non-portable.
If you insist on using it, when you move to a new platform you have
to re-write the application (as in the hypothetical example I
presented).
Better by far I think to follow the well-known technique of isolating
the platform-specific parts (i.e. the assembler) into a small
separate compilation unit (i.e. assembler source file), and providing
different versions of that file for different platforms. In other
words, rather than mixing portable with non-portable code (as in-line
assembler does), separate it out.
Now if you believe portablility between environments isn't an issue
for you, I suggest you read back over some recent posts to see the
difficulties encountered by those attempting to port code to ARM when
non-portable features have been used. I'm sure the authors would have
said when the code was 1st produced "I doin't have to worry about
portablility".
I really can't think of another way of saying this, though I could
supply a real example if you or anyone else is really interested.
Brendan
know
> Jaya
I will ignore this comment knowing you for what you are :)
> Something concrete:
Excellent example of INCORRECT use of inline assembly.
You want to use "r5" for your own purpose but have chosen not to tell
the compiler.  You appear not to know, or to have forgotten, that the
compiler is responsible for allocation of registers.
Although I question the validity your particular requirement (as I can
gather from your comments), the compiler nonetheless will accodomate
your requirement (subject to reasonable limits) if you were to include
the following declaraction in your function:
> register int r5 asm ("r5");
If you do not tell the compiler you are using a register that it also
uses, you should not be surprised at what happens as a result.
While the reference to "r5" in the ASM statement may be obvious to you
as a human, the compiler does not parse this string at all.
Jaya
Jaya,
We all have opinions about each other here.  You don't know what I am,
I've never met you, so how you know what I am is just more supposition
on your part, just like your CRP "facts".
> > Something concrete:
> using that
Yes, of course it is incorrect, that's the whole f'ing point.
> to tell the compiler.  You appear not to know, or to have
> forgotten, that the compiler is responsible for allocation of
> registers.
Too bloody true.  The whole point is that customers write this shit and
don't have a clue.  It might work when debugging, but it won't work when
you turn the optimizer on.  And it won't work when you change the
function.
> (as I can gather from your comments), the compiler
> nonetheless will accodomate your requirement (subject to
> reasonable limits) if you were to include the following
> it also uses, you should not be surprised at what happens as a result.
> obvious to you as a human, the compiler does not parse this
> string at all.
Yawn.  I know all this.  This is an example of stuff customers will
write.  The point is that customers write this crap without knowing what
they're doing.  It's not enough that they can screw themselves with
non-portable C, now inline assembler has given them yet another
dimension to screw around and "solve" problems with.  The problems, of
course, come when somebody has to maintain it, move it to a new
compiler, or even move to a new architecture as has been pointed out.
In short, I have never used inline assembler and I see no reason to
start using it.  Our own compilers do not offer this feature and with
the wealth of customers we have, each time they ask for it I show them
why they don't need it.
I appreciate the need to use inline assembly features of GCC in
embedded systems especially.  I find them very handy to meet that odd
requirement that takes a lot of contortion to do otherwise.
The benefit I find in using inline assembly for such reasons is that
not only does it avoid having open up the interface (by creating an
external call), but also makes the code more readable, and in many
cases also compact and efficient.
Jaya
Jaya,
I have to say, you're a great source of amusement and entertainment!
Someone presents an example of incorrect usage, and you go to great
lengths to show how incorrect it is! Doh!
I haven't enjoyed myself so much since reading about your "surprise"
interrupts. Based as they are on a complete misunderstanding of how
ARM's handle interrupts, it's no wonder you were surprised.....
Keep up the good work!
Brendan
> > Something concrete:
register,
that
tell
can
include
also
you
> Jaya
> From: "brendanmurphy37" <brendan.murphy@...>
> non-portable.
Especially in embedded work, device drivers aren't portable
whatever they are written in.
> presented).
That's a consequence of working in C/C++. Other languages handle
things differently.
When I look at where MPE (as opposed to its clients) uses in-
line assembly, we find it in device-specific drivers, e.g. UART
and Ethernet drivers, and in CPU specific sections, e.g.
schedulers, where we are striving for performance. In our world,
interrupt latency and task-switching speed really matter,
regardless of CPU performance - the faster the CPU, the more we
are asked to do with it.
Paul's comment about intrinsics is relevant, but I would really
hate to have to guarantee that a client won't find another
useful one that we haven't already provided. Today I had a tech-
support conversation about bank-switched RAM ... he had found
another way of perverting the hardware/software trade-offs in
our standard libraries.
In-line assembler isn't evil, you just have to be able to make a
good case for it, and that case has to include maintenance and
portability.
Stephen
Stephen,
I don't necessarily agree with all you say, but I like your sensible
conclusion, that hopefully everyone can agree on:
> portability.
> Stephen
By the way, why is that that some people feel the need to inisist
their own view is 100% correct and nobody's else views, experience or
opinion matters? I find I learn something from most contributors
here, even if I don't agree with their conclusions.
Brendan
Brendan
Please refrain from disrupting the thread with such digressions.
If you do not like my characterisation of interrupts and feel you must
say something, raise it as a separate thread.  If I see a question
that has not already been answered I usually respond.
Jaya
wrote:
> Jaya,
> Brendan
Jaya,
Sorry - I'll ask for permission next time, before making any
comments. I'd hate to upset you.
My comment was made in passing and in jest.
If you're interested in where your misunderstanding of ARM interrupts
arises, you can let me know in a separate thread.
Brendan
> Brendan
must
> Jaya
> wrote:
> > Jaya,
entertainment!
great
your "surprise"
how
> > Brendan
2006-04-10 by Michael Rubitschka
Guys
Make code not war!          ;-)
Cheers
Michael
>Reply-To: lpc2000@yahoogroups.com
>Subject: [lpc2000] Re: Example of C and inline ASM in a file?
>Date: Mon, 10 Apr 2006 14:52:08 -0000
>Jaya,
>Brendan
> > Brendan
>must
> > Jaya
> > wrote:
> > > Jaya,
>entertainment!
>great
>your "surprise"
>how
> > > Brendan
Michael,
Your right, of course.
In my defence, I find it hard not to respond to the ongoing insults
and abusive comments from certain quarters.
I'll stop now, though: genuine apologies all round.
Brendan
--- In lpc2000@yahoogroups.com, "Michael Rubitschka" <rubitschka@...>
wrote:
> Guys
> Cheers
> Michael
2006-04-10 by Steve Franks
At risk of being flamed myself, there are at least 3 people on this list who
consistently contribute a significant amount of technical info, along with a
singificant amount of unpleasant philosophy.  I can see that they all desire
to make a contribution, and all hold valid points at times.  Each at times
asserts things that are either not well thought out or reseached at times,
just like the rest of us.  Each has made comments that I respect and have
increased my understanding of the Arm/Lpc.  Please keep that in mind when
assaulting eachother, guys.  You all start out on the defensive because this
has been going on too long.  Please do not make the mistake of my home
government (not to confused with my home people) and assert that increased
violence will somehow secure peace.  ~Steve
This is an add-on to Danish Ali's contribution to AH's original question.
I hope it will show how one can use GCC's inline assembly features in
an effective way to produce code that is both readable *and* efficient.
I am not sure if I could have handcrafted the assembler code to be
that efficient, considering the three primitives I created in the
header file are not specific to the WATCHDOG or the LPC.
Sorry it is longish but striking a balance between being brief and
clear is not always easy considering the nature of this audience.
Enjoy!
Jaya
PS:  All you need to know about inline assembly for purposes of
understanding this tutorial can be found at:
I am happy to explain finer points if anyone wants to know more.
> 	int irqStat;
> 	asm volatile (
> 		" mrs r0, cpsr\n"
> 	if (128 & ~irqStat)
> 	asm volatile (
> 		" MOV r1,#0xAA\n"
> 		" MOV r2,#0x55\n"
> 		" STRB r1,[r0]\n"
> 	if (128 & ~irqStat)
I wrote a header file, foo.h with three primitives to do what the
above code does.  This is included at the end of this post E&OE.
I wrote foo.c which includes foo.h (and other header files), and in
which I invoked the equivalent of the Watchdog_Feed() function as follows:
>  feedSeq(&WATCHDOG);
I used GCC to generate the optimised assembler source file as follows:
> arm-esdk-gcc -Wall -Werror -O3 -S foo.c
The assembler output for the feedSeq() call I got is as follows
(comments added)
> 	mov	r0, #128		@ 0x80 (IRQ BIT)
> 	mov	lr, #-536870912		@ 0xe0000000 (&WATCHDOG)
> 	mrs	ip, cpsr		@ save copy of CPSR
> 	orr	r0, r0, ip		@ set IRQ bit in temp
> 	msr	cpsr, r0		@ disable interrupts
> 	mov	r0, #170		@ 0xAA (feed byte #1)
> 	mov	r3, #85			@ 0x55 (feed byte #2)
> 	str	r0, [lr, #0]		@ WATCHDOG FEED #1
> 	str	r3, [lr, #0]		@ WATCHDOG FEED #2
> 	msr	cpsr, ip		@ restore interrupts
The header file where I make use of inline functions and inline
assembly to achieve the above result follows.  Note that I do not
refer to any register by name, but let the compiler tell me what
register to use.
The name of the game here is not to override the compiler with your
choices, but to tell the compiler (in the nicest way possible) what
you want it to do for you ... to produce the code shown above.
> // 'irqMask'
> // mask either irq or fiq bit
> inline int
> irqMask(mask)
> 	int mode;
> 	// set mask bit
> 	asm volatile
> 		"mrs\t%0, cpsr"		"\n\t"
> 		"orr\t%1, %1, %0"	"\n\t"
> 		"msr\tcpsr, %1"
> 		: "=&r" (mode)
> 		: "r" (mask)
> 	// previous mode
> 	return (mode);
> } // irqMask()
> // End of 'irqMask'
> // 'irqMode'
> // restore mode and irq bits
> inline void
> irqMode(int mode)
> 	// restore CPSR
> 	asm volatile ("msr\tcpsr, %0" : : "r" (mode));
> } // irqMode()
> // End of 'irqMode'
> // 'feedSeq'
> // atomic feed sequence
> inline void
> feedSeq(int *loc)
> 	int mode;
> 	// enter critical section
> 	mode = irqMask(IRQ_BIT);
> 	asm volatile
> 		"str\t%1, [%0, #0]"	"\n\t"
> 		"str\t%2, [%0, #0]"
> 		: "r" (loc), "r" (0xaa), "r" (0x55)
> 		: "r1", "r2"
> 	// leave critical section
> 	irqMode(mode);
> } // feedSeq()
> // End of 'feedSeq'
Sorry for typo error in my tutorial. Pleae replace WATCHDOG with
WDFEED.  E&OE comes in handy at times like this :)
question.
> Enjoy!
> Jaya
> > 	int irqStat;
> > 	asm volatile (
> > 		" mrs r0, cpsr\n"
> > 	if (128 & ~irqStat)
> > 	asm volatile (
> > 		" MOV r1,#0xAA\n"
> > 		" MOV r2,#0x55\n"
> > 		" STRB r1,[r0]\n"
> > 	if (128 & ~irqStat)
follows:
> >  feedSeq(&WATCHDOG);
> (comments added)
> register to use.
> > // 'irqMask'
> > inline int
> > irqMask(mask)
> > 	int mode;
> > 	// set mask bit
> > 	asm volatile
> > 		"msr\tcpsr, %1"
> > 		: "=&r" (mode)
> > 		: "r" (mask)
> > 	// previous mode
> > 	return (mode);
> > } // irqMask()
> > // End of 'irqMask'
> > // 'irqMode'
> > inline void
> > irqMode(int mode)
> > 	// restore CPSR
> > } // irqMode()
> > // End of 'irqMode'
> > // 'feedSeq'
> > inline void
> > feedSeq(int *loc)
> > 	int mode;
> > 	asm volatile
> > 		"str\t%2, [%0, #0]"
> > 		: "r1", "r2"
> > 	irqMode(mode);
> > } // feedSeq()
> > // End of 'feedSeq'
Jaya,
In the interests of following your lead and sticking to positive
rather than negative contributions, some may find the following
example useful too.
It is actually a very similar example, based on a `C' API used by an
RTOS I was involved in a while ago.
The ARM implementation is as follows:
 * Disable/Restore interrupt processing
 *  Use as:
 *    int disabled = HwIntrDisable();
 *      /* Critical section that needs interrupts OFF */
 *    HwIntrRestore(disabled);
HwIntrDisable:
  mrs   r1, cpsr    /* get CPSR into work register */
  mov   r0, r1      /* return copy of original CPSR to caller */
  orr   r1, r1, #0x80
  msr   cpsr_c, r1  /* update CPSR with I=1 */
  bx    lr          /* return to caller */
HwIntrRestore:
  msr   cpsr_c, r0  /* update CPSR with value supplied by caller */
You'll notice they can be called from Thumb mode as well.
There are versions for NEC NV850, MIPS and (used for development,
debug and test) Win32 (the Win32 version is coded in `C' and uses
critical sections).
The main-body of the RTOS itself is 100% ANSI `C' and just needs a
compile to get it up on a new platform, once the functions above and
any other assembler has been written (about 10-50 lines, depending
on platform). Although this portability is useful, the biggest win
we found with this approach was the speed of development and ease of
maintenance. Basically, our experience is that separating out
portable from non-portable code will generally simplify ongoing
maintenance and support. This helps guarentee high-quality software
which we regard as being far more important than saving one ot two
cycles where it won't be noticed in any case.
Brendan
question.
in
efficient.
2006-04-11 by Robert Adsett
There. I think, we will just have to disagree.  I've found the reverse to
be true in my experience.
Robert
2006-04-11 by Bruce Paterson
> make a good case for it, and that case has to include
> maintenance and portability.
I'll agree with this conclusion.
In most embedded applications I avoid it for two reasons:
1) Portability issues. I often find myself re-using code again on
another project/environment, even if I didn't expect to initially.
2) Learning curve. Inline assembler means you have to learn the syntax,
probably study up on how to reserve the registers you need or find out
what the compiler doesn't use. If it doesn't use it, you need to then be
careful that your own interrupt routines are saving all the context they
have to (especially if you use inline in them too). All in all, there
are certainly more chances to stuff up with inline unless you've gone
into it properly.
That said, I have had application where inline was very handy.
It was a gcc C compiler for a motorola DSP. The DSP assembler allowed
many instructions in the one line, and the inline syntax was powerful
enough to support this. The C compiler itself rarely generated code that
was that smart. If a time critical task was big enough you were better
off using an assembler subroutine (but for this also you have to be
aware of the C compiler calling and return methods and what has to be
saved). For simple things the inline was very useful (eg. Divide by a
constant was one I remember using where it was more efficient to
multiply by the reciprical of the constant fractionally). I wrote a
fixed-point complex number library that was a mixture of C, inline and
assembly routines.
The efficiency argument only really applies where the routine calling
overhead is large compared to the task your assembly is performing.
Interestingly this library was ported....by rewriting entirely in C with
no regard for efficiency. We wanted to test all the higher level
algorithms on the PC where it was much easier to develop at the time
than on the DSP.
So, there is a case for inline in some specific applications, where the
case can be made. Even when it can, try to isolate the inline into one
easily replaceable library which you can unplug. There is no
justifcation for inline assembly in main.c !   It all comes down to how
you design your project from the start.
Bruce
> > non-portable.
Portability, is about items other than porting code.  It's also about the
portability of knowledge and skill.  It's about the portability of tools
(editors, analyzers, generators etc..).  In this particular case it's also
about limiting the egregious growth of languages (from 2 [C, ASM] to 3 {C,
ASM and inline ASM]) :)
Why not do them in assembly rather than inline?  I don't expect either of
us to change the others mind but I am curious as to the reasoning.
Robert
> > than it fixes.
>one does.
Apparently we have experienced different projects and tools.
I have never used a compiler seriously and not had it break at some point
on me.  The only exception so far is GCC.  The most common point of
failure, by far, are the architecture specific extensions.  Interrupt
keywords, inline assembly, memory placement modifiers etc...  Curiously,
the second most common failure point seems to be switch statements.
Problem 1:  Nearly all implementations suffer from a lack of
documentation.  One case in particular I remember the documentation boiling
down to more or less "the inline asm syntax is  asm assembly
instruction;"  Needless to say, I didn't even attempt that one.
Problem 2: Incompatible C syntax The form above is obviously not
compatible, so is the form
         #asm
         #endasm
They both cause problems with tools and reuse.  Tools are generally the
bigger issue.
Problem 3: optimization. If the assembly is just inserted in the middle of
the generated code before being passed to the backend it is sometimes
optimized away.
Problem 4: Register reappropriation.  Not a good term but it will do.  The
compiler documents the calling convention but when using inline even at the
beginning of the function the compiler appropriates the register for other
temporary uses first so you can never be sure that you will get what you
were expecting when you originally wrote it.
That being said I have run across compilers that only allowed inline (they
had no separate assembler)  In both cases though the compilers resembled C
in much the same way Java  does so the solution in both cases was really to
get a proper tool chain.
I have used multiple compilers on multiple architectures and experience has
taught me to approach architecture specific extensions with caution and if
their are clear simple alternatives as there are for interrupts and
assembler avoid them all together.    I'd rather not spend my time
debugging the compiler if I can avoid it.
Robert
2006-04-11 by Eric Engler
That's true with me, too. The few times I get involved with low-level
issues not already handled by libraries I need to spend a lot of hours
with irritating registers, processor modes and the like. Frankly,
these types of things make me employable, so I shouldn't complain too
much!
But I have never used any inline assember except for the code
recommended by compiler vendors (which used to happen more than it
does now - libs weren't well developed back then). I always prefer to
isolate my asm code in separate modules with well-defined API's, and
then I link them to C programs.
I also use asm for things that need to be kept secret, like licensing
support code, and the like. It's much harder to disassemble hand-coded
assembly routines than compiled C code, especially if the asm code was
written with this in mind. Sometimes the art of deception even
involves code for peripherals that aren't even being used for anything
- it's the old magicians trick of attracting you to one hand while the
other hand is doing something completely different.
Assembler routines take about 10 - 20 times longer to write than C,
and a much longer time to debug. Most companies simply can't afford
this kind of development except for those cases where there is no
alternative. And when this kind of need arises it often makes sense to
use a consultant who specializes in this.
Eric
2006-04-11 by brendanmurphy37
In looking at this again, it struck me that another reason not to
use in-line assembler such as the example below (i.e. particularly
where macros are involved) is to ask what happens when you want to
re-compile the code using Thumb mode (as you might want to do to
reduce code size)? My guess is that the macros will no longer work,
so you'll be forced to do Thumb versions of the same. Then you have
to figure out a way to use the correct macros at the correct places.
This is a typical example of not considering portability issues at
the start, and having them come back to haunt you at a later date.
1. Start off with some neat code that exploits some compiler
feature, in this case by writing some clever macros that use in-line
assembler.
2. There's no issue with Thumb mode, because all the code is
compiled in ARM mode: where's the problem?
3. The macros are so good they get to be used all over the place.
4. Suddenly someone wants to use this software: the problem is
they're insisting on using a part with a minimal amount of code
space.
5. We know we can achieve this if we used the preferred ARM
mechanism for reducing code space (Thumb mode), but we have all
these ARM-code inline assembler macros scattered throughout the code.
6. What do we do?
I'm not saying this scenario is the case here, but hopefully people
can see what the big deal is with using non-standard, non-portable
features: you can never tell how requirements will evolve over time.
The alternative I approach I posted doesn't suffer from this
problem. I'm not saying it's perfect, but I'd argue that at the very
least it is easier to maintain and modify.
I have seen many, many examples of the sequence of events listed
above (details changed obviously), and each time there's been a lot
of pain involved in solving the self-inflicted problems thrown up.
Please note that none of this is a criticism of the actual code
below: I'm simply using it to illustrate a point.
Brendan.
question.
[[items removed here]]
> > // 'irqMask'
> > inline int
> > irqMask(mask)
> > 	int mode;
> > 	// set mask bit
> > 	asm volatile
> > 		"msr\tcpsr, %1"
> > 		: "=&r" (mode)
> > 		: "r" (mask)
> > 	// previous mode
> > 	return (mode);
> > } // irqMask()
> > // End of 'irqMask'
2006-04-11 by Stephen Pelc
> Subject: Re: Re: Example of C and inline ASM in a file?
Here's my standard response to this question. Just to confuse
you, the example is not in C, and it's not for an ARM, but the
principles apply. The example is for a very simple UART driver
with interrupts enabled on receive.
: key0		\ -- char
\ *G Wait for character from USART0 and return it.
  begin
    di  rx0-avail c@ 0=
   while
    [asm  bis # _cpuoff _gie + sr  asm]	\ cpu to sleep, GIE set
  repeat
  rx0-char c@  0 rx0-avail c!
  ei
The compiler 'knows' about DI and EI to disable/enable
interrupts. The ways to the put an MSP430 to sleep are myriad.
The objective is to minimise the time for which interrupts are
disabled. Putting in a single assembler instruction achieves
that objective and documents everything the user needs to know.
Doing it this way gives faster code, better interrupt latency,
shorter source, and keeps everything together. Yes, I could have
tweaked the compiler to do this, but I prefer to do that only
when the required functionality is itself portable across CPUs.
Where I will code a complete routine is for something like the
TCP/IP checksum, where a hand-coded assembly routine will beat
the pants off the output of most compilers.
For an ARM7, each call/ret pair costs at least six cycles. For
matched entry/exit routines, that costs at least 12 additional
clocks. On the LPC2xxx there are four potential MAM stalls.
When you have an effectively 12MHz ARM (not an LPC2xxx),
thirteen tasks, and a bomb-disposal machine to control, you
learn to be paranoid!
Stephen
2006-04-11 by Paul Curtis
Hi Stephen,
> expect either
> > of us to change the others mind but I am curious as to the
> reasoning.
> the principles apply. The example is for a very simple UART
> driver with interrupts enabled on receive.
> : key0		\ -- char
>   begin
>     di  rx0-avail c@ 0=
>    while
>   repeat
>   ei
> are disabled. Putting in a single assembler instruction
> achieves that objective and documents everything the user
> needs to know.
> latency, shorter source, and keeps everything together. Yes,
> I could have tweaked the compiler to do this, but I prefer to
> do that only when the required functionality is itself
In C, if I remember Forth control words well enough:
#include <inmsp.h>
#include <msp430x14x.h>
unsigned char rx0_avail;
unsigned char rx0_char;
unsigned key0(void)
  unsigned char ch;
  for (;;)
      __disable_interrupts();
      if (rx0_avail)
          ch = rx0_char;
          rx0_avail = 0;
          __enable_interrupts();
          return ch;
      __bis_SR_register(CPUOFF + GIE);
Generates:
       __disable_interrupt();
1100  32c2                      DINT
        if (rx0_avail)
1102  c2930102                  CMP.B   #0, &_rx0_avail
1106  0624                      JZ      0x1114
            ch = rx0_char;
1108  5f420002                  MOV.B   &_rx0_char, R15
            rx0_avail = 0;
110c  c2430102                  MOV.B   #0, &_rx0_avail
            __enable_interrupt();
1110  32d2                      EINT
            return ch;
1112  3041                      RET
1114  32d01800                  BIS.W   #0x18, SR
1118  f33f                      JMP     0x1100
I believe this is pretty good code from our CrossWorks MSP430 compiler.
:-)  No assembly inserts in sight.
Ok, this is an MSP430 example, but for each architectural feature of the
MSP430 I believe I have provided an intrinsic which means that inline
assembly code is not required.  It's done in such a way that it is also
compatible with the IAR MSP430 compiler, which means you can take code
written for ours and recompile on a competing compiler without resorting
the recoding any assembly language items.  Of course, we find the tide
is in the opposite direction... ;-)
Good example of an appropriate use of in-line assembler. The side
effects of issuing the "DI" and "EI" are pretty much non-existent in
this case: there really is very little argument for taking another
approach (though I would hide the implementation behind macros just
in case).
For an in-appropriate use, see the recent example of ARM macros to do
a similar task.
I'd be careful about making this argument. We do a lot of DSP stuff
on RISC processors (digital filters of various types). For the low-
level stuff, our starting point is a 'C' implementation. On a couple
of platforms we coded these up in assembler. However, we stopped
doing this, as by measuring the performance of the optimised 'C'
version we found there was little difference in performance:
certainly not enough to justify the additional development and test
time required. The greatest performance gains came from algorithm
optimisation rather than coding in assembler.
Someone presented this argument in relation to coding a context
switching implementation. I'd argue that if you can't afford a few
extra cycles in your context switches, you're doing too many of them.
Try another approach.
I've seen this argument so many times: a particular way of doing
something saves a few cycles. In the vast majority of cases it makes
absolutely no difference to a system's performance. If you really are
that close to the edge, you're much better off at reconsidering the
overall approach you're using.
Unless something is inside a loop with many iterations, or part of a
very high frequency event (e.g. a high frequency interrupt), it is
pretty much guaranteed not to have any impact on system throughput.
If it is in either of those situations, and performance was an issue
(determined by quantitative analysis or empirically), I'd look at re-
coding the entire offending section. If you really, really feel the
need for in-line assembler, I'd isolate the relevant code into a
separate source file.
I'd argue that this would lead one to maximise quality rather than
speed of code. Simplicity, ease of maintenance, absence of side-
effects, portability all tend to drive quality up. Squeezing the last
drop of performance, using non-standard compiler extensions and the
like all tend to drive it down.
Please don't get upset anyone, the above is just an opinion! I'm
happy to accept that the counter argument is perfectly valid: all I'm
saying is that based on my own experience, using in-line assembler
would be my last rather than first choice.
2006-04-11 by jayasooriah
Robert,
Thanks for your detailed response.  Here is an alternate view.
> >one does.
I have had considerable experience in training programmers from 18 to
50, in academia and in industry, using Borland, ByteCraft, Keil
compiler variants besides K&R C, on 8-bit, 16-bit, 32-bit, CPUs and DSPs.
I have written compilers, assemblers, linkers, operating systems,
mostly all in C.  I also have a good record in trouble shooting
problems to their root causes when it is not clear if the compiler or
the code being compiled is at fault.
boiling
I do not agree with your "nearly all" characterisation.  Perhaps many.
The ARM GCC Inline Assembler Cookbook is one that comes to mind.  I
have seen some others documented reasonably well too but I will admit,
it is very hard to get programmers (whether 18 of 50) to reading the
manual.
>          #asm
>          #endasm
> bigger issue.
I agree, *if* the compiler does not support inline assembly properly.
 Do you think GCC falls in this category?  I am not sure about the
rest, but in GCC, the ASM feature is a (clever) hook to the code
generator internals.
middle of
> optimized away.
I would classify this more a myth than fact.  One has to understand
the limitations of the feature before one uses it.  More often I find
that the programmer forgets to use the volatile qualifier.
I am not saying optimisers do not screw up.  But they are bugs just
like other bugs.   There are bugs in how compilers implement switch
statements. That is not sufficient grounds IMO to advocate not using
switch construct.
do.  The
at the
other
you
I classify this the myth category.  More often than not, one forgets
and names a register and forgets to tell the compiler.  I provided an
example in GCC where you do not have to name a register -- get the
compiler to allocate it.  This way, the compiler always knows what is
being used.
I am happy to consider real examples, past or present, which I hope
will make it easier to illustrate the points I have raised.
Jaya
> Jaya
Maybe you could consider the issues I raised about your own example in:
http://groups.yahoo.com/group/lpc2000/message/15225
I'm sure everyone would welcome your input.
Brendan
2006-04-11 by George M. Gallant, Jr.
How to start a flame war by Brendan Murphy.
I switch between C/Assembler because it fits my current needs. End of
discussion!!!
George
> > Jaya
> in:
> Brendan
> SPONSORED LINKS
> Microcontrollers
> Microprocessor
> Intel microprocessors
> ______________________________________________________________________
> YAHOO! GROUPS LINKS
>      1.  Visit your group "lpc2000" on the web.
>      2.  To unsubscribe from this group, send an email to:
>          lpc2000-unsubscribe@yahoogroups.com
>      3.  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>         Service.
> unsigned key0(void)
>   unsigned char ch;
>   for (;;)
>       if (rx0_avail)
>           ch = rx0_char;
>           rx0_avail = 0;
>           return ch;
I'm not complaining about your code generators, Paul. Remember
that you've written compilers for MPE!
I'll requote my post:
> needs to know.
versus
Not much difference either in terms of readability or of
keystrokes. As I implied above, it's a qualitative/subjective
decision, and I personally don't find CPU-dependent pseudo-
portability attractive.
The advantage of your intrinsics is in the protection for the
user against resource usage by the compiler.
[AD] IAR vs Crossworks snipped!
Stephen
> time required.
In general, I agree, but the gains on an ARM were irresistible
and we did the comparisons some years ago.
No argument there - complete agreement.
Remember that MPE sells Forth compilers with an RTOS and
drivers. We have clients who (some years ago) thought that it
was reasonable to run interrupts at 1Mhz on a 10Mhz CPU - we've
just learned over the years that spending a couple of hours
reducing interrupt latency during development can save days
later.
For most applications your arguments are valid, but 10% of
clients cost 90% of tech support.
Define quality. The first requirement is to meet the spec! That
job took 100 hour weeks and *all* code was documented.
My example was from a low-level device driver, not from
application code. Now have a go at Paul's non-standard
intrinsics :-}
Now let's agree just to disagree on some points.
Stephen
2006-04-12 by jayasooriah
George,
I appreciate the sentiment you expressed.
I frequently write illustrattive examples on-the-fly that encapsulate
the concepts that want to explain.  Such examples often look simple
but non-trivial.
My experience in training has been that is that those who understood
from the example move on very quickly.  The ideal is that these people
are able to extend it to meet their particular requirements.
However there are those who will keep going back to the same example
over and over again well past its half-life.
Although ducationists and psychologists have lots of theories about
this kind of behaviour, I usually look at this simplistically as a
problem with the level at which the example was pitched at.
Solution?  Break it down to smaller components and may be add a
textual explanation rather than letting the code speak for itself.
If there are enough people interested in textual commentary of my
example, and perhaps on finer things that come out nicely in this
example relating to how GCC optimises the inline assember code in the
way we want it to, I am happy to oblige.
Jaya
--- In lpc2000@yahoogroups.com, "George M. Gallant, Jr."
> discussion!!!
> George
> > > Jaya
> > in:
> > Brendan
2006-04-12 by brendanmurphy37
Stephen,
First off, thanks for engaging seriously with the points I raised,
rather than simply disparaging or insulting those with a different
view. Having said that, I think we probably agree far more than we
disagree.
See some detailed comments below.
Brendan
In that case, we agree 100%, if what you're saying is: "do the
comparisons, then decide assembler or 'C'". We use the following
strategy for time-critical systems: (1) find out where the system
really spends its time (2) focus on the algorithms used in those
sections and modify as appropriate (3) code in assembler (if
necessary) and (4) most importantly: measure. The fact that we came
up with a different result at stage (4) is kind of irrelevant: the
point is that we both used comparative results to come to a reasoned
conclusion.
Note that you can stop at stage (2) if the system meets its spec at
that stage, and save yourself a lot of development and support time
and effort.
A minor point is that in the example I used of the digital filter
stuff, the low-level functions were deliberately written to give the
compiler the easiest possible job of optimisation. Sure enough, it
spat out the appropriate series of "mac" instructions, one after the
other as planned. The algorithm optimisation (which involved a
technique of loop unrolling) was done at a higher level to make this
possible.
Nothing more to be said here.
> later.
I take your point. A related one I guess is that in your case you
will be judged amongst other things on benchmark results. So for
example a commercial RTOS might be judged on speed of context
switch. Another case of where benchmarks are frequently misleading
or irrelevant.
A useful definition of quality: "absence of defects". Meeting the
spec is a given. After that anything that aids maintenance and
ongoing support will tend to drive quality up. I'm talking
generalities here: I'm sure your system was of the highest quality!
> intrinsics :-}
I'd rather see non-standard intrinsics than in-line assembler!
As I said, I suspect we agree far more than disagree. The only real
difference is that in our respective toolchests, in-line assembler
is likely to be found in a different place (somewhere near the
bottom in mine). I wouldn't fall out with anyone because of that:
the important thing is to be conscious of all the relevant factors
involved in using a particular tool, and to learn from other's
experience rather than simply blindly challange it.
Brendan
Jaya,
I'm not sure what you're trying to achieve here.
You present an example. I point out that it illustrates a point I'd
been making (about how using in-line assembler can cause unintended
problems as requirements change). You accuse me of not understanding
the original example.
If you're interested in a technical discussion, maybe you should
read what I actually said, and respond accordingly?
If all you're interested in is disparaging and insulting other
contributors, can I ask you to please stop? I've had more than
enough of it at this stage.
Best wishes
Brendan
wrote:
> George,
encapsulate
> but non-trivial.
understood
people
example
> Regards,
> Jaya
End of
> > discussion!!!
> > George
I hope
> > > > Jaya
example
> > > in:
> > > Brendan
Dear Brendan,
Please onsider inline assembly issues as separate from interworking
issues.  Lumping them together results in the type of problems that
you appear to find yourself in.
Take a moment, and consider if you can appreciate the purpose of my
on-the-fly example.  The fact that it looks like operational code is
incidental.  It is *not* a on size fits all solution.
You have peculiar requirements.  Write your own if this one will not
fit.  Have a go.  Avoid making ambit claims about what can and cannot
be done with the example in a hope that I will respond by providing
you the extension that will meet your peculiar requirements.
My on-the-fly example serves to demonstrate that:
b) the problem I originally extracted my requirements from (a code
that I attributed to Rowley Associates) can be solved by identifing
three primitives required;
b) each of these can be coded as inline assembly or external module as
one prefers, and I provided an inline assembly example, and using
inline functions; and
[Some here seem not to distinguish between the two different use of
"inline" attributes.]
c) using inline assembly, and letting the compiler know what you are
doing in these three primitives, you can take advantage of the merging
of the independent primitives, inline, efficiently as shown in the
final outcome.
I am not proposing that one should avoid procedure calls.  The example
I started with appears to suggest this is a requirement.  I thought of
a simpler way to achieve the same end result.  So I put it up as my
on-the-fly code.
I am not interested in your whining every time I point a simpler,
better, or for that matter, just another, way of doing things.
Have a good day.
Jaya
wrote:
> Jaya,
> Best wishes
> Brendan
2006-04-12 by Robert Adsett
>boiling
Fair enough, Many/nearly all could well be a sampling error or selective
memory.
>manual.
I would be an exception, annoys some people for some reason.
Where would I find that BTW?  The one gripe I have against GCC is that the
documentation seems to be well hidden.
> >          #asm
> >          #endasm
> > bigger issue.
I've no reason to disparage GCC particularly.  Indeed GCC seems to be the
best thought out implementation I've seen (mostly from afar) but it as a
result it also tends to be most of the way towards being a third language.
I've just yet to see an advantage to inline over standard assembler and
given the problems I've encountered the 0 benefits/x problem ratio tends to
discourage :)
Actually (as a side bar), the availability or lack thereof of GCC for an
architecture is becoming a major consideration in choosing a
microcontroller for me.  I've become fed up with the copy protection
schemes commercial compilers tend to foist upon me.
>middle of
> > optimized away.
Since at least one of the compilers that exhibited this had no concept of
volatile (pre-ANSI) that would have been difficult.  Surely volatile is not
used universally to signal this?
>do.  The
>at the
>other
>you
That presupposes that it is possible to tell the compiler what registers
are being used.
Both of the last two problems I have seen.  It's been long enough I
couldn't dredge up the details so it's certainly subject to fuzzy recall
and you should feel free to take with as much salt as you like :)
My experience has taught me (much as touching a hot stove does) to avoid
compiler and architecture specific 'features'.  There are times they cannot
be avoided or the facilities they provide are very advantageous.  Items
like mapping into otherwise unaddressable memory spaces come to
mind.  However, for items like assembly and interrupt prologues and
epilogues where there clear, simple well tested alternatives I won't
subject myself to the risk any more.
I don't expect we are likely to change each others minds, but knowing why
we reach the decision we do is useful I think.  Now if someone could come
up with a credible way of measuring some of this we might be further
along.  On the other hand that might just destroy the fun of debate ;)
Robert
> that the documentation seems to be well hidden.
I was referring to:
I do not like GCC by and large for the same reasons.  Having dwelled
in it to the extent I have, I appreciate the its evolution to the
extent I can sort of "guess" how something works in GCC long before I
dive into the code to confirm.
Open source has its disadvantages.  There are so many variants, many
of which are unfortunately just hacks for particular purposes. These
tend to break the core philosophy and implementation in unexpected ways.
Builds for the popular platforms tend to suffer from this problem more
than core platforms. I run from one such popular platform and I always
work with my own builds from FSF releases which is better controlled.
The creators of C had a phobia about introducing new tokens.  So they
tended to overload the meaning of the same token in different
contexts.  The "static" qualifier is a good example.
From memory, volatile applied to a variable tells the compiler not to
assume that it is normal memory because it may not retain its value
until over written, or that reading it repeatedly may not yield the
same value.
The same qualifier applied to ASM statement tells the compiler not to
assume that optimisation techniques applied to memory will work in the
context of this code sequence involved.
registers
> are being used.
Yes, GCC lets you do this.
knowing why
come
The root cause of wars IMO is when one side tries to change the others
mind!
Okay, seriously, I think the truth is somewhere in between.  I like
knowing both so that I can interwork (to borrow the term) and take
advantage of the side that best suits by needs.
2006-04-12 by Michael Rubitschka
Dear Jaya
I often noticed that the medicore programmers do the best job.
They somehow follow the ASAP-ACAN principle.
(As simple as possible, as complex as neccessary).
Their code is highly readable and maintanance friedly.
The work of gurus or experts is often much more complex
as neccessary and one can prepare for a rewrite once that
person leaves the company.
my 2 cents
Michael
Jaya,
I take your point about your example being illustrative only, and not
intended as a workable solution to a particular problem.
I had hoped you would take my point of using your example as an
illustration of the problems that can arise with in-line assembler.
We're both doing exactly the same thing: using a particular example
to make a point. They just happen to be different points.
I don't have any particular requirements, nor am I faced with a
particular problem, and I'm certainly not looking for you to provide
any solutions (I'm baffled as to how you could draw this conclusion).
Maybe you should read what I said again, with this clarification in
mind?
Finally, I'd ask you once again to ease up on the disparaging and
insulting language ("peculiar requirements", "whining" etc.). It adds
nothing to your arguments, and simply turns people off.
Best wishes
Brendan
> Dear Brendan,
cannot
as
merging
> final outcome.
example
of
> on-the-fly code.
> Have a good day.
> Jaya
> wrote:
> > Jaya,
I'd
unintended
understanding
> > Best wishes
> > Brendan
Micheal,
If your definition of a "mediocre programmer" is one who strives
for "highly readable and maintenance friendly code", I'd be proud to
be considered as one!
Brendan
wrote:
> Dear Jaya
understood
people
> my 2 cents
> Michael
Hi Michael, you alluded me to a typo.
I meant to say "idea" but typed "ideal" and that changed the meaning
somewhat.  I meant to say that most programmers cope with it well.
Cuts both ways.  Mediocre programmers accept requirements more readily
and are usually easier to manage.  Expert programmers often dwell in
changing the requirements to meet their notion of a good solution.
Expert or mediocre, I like to think requirements come first followed
by the KISS (keep it simple, xxx) rule.  All else is optional.
In case you are suggesting (I am not sure), my example is not a guru
level solution by any means.
I reckon the person who wrote the example I extracted requirements
from went to great lengths in making sure that the procedure call to
disable or enable interrupts is not taken unless necessary.
In my rewrite the procedure call is a non-issue and thus I was able to
do away with the conditionals making it simpler and deterministic.
The whole idea behind using inline assembly rather than assembler
modules for my example is to show that it is both more readable *and*
easier to maintain.
One could hide ASM details in a header and then you cannot tell the
two implementations apart by looking at the code.
A maintainer would prefer to maintain C and H files than S files, when
the code is generic and common to the different architectures barring
inline ASM escapes in conditional context.
A client will not appreciate conditional code that handles just about
every variant there is on the planet when only one of these is all the
client is interested in.
> my 2 cents
> Michael
Hi Jaya
No I did not want to offend you or put in in the guro or medicore programmer
drawer.
Yes absolutly right, I see this every day.
In the end all that counts is to get the requirements working as fast as
possible
and kepp them free of bugs.
Cheers
Michael
> mind?
I have.  You include interworking requirements to the original problem
from which I extracted the requirements.
If you can rephrase your problem without interworking requirements, I
am happy to respond.
I do not wish to start a thread on interworking at this time because
it is a different kettle of fish.  (I do not know of any compiler that
is capable of optimisating across interworking barrier.)
Jaya
Hi Brendan
I am also working hard to become one. :-)
Cheers
Michael
>Date: Wed, 12 Apr 2006 09:40:29 -0000
>Micheal,
>Brendan
>wrote:
> > Dear Jaya
>understood
>people
> > my 2 cents
> > Michael
Jaya,
OK - I think we got off on the wrong track: I'll try and explain
further.
I was using your example - which is perfectly valid in itself - to
illustrate a point.
Consider the following sequence of events:
1. We need some mechanism to lock out interrupts, for reasons that
should be clear enough to everyone.
2. We decide to implement this as in-line assembler, wrapped up in
some nice macros. In fact, we implement exactly the same macros as
you presented in your example.
3. We test these out, and they work well. Everyone is delighted with
the results. Our macros are a great sucess, and everyone is happy.
Everyone uses them, all over the place.
4. Then, as often happens, some new requirement comes along. Code
space is now a real issue for everyone. No problem: our chosen
architecture has just the solution: re-build all our software using
Thumb mode.
5. We re-build our software and are faced with an immediate problem:
our nice macros that are used everywhere no longer work, as they use
ARM-mode specific instructions.
How do we solve this problem? there are all sorts of ways it can be
solved: I'm sure you and I could both come up with several without
too much effort. The problem is that it will take effort, no matter
how it's done.
The point I'm making is that the more you use non-standard, compiler-
specfic features such as in-line assembler, the more likely it is
that changing requirements will cause problems.
It's a general point: unfortunately as we all know we can never
anticipate all possible requirement changes when we produce a
solution to a set of requirements. However, by following some general
rules, such as avoiding non-portable features where possible, we
increase our chances of being able to modify our system with fewer
rather than more changes as requirements change.
I completely take your point that your example was for illustrative
purposes only, and that you probably wouldn't implement these macros
in a working system (possibly for the reasons I outline). However,
I'm using also it to illustrate a point: a naïve programmer might
very well use solutions such as those in the example, without being
conscious of the need to consider portability issues.
Best wishes
Brendan
in
> > mind?
problem
I
that
> Jaya
2006-04-12 by rtstofer
wrote:
> Hi Brendan
> Cheers
> Michael
I'm 'mediocre' - even on a good day.  But, I can live with it!
Heck, I wrote a FORTRAN program a couple of weeks ago to do some curve
fitting.  It was nice to be home; visiting an old friend.  I just
can't take the C thing serious...  A passing fad, no doubt!
So, has anyone enabled FORTRAN for the GCC compiler and the ARM platform?
Richard
Dear Brendan,
This dialog has gone long enough.  I like to finish off by addressing
your lingering doubts once more as best as one can, and move on.
Thus my on-the-fly example has served its purpose.
> Thumb mode.
> how it's done.
You cannot turn off interrupts while in thumb mode if you do not
interwork.
GCC supports interworking.  It has compiler options to select the
paradigm you want to adopt for interworking.  If you do not want to
use it because it is not supported in the same way on all compilers,
that is up to you.
I like to use the feature given I think GCC supports it well enough.
This is not what I said.  I stand by what I said.
Finally Brendan, my on-the-fly example having served its purpose, and
the forum having moved on, it is about time you do the same.
Jaya
platform?
I had to enable (build and validate) FORTRAN for GCC for i86 platform
just last year.  At first I protested vehemently but I changed my mind
when I found compensation difficult to refuse :)
Jaya
Jaya,
OK - I give up. I've clearly failed to explain to you the point I was
trying to make (which has nothing to do with interworking or whether
or not particular features are supported by GCC). Maybe someone else
can try.
Hopefully others will have understood what I've been trying to say,
and it'll provide them some food for thought.
Brendan
> Dear Brendan,
addressing
that
in
as
with
happy.
using
> > Thumb mode.
problem:
use
be
without
matter
> > how it's done.
> interwork.
compiler-
> that is up to you.
illustrative
macros
and
> Jaya
2006-04-14 by John Heenan
Despised by the 'beautiful people' but practical, macros make it is
easy to retarget ARM inline assembler to work with C code compiled as
Thumb assembler.
Following are expamples for interrupt disable/enable for GCC. The
intention is simply to force the macros through functions compiled as
ARM code so as the compiler will force correct usage of bx to switch
between ARM and Thumb modes, when compiling Thumb code. The beauty of
the macro system is that all ARM generated code can use pure inline
assembler through
#define INTDISABLE INTIF_DISABLE
#define INTENABLE  INTIF_ENABLE
and all Thumb generated code can use function wrappers for the same
macro names through
#define INTDISABLE cpsr_if_disable()
#define INTENABLE  cpsr_if_enable()
When it comes to portability, the interface definiton is crucial.
Macros make it dead easy to muck around with interface defintions. Of
course debugging through a macro maze is another story!
//part of HEADER FILE such as header.h
//MAKE SURE A DEFAULT ISR HANDLER IS ASSIGNED TO VICDefVectAddr
//THE DEFAULT ISR HANDLER CAN BE EMPTY BUT MUST BE PRESENT
//#define INTDISABLE cpsr_if_disable()
//#define INTENABLE  cpsr_if_enable()
#define SLOWINTDISABLE INTI_DISABLE
//#define SLOWINTDISABLE cpsr_i_disable()
#define SLOWINTENABLE  INTI_ENABLE
//#define SLOWINTENABLE  cpsr_i_enable()
//volatile definition forces stack storage and is not required
//as optimisation sees variable is used by a function and so keeps
//#define INTVAR volatile int cpsr_prior
#define INTVAR int cpsr_prior
#define INTGETDISABLE cpsr_prior=cpsr_ifget_disable()
#define INTRESTORE cpsr_c_restore(cpsr_prior)
void cpsr_if_disable(void); //works with thumb
void cpsr_if_enable(void);  //works with thumb
void cpsr_i_disable(void); //works with thumb
void cpsr_i_enable(void);  //works with thumb
int cpsr_ifget_disable(void);//works with thumb
void cpsr_c_restore(int cpsr_prior);//works with thumb
//not OK for thumb code
#define INTIF_ENABLE   asm volatile ( \
   "mrs r3,cpsr     \n\t" \
   "bic r3,r3,#0xC0 \n\t" \
   "msr cpsr_c,r3   \n\t" \
   : "r3"                 \
#define INTIF_DISABLE  asm volatile ( \
   "orr r3,r3,#0x80 \n\t" /* I bit. separate disablement: see user
manual */ \
   "orr r3,r3,#0x40 \n\t" /* F bit */ \
   : "r3"                 \
#define INTI_ENABLE   asm volatile ( \
   "bic r3,r3,#0x80 \n\t" \
   : "r3"                 \
#define INTI_DISABLE  asm volatile ( \
   "orr r3,r3,#0x80 \n\t" \
   : "r3"                 \
//MODULE FILE compiled as ARM assembler
#include "header.h"
void cpsr_if_disable(void)//works from thumb
 INTIF_DISABLE;
void cpsr_if_enable(void)//works from thumb
  INTIF_ENABLE;
void cpsr_i_disable(void)//works from thumb
  INTI_DISABLE;
void cpsr_i_enable(void)//works from thumb
  INTI_ENABLE;
int cpsr_ifget_disable(void)//works from thumb
  unsigned int cpsr_prior;
  asm volatile (
   "mrs %0, cpsr       \n\t"
   "orr r3, %0, #0x80  \n\t"  /* I bit. separate disablement: see
user manual */
   "msr cpsr_c, r3     \n\t"
   "orr r3, r3, #0x40  \n\t"  /* F bit */
    : "=r"(cpsr_prior)
    : "r3"
  return cpsr_prior;
//assmembler generated
// mrs r0, cpsr
// orr r3, r0, #0x80
// msr cpsr_c, r3
// orr r3, r3, #0x40
// msr cpsr_c, r3
// bx	lr
void cpsr_c_restore(int cpsr_prior)//works from thumb
  asm volatile (
   "msr cpsr_c, %0 \n\t"
    : "r" (cpsr_prior)
//assembler generated
// msr cpsr_c, r0
// bx	lr
John Heenan
<brendan.murphy@...> wrote:
> Jaya,
was
whether
else
> can try.
> Brendan
> > Dear Brendan,
> addressing
<brendan.murphy@>
> that
> in
> as
> with
> happy.
Code
> using
> > > Thumb mode.
> problem:
they
> use
can
> be
> without
> matter
> > > how it's done.
> > interwork.
> compiler-
is
to
compilers,
> > that is up to you.
enough.
> illustrative
> macros
> and
> > Jaya
I have extended and tidied up the examples I have just posted to the
thread. I will probably post the code to the file section soon.
John Heenan
//header file interwork.h
#ifndef INTERWORK_H_
#define INTERWORK_H_
#ifdef THUMB_INTERWORK
#else
 #define INTGETDISABLE INTIFGET_DISABLE(cpsr_prior)
 #define INTRESTORE INTIF_RESTORE(cpsr_prior)
#endif
Usage example
  INTDISABLE
  INTENABLE
  INTVAR;
  INTGETDISABLE;
  INTRESTORE;
  INTGETDISABLE;
  INTRESTORE;
   : "r3"                 \
manual */ \
   : "r3"                 \
   : "r3"                 \
   : "r3"                 \
#define INTIFGET_DISABLE(A) asm volatile ( \
   "mrs %0, cpsr       \n\t" \
user manual */ \
   "msr cpsr_c, r3     \n\t" \
   "orr r3, r3, #0x40  \n\t"  /* F bit */ \
    : "=r"(A)                \
    : "r3"                   \
#define INTIF_RESTORE(A) asm volatile ( \
   "msr cpsr_c, %0 \n\t" \
    : "r"(A)             \
#endif // INTERWORK_H_
//module file interwork.c compiled as ARM assembler
#include "interwork.h"
 INTIF_DISABLE;
  INTIF_ENABLE;
  INTI_DISABLE;
  INTI_ENABLE;
  INTIFGET_DISABLE(cpsr_prior);
  return cpsr_prior;
// mrs r0, cpsr
// msr cpsr_c, r3
// msr cpsr_c, r3
// bx	lr
  INTIF_RESTORE(cpsr_prior);
// msr cpsr_c, r0
// bx	lr
as
> Thumb assembler.
as
switch
of
> assembler through
2006-04-15 by jayasooriah
John,
Hope this spoilt child will not be grounded for critiquing on dad's
work :)
It certainly dismisses the myth that one can disable interrupts while
in 16-bit mode without interworking!
I hope you will not mind if I critique your design with the view of
improving it becomes a file.  I do not wish to kill your efforts by
coming up with yet another interface design.
I do apologise before hand if in aiming to be complete I appear to be
nit picking.  It is occupational hazard that I have learnt to live with :)
I feel your design can be made more compiler friendly in relation to
optimisation if you had used inline functions.
I trust my comments will be received in a constructive mode.
Jaya
> John Heenan
Probably your intention was to demonstrate interworking.  When you
make it a file, perhaps you could reflect on the purpose of this
interface, which is not interworking.
I do feel this comment is out of place.  Certainly it applies to LPC
but is not something generic that I think warrants such a comment if
we look at the portability requirement some here appear preoccupied with.
Appears to violate a rule in my KISS book that says:
  "Avoid defining a new conditional for one that exists."
Why not use the __thumb__ token that is already defined by GCC when
you invoke it with -mthumb option to produce 16-bit code?
I think the comment is not clear.  I do not understand what you are
getting here.  Perhaps you can rephrase it to make it clearer.
Appears to violate two rules in my KISS book:
  "Avoid defining a new interface for one that exists."
and
  "Avoid using macros to alters syntax or semantics."
In relation to the latter rule I am assuming we are taking about a
fresh design, not retrofitting header to existing code.
> #else
> #endif
> Usage example
>   INTDISABLE
>   INTENABLE
>   INTVAR;
>   INTGETDISABLE;
>   INTRESTORE;
>   INTGETDISABLE;
>   INTRESTORE;
>    : "r3"                 \
I prefer to avoid having to name registers explicitly so as not to
impose additional constraints on register optimisation.
Although not naming a register appears to adds one extra instruction
(which can be avoided if we were to design the interface differently),
it can save two move instructions where it is instantiated inline.
> manual */ \
>    : "r3"                 \
Same issue here with naming register.  More such examples below.
>    : "r3"                 \
>    : "r3"                 \
> user manual */ \
>     : "=r"(A)                \
>     : "r3"                   \
>     : "r"(A)             \
I recommend naming the interworking options needed if compiled code is
to work when called from 16-bit mode -- caller or callee interworking?
>  INTIF_DISABLE;
>   INTIF_ENABLE;
>   INTI_DISABLE;
>   INTI_ENABLE;
>   return cpsr_prior;
> // mrs r0, cpsr
> // msr cpsr_c, r3
> // msr cpsr_c, r3
> // bx	lr
> // msr cpsr_c, r0
> // bx	lr
> as
> > Thumb assembler.
The macro feature is powerful, so powerful that it can be used to
obfuscate code as much as to make it clearer.
Macros in themselves are not ugly, but it certainly can be used in
very ugly ways.  Thus I do not despise the macro feature itself.
The most powerful use of macro is in retrofitting through making
minimal yet effective changes in the header.
> as
> switch
> of
> > assembler through
2006-04-15 by John Heenan
> John,
> work :)
Don't want to understand.
while
I was not aware of any such myths. I have simply submitted some
industry standard core code using techniques adapted from numerous
sources to fit a simple idea. I noted there is no MSR or MSR
instruction in Thumb and have not noted any code for the equivalent
in Thumb. The core of the code is firmly based on well documented
examples given by ARM and Philips.
Interrupts can be disabled without interworking on the LPC2xxx
through the VIC registers while in Thumb mode. I have brief notes in
preperation to be submitted as a file to the group.
be
with :)
I agreed it would give more freedom to the compiler to do its thing.
I have made comments about inline code below.
As I said it is just standard code adapted to fit a simple idea,
namely force industry standard ARM assembler code into a form
suitable for Thumb through functions compiled for interworking.
More comments below.
John Heenan
> Regards,
> Jaya
> > John Heenan
Yes.
with.
I disagree. It is a practical issue. Both ARM and Philips state a
default handler must be assigned using the standard examples they
provide that has been incorparated into the code.
Point accepted. Saw THUMB_INTERWORK in another example and took a
punt it was standard. I was wrong.
keeps
> and
It reflects my attitudes to macros and functions. I tend to make
function names reflect what is really going on at the lower level and
make them lower case. I tend to make macros names closer to the real
intention of the macro is and in upper case. It is a practice that
serves me well personally. I get a marriage of intention (macro name)
with implementation (function name), all in a single line definition!
However it is a practice I can be divorced from if is the democratic
will!
> > #else
> > #endif
> > Usage example
> >   INTDISABLE
> >   INTENABLE
> >   INTVAR;
> >   INTGETDISABLE;
> >   INTRESTORE;
> >   INTGETDISABLE;
> >   INTRESTORE;
> >    : "r3"                 \
I only named one register, r3, and specified it was clobbered. Since
the register cannot be attached to an input or output variable and
since I did not to troll through the horrific GAS assembler
documentation to see if there was a qualifier to specify working
registers r0-r3 or r12 only, I took the easy way out.
differently),
Inline code CANNOT get rid of the call and return bx instructions
(bxl for Thumb also) as these instructions are the mode change
instructions. Inline code expands TOTAL code size but does have the
advantage of not refilling the fetch/decode/execute pipeline.
user
> > manual */ \
> >    : "r3"                 \
> >    : "r3"                 \
> >    : "r3"                 \
> > user manual */ \
> >     : "=r"(A)                \
> >     : "r3"                   \
> >     : "r"(A)             \
is
interworking?
Agreed.
> >  INTIF_DISABLE;
> >   INTIF_ENABLE;
> >   INTI_DISABLE;
> >   INTI_ENABLE;
> >   return cpsr_prior;
> > // mrs r0, cpsr
> > // msr cpsr_c, r3
> > // msr cpsr_c, r3
> > // bx	lr
> > // msr cpsr_c, r0
> > // bx	lr
it is
compiled
> > as
> > > Thumb assembler.
The
compiled
> > as
> > switch
beauty
> > of
inline
> > > assembler through
> while
I was referring to the persistent request (to which your first post
was a response) that my interrupts example can be extended to 16-bit
mode without interworking.
Yes but there are costs.  The first (and prohibitive as I have argued)
is that the implementation of VIC on the LPC family (based on PL190
design) causes spurious interrupts to be generated when you do this.
The second (probably more insidious) is that the distinction between
of user and system modes appear to have been lost in the process.
The term "industry standard" cuts both ways -- see comment below :)
The "default" handler in VIC (PL190) is to handle interrupts that are
not vectored.  If all the interrupts are vectored, one does not need
to dismiss interrupts through the default handler -- one can take a
kernel panic when this happens as it indicates a system failure.
Philips requirement is different -- it a default interrupt handler is
required to dismiss spurious interrupts generated by LPC peripherals.
I like to make the distinction between "practice" and "standards".
This is what I meant by "cuts both ways" earlier :)
> will!
My experience from having to look at historical code base, is that
this is one of the biggest impediments to code life.  The next person
has to not only understand and appreciate how the features of the
language are used, but also understand new abstractions that sometimes
obfuscate the original intent;
For example:
	SAVE_INTERRUPT_STATE;
and
	int mode;
	mode = getInterruptState()
say quite different things.  The latter can be understood by anyone
with just the language semantics, but to understand the former, one
has to include the mind set of the original programmer to discover how
is the save achieved, where is it saved, and how does one restore the
saved state, what happens when there are more than one saved state, etc.
I advocate the philosophy that one uses as much of what is there
rather than creating new abstractions, and that a strong case be made
each time a new abstraction is contemplated.
Programs express precisely what we cannot easily do as prose.  Making
program look like prose usually works against KISS rules.
You are right in that there is no way to allocate a register that is
not attached.  However I thought the method I originally proposed that
does exactly the same overcomes this limitation.
Not true.  The compiler is able to optimise prolog/epilog when it
instantiates functions inline.  Have look at my original example
carefully.
Jaya
Re: [lpc2000] Re: Example of C and inline ASM in a file?
2006-04-15 by Robert Adsett
Is this distinction actually useful?  If user mode actually provided memory
protection or I/O protection mechanisms I could see a use.  As it is the
only real use I see for the mode distinctions is the register
saving/shadowing on interrupts.  The inability to manipulate the interrupt
flags appears to just be an annoyance/relic held over from ARM's larger
general purpose computer roots.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2006-04-16 by John Heenan
> > while
I have not seen your examples. Please provide a link or message
number. My posting was simply to provide examples of how inline ARM
assembler could be called from Thumb through a function wrapper.
I get a daily digest of the list and may go for days without even
opening it, let alone scanning it. When I do scan it I look for names
that provide useful information.  Top of my list is Philips_apps and
Tom Walsh. I generally do not scan past even the first few words in a
subject line. The only reason I posted to this thread was because I
scanned with amusement the words 'I give up' by Brendan Murphy and
because I hope I can pay back those who have given up their time
freely with something useful myself.
Like many I find vague and unsubstantiated accusatory information
irritating, not because I find the people irritating but because I
find having my time wasted by unnecessary drama irritating.
in
argued)
are
is
peripherals.
Why the drama over a peripheral that can sensibly clear its own
interrupt source?
I refused to buy into the 'interrupt debate' as I saw the debate as
less illuminating and coherent than the information already
available. An application note on spurious interrupts by Philips
exapands on information provided by ARM and by Philips in all of
their manuals.
Leaving aside the issue of IRQ and FIQ disablement, which is well
discussed in the manuals and does not require use of a default
handler, Philips clearly points out a default handler is required
when the VIC may change state in the pipeline between the core
latching an interrupt and between when the ISR address is read from
the VIC.
The application note provides two examples of the VIC changing state
as above: one when code changes the VIC state through assignment to
VICIntEnClr to feed the watchdog and another when a peripheral
changes the VIC state without user code through a UART FIFO clearing
an interrupt source. Clearly another way to change the VIC state in a
way that may require a default handler is to clear an interrupt
source with user code outside an interrupt while interrupts are
enabled.
I don't feel there is a real problem. Setting up a default handler is
trivial and good practice. It is not even necessary to update
hardware priority logic through assignment to VicVectAddr if there
are no real default interrupts to be handled. The handler can remain
empty as the interrupt call will be reissued if the interrupt source
is still present.
and
real
that
name)
definition!
democratic
> > will!
person
sometimes
> For example:
> and
>  int mode;
how
etc.
made
Making
It is not fair to apply good practice rules of database and business
rules programming (such as forms and reports programming) to hardware
and embedded programmers. Business rules programmers uses highly
abstracted tools that hide the horribly complex APIs. At some point
abstraction breaks down, it has to, the real world is not an abstract
entity. In this case it helps to know what functions are performing
direct hardware tasks as opposed to functions which are deliberately
abstractive.  For my own programming if a function performing
hardware tasks need to be used by an abstract set of functions then I
use a function pointer, as macros are unsitable at this level.
Function pointers are not used by database and business rules
programmers.
I don't think it is worth making a fuss about, I will probably accede
because I have better things to do than have questions raised by
theorists over how functions are named and to provide ammunition for
backroom gossip and amusement. There can't be much wrong in the IT
world if abstract naming is a central preoccupation!
to
Since
and
that
> carefully.
Please provide a link or message number.
You are not providing a complete picture.
In my example the only epilogue was BX and there was no prologue. BX
just does more than return, it also changes back to the Thumb state.
While a large prologue and epilogue can be reduced (if not
eliminated) and more optimisation can be performed if the code is
inlined, if the same function is inlined many times then the overall
code size is increased. People use Thumb to reduce code size.
Even if ARM code was inlined between Thumb code, the BX instruction
is required to enter ARM state. Since BX is a branch instruction it
will probably automatically refill the fetch/decode/execute pipeline
(can be tested by BX to inline ARM/ARM or Thumb/Thumb) and will need
to discard the current pipeline anyway due to how the current
pipeline has been interpreted and has the wrong size of information.
I have reviewed the RealView assembler guide and discovered there are
Thumb instructions for changing the interrupt state. They are CPSID
and CPSIE. They cannot be used to change to ARM state inline and so
avoid a branch penalty. However the instructions mean interrupts can
be disabled and enabled without entering ARM state through
interworking.
However the principle of my example remains, which is how to allow
inline ARM code to be used by Thumb code. The fact that the code was
interrupt related code was irrelevant. it just happened to be 'on
hand' and regrettably has drawn me into a debate I don't want to be a
part of and started anoter debate I don't want to be a part of
(abstract naming).
I am grateful for useful information when it is provided and am keen
to provide useful information in return.
John Heenan
> Regards,
> Jaya
Re: system and user modes (was Re: Example of C and inline ASM in a file?)
2006-04-16 by jayasooriah
Robert, given we are digressing, I hope you dont mind the my change of
the thread title.
memory
interrupt
One can ignore (and not enter) user mode to avoid the annoyance as you
put it.
If however one makes the distinction between user and kernel (or
system) modes there are benefits.  Off the top of my head:
1/  The designer is forced to make the distinction between
infrastructure (kernel) from application specific (user) components.
Infrastructure code is generic to multiple systems.  Application code
does the particular task the system is designed to do.
2/  Application code can be run at a lower privilege level so as to
avoid having to resort to extreme debugging measures when there is
interference.
A new programmer joining the team does not need to start with
expensive JTAG and/or other in-system emulation and debugging systems.
[By expensive, I mean to not only (just) price, but also time and effort.]
For example they could start developing an application on the target
using techniques as simple as printf() equivalents.
[Programmers who start with such methods exhibit more skills in
probing a system at the right places using techniques that do not
alter the system's operational behaviour.]
3/  The different privilege modes supports the decomposition of
embedded systems into a set independent and cooperating concurrent tasks.
This usually means there is a simple (almost always better) way to
describe system in terms of its constituents and how these
constituents interact.
I accept (although I do not know of one) that the distinction between
kernel and user mode may not be appropriate in every case.
However, in removing this distinction in the LPC family just makes it
less usable that it could otherwise be.  Bear in mind implementors
have the option of gating any operation with privilege mode bits
available in the ARM core.
Jaya
This is the clearest indication that my attempts to improve the
solution you proposed in preference to putting up yet another solution
is not working.
I look forward to seeing your solution is all done and ready.
If I feel I am able to extract your requirements, I will append to or
provide an alternative replacement solution as appropriate.
Jaya
Re: [lpc2000] Re: system and user modes
2006-04-16 by Robert Adsett
>the thread title.
I should have thought of it myself.  I'll trim it a little further :)
>memory
>the
>interrupt
>put it.
I realize that.
Well, yes but that's independent of user/system mode.  I can see system
mode being useful in large systems especially when you are loading an
application in RAM and using a flash image as the OS/kernel.  SWI then acts
as an indirect jump table to the underlying kernel functions.  But with the
small micros, especially those w/o an external bus, programs can as easily
be built with a static link and avoid the extra overhead of the SWI.  Both
the simple timing overhead and the need to build a gateway library that
provides the prototypes and parameter conversion from standard C type call
to an SWI based call.
>interference.
Well, yes but that was the real point of my question.  Other than the
ability to affect the interrupt state there doesn't appear to be a
privilege level difference between system and user modes.
You can do that anyway.  You can do a lot of debugging with simple serial
I/O and a few pins to toggle.  Indeed there is a lot of useful , especially
timing, information that is difficult or impossible to get other than
through I/O pins and an oscilloscope and/or logic analyzer.
There are other times when the only real recourse is multi-megabyte trace
and good trigger and more than a little persistence.  A problem I had on
another processor with a commercial kernel comes to mind.
I suspect there is a legion of them.  However let me give you a simple
one.  Linear actuator motor control.  Two, possibly three inputs (forward,
reverse and optionally a deadman) Outputs H bridge control of the motor and
a brake release coil. Add in ramping, deceleration tracking overload
protection etc.
You can argue that an ARM is overkill and for the simplest variant of this
it surely is, but with the price and them getting as low as they are it can
make a lot of sense to use them in very similar applications in the same
way it made sense to replace discrete logic with microcontrollers to begin
with.
Well, if they had I could see an argument.  I am not aware of any who
do.  Certainly the four I am most familiar with (Philips, ST, Atmel and
Analog) do not.  I've yet to use a micro that had that support.
Again this was sort of the point of the question.  Since that support is
not there is there any real advantage to the use of user mode?
If the micro provided I/O protection or memory protection I could see
gating I/O operation to/from user mode to gain a little more protection
from inadvertent manipulation of I/O.  A lot of the time inadvertently
flipping a bit at the wrong time is more dangerous than changing the
interrupt state, it's also a lot easier to do.
Robert
2006-04-17 by jayasooriah
> SWI then acts
with the
easily
 Both
type call
I know of many who think along the lines you have expressed.  They
associate "kernel" with what is found in general purpose operating
systems.
Allow me to challenge your perceptions relating to timing overheads
and gateway library requirements for SWI in embedded ARM context.  I
will use the watchdog feed example that got me involved in the earlier
thread.
Here is the interface
> static inline void
> atomicFeed(volatile int *feed, int arg1, int arg2)
>         register volatile int *param1 asm ("r1") = feed;
>         register int param2 asm ("r2") = arg1;
>         register int param3 asm ("r3") = arg2;
>         register int vector asm ("r0");
>         asm volatile
>                 "ldr\t%0, =atomicFeed"  "\n\t"
>                 "swi\t0"
>                 : "=r" (vector)
>                 : "r" (param1), "r" (param2), "r" (param3)
> } // atomicFeed()
and the implementation
> __attribute__((naked))
> void
> _atomicFeed(void)
>         asm volatile
>                 PROLOG (atomicFeed)
>                 "msr\tcpsr_c, #0xd3"    "\n\t"
>                 "str\tr2, [r1]"         "\n\t"
>                 "str\tr3, [r1]"         "\n\t"
>                 EPILOG ()
> } // _atomicFeed()
The application includes the header file and invokes atomic feed:
>        atomicFeed(&_WD.feed, 0xaa, 0x55);
The code generated for the application in 16-bit mode is:
>         ldr     r1, =[address]
>         mov     r2, #170
>         mov     r3, #85
>         ldr     r0, =atomicFeed
>         swi     0
The SWI 'vector' at 0x00000008 is always coded as
>         mov	pc, r0
And generated code for the "kernel" handler in 16- and 32-bit modes
>         .code   32
>         .global atomicFeed
> atomicFeed:
>         msr     cpsr_c, #0xd3
>         str     r2, [r1]
>         str     r3, [r1]
>         movs    pc, lr
The beauty of this method is that it supports both 16- and 32-bit
compilation (with no conditionals I must add), and it works when
invoked from both user and kernel modes.
Have a go and see how much you can trim off this implementation in
terms of timing and gateway library interface overheads by using
procedure calls and consider what you would stand to lose.
Incidentally, the "vectored SWI" approach I use allows any team member
who are play with custom "system mode" kernel calls.
Jaya
PS:  E&OE applies here too :)  If you spot mistakes, please do not
hesitate to point it out.
2006-04-18 by Robert Adsett
> > SWI then acts
>with the
>easily
>  Both
>type call
>systems.
Actually I was thinking more along the lines of a real time
kernel,  threads, semaphores etc..  I can see the term being extended a bit
beyond that but at the risk of its losing its meaning.
>thread.
I was referring to more than just timing overhead, although that's in there
too.
<snip>
<snip>
You appear to have left out the cracker function.  Unless you are planning
a one function kernal?
In this case somewhere between 50 and 80% since all you are left with is
the implementation function.  That's not really fair though I would expect
a real kernal to use somewhat heavier functions. I wouldn't pass the WD as
an address to the function like that, it just confuses the interface.  Also
something I wouldn't do inline but we've been through that ;)
However the bigger issue hasn't been addressed which is the rest of the
overhead.  The rather simple to maintain simple function interface has been
replaced by two functions separated by an interrupt.  Across this interrupt
you have lost the type checking and other interface protection C normally
provides.
You also have not addressed the issue of what this approach actually
achieves.  Since there appears to be no extra protection added by being in
user mode all that appears to have happened is that you've replaced one
function call with two calls plus an interrupt (one call to setup the
registers for the interrupt, one call from the interrupt cracker to the
actual function).  The calls maybe inlineable but conceptually they are
still there and what they do still needs to be done.  In return for this
the net gain is the user mode app can't manipulate the interrupt bits.  I
don't see the point.
I also don't see anything being lost by using a library that links directly
rather than through a SWI.  Quite the reverse actually.
I can see three cases where this approach could be useful
         1- A large system where the kernal is loaded separately from the
application.  Possibly with the application in RAM
         2- A multi-language app with the kernal and application having
incompatible calling conventions.
         3- An appliance application where the kernal and chip are shipped
as a unit.
Only for the external bus versions does 1 make much sense.  The memory
available on the 2100's. and non external bus micros from Atmel, AD and ST
just isn't that large.
In case two, well that's what assembly language is for :).  Or just a
better tool set.
Case 3, well that's rather specialized.  Personally I have no desired to
handcuff my chip source to my kernal supplier.
"to play with" maybe?
Which is different from a linked library in what fashion?
E&OE?
Robert
2006-04-18 by jayasooriah
extended a bit
My aim was to challenge that assumption that kernel must be large,
general purpose, and is only worth if there are many primitives.
The atomicFeed() example shows the benefits of making even just a
single procedure call a kernel primitive.  I have boot loaders that
run with as little as three of four kernel primitives.
with is
I dont understand what you mean.  Are you suggesting changing the
kernel call to procedure call will be smaller -- 50 to 80%.  I like to
see how.  You have to try it to discover the tradeoffs.
This is contrary to the KISS rule -- the simpler the functions are,
the less likely they will fail, the easier they are to manage, and the
more useful they would tend to be.
There are OSes (as different from kernel feature) that seek to
accommodate a variety of paradigms.  They are big for this reason.
interface.  Also
This is more a "style" or "preference" issue than programming
paradigm.  Maing it a parameter avoids having to provide separate
primitives for WD, PLL, and so on.
has been
interrupt
normally
> provides.
If you do not use kernel calls then you cannot reap the benefits.
I went through at great lengths to preserve type checking.  Hennce the
use of inline functions rather than macros.  Why do you say type
checking is lost?
being in
> actual function).
Two that I like to point out most:
1)  implementation does not know (and does not rely on knowing) if the
caller is in 16- or 32-bit mode; and
2)  implementation does not know (and does not rely on knowing) if the
caller is in user or system mode;
This means that there is no need to maintain multiple version
libraries for the four permutations of the two modes.
directly
Library linked code is strewn all over the code space.  Kernel method
allows it to be managed much more efficiently.
Supppose a system locked up because interrupts ended up turned off.
It would be trivial (or near trivial) to identify the culprit with the
kernel approach without having to even rebuild a single application
code.  I cannot think of any other method that is as simple and efficient.
from the
I would advocate against this.
This is not my intention here.
shipped
> as a unit.
Yes, it would have been much more efficient to provide primitives in
this manner that avoids the programmer having to discover one
limitation after another the painful way because the interface is a
procedure call but with the complex implementation idiosyncrasies
hidden from the user's view.
Actually this "play with" comment comes from my training background.
I like the programmers to get experience in working across interfaces
by working on both sides and this method allows them to.
Where the abstraction is useful to many programmers, it makes its way
into the common pool of kernel functions, and becomes part of the tool
set that new programmers can assume already exists and not re-invent
the wheel.
> E&OE?
Errors and Omissions Excepted (or something like it).  It is meant to
say that I have not put through the code through compile or debugger.
My justification is simply that if I put the fully operational code,
there are things in there that will distract one form the purpose of
the example.
However it takes time for me to make the changes, then compile to make
sure there are no typo or silly errors.  So I get lazy and just add
E&OE!  It just helps me provide examples more liberally than I can
otherwise do.
Jaya
>extended a bit
I don't yet see a benefit in using SWI over a function call.  Only
disadvantages.  That is the question here; not the size of whatever we
refer to as the kernal, since presumably that's why we are using user mode
rather than system mode.
>with is
Let's see
function call -> SWI -> Irq  cracker -> function call
vs
function call
As I said earlier I don't consider this an important point.  Remember I'm
one of those who think inline code is a bad idea, I'm not going to quibble
about the extra execution time of a SWI unless maybe you are calling it in
a small time critical loop.  "Premature optimization is the root of all
evil"  Knuth (I think)
>interface.  Also
One line functions tend to lead to a proliferation of functions.  Also
violating the KISS principle.  There is a golden mean somewhere.  This
particular case I would have gone the other way and provided two functions
one for the watchdog and one for the PLL since they are the only items that
make use of that particular mechanism.  The functions would also provide
some additional functionality.  Each function providing a complete
functional unit in keeping with the KISS principle.
>has been
>interrupt
>normally
> > provides.
True, but the question of whether to use a kernal or other set of support
functions is separate from what benefit user mode may have. I ask again
what benefits does user mode have?
>checking is lost?
If your compiler can type check a SWI it's a sight better than any I've
ever seen.
>being in
> > actual function).
?? How is that an issue? We've been talking about user/system
mode.  Compiling libraries for ARM/Thumb is a simple exercise.  Trivial if
your 2 or 3 assembly routines are written to accommodate both.
This gets us back to the question I've been asking from the
beginning.  What is the benefit of running in user mode?
If SWI is available in both that eliminates it as an a benefit of user mode
even if there is an advantage to SWI.
I can see maintaining ARM/Thumb but why maintain system and user versions?
Your solution also needs to maintain both.  You still need a library
>directly
Good Lord, you have got to be kidding.
Two points.
         - What do either of these have to do with user/system modes?
         - How does implementing a kernal help you narrow that region
down?  The only way I can see it is you restrict interrupt setting to the
kernal but even that only narrows it down if you insist that interrupts
always be on when exiting the kernal.  That's not unreasonable in my
opinion but it's got nothing to do with user/system modes.  It also does
absolutely nothing to protect against the far bigger dangers of memory
access outside of the bounds.
>from the
I wouldn't use it either but then I don't build embedded systems that
large.  AFAIK nearly all large embedded systems use this technique.  For
that matter a fair number of them use hard disks.
>shipped
> > as a unit.
huh?
Idiosyncratic is idiosyncratic whether in a SWI or a function
call.  Whether in user mode or system mode.
I was verifying that I understood your grammar here.  I wasn't clear that I
understood it.  It appears I did.  And again how is this different from a
linked library?
>the wheel.
Indeed, but this is a separate question from system versus user mode
benefits.
I do use kernals of support, after all why keep rewriting the same thing
over and over,  but so far I see no benefit to using user mode.  I was
hoping you would provide one but we seem to have veered off into a
discussion of SWI, which is somewhat related but doesn't provide an answer
unless there is a benefit to using a SWI over using a function call.  And
for the size of system we appear to be talking about I fail to see any
benefit in a SWI.
> > E&OE?
Ah, I've just not seen that used before.
Robert
2006-04-19 by jayasooriah
Allow me to get back to the thread proper using top down.
I will start with the list of advantages I have already pointed out as
arising from making the distinction between user and system modes of
operation as follows:
1/  allows codes of different maturity level (system vs user,
operational vs experimental, infrastructure vs application) to coexist
in the (embedded) system in a way that failure of (user) code does not
result in failure of the entire system;
2/  provides isolation between caller and callee in providing the
kernel primitives that will work under variety of conditions,
including that not anticipated by the provider; and
3/  renders the resulting system friendly in relation to probing by
hooking onto kernel primitives without the need to touch user code.
[This helps track down problems of the type that go away when you add
code to the application to watch what happens.]
The tools I listed as useful in achieving the above goals, without
making the system complicated, large or inefficient are:
1/  Inline functions: These behave exactly like a function that does
not have this attribute (for type checking and so on), but at the same
time makes the implementation visible to the compiler (and user).
2/  Inline assembler: This allows target code to generate the
appropriate binary instance of the same source code depending on how
it is compiled (16- or 32-bit mode, interworking paradigm, and so on)
to accommodate style and preference requirements of the application
programmer.
In the context of this, I shall respond to your post by way of annotation.
user mode
If the advantages I listed above does not apply to your scenario, then
I can accept this statement.  I cannot see why the do not though.
> Let's see
> vs
> function call
Remember I'm
quibble
it in
Even taking into account the, I cannot see how to make it more
efficient :)  Probably because I do not like assembler too much!
The fact that a feature or technique can also be misused is (to me)
not sufficient justification to barr its use.
support
See above.
Trivial if
I think you do not appreciate the fact that there is only one instance
of the kernel binary, not multiple variants depending on what mode the
application was compiled in.
I use the ARM primitives designed just for this purpose.  Doing it
otherwise would be more expensive in terms of code and space.
See above.
versions?
If you use ARM/THUMB, you have to maintain two version.  In my method,
you do not need to.
If you do not distinguish system vs user mode, then it does not apply.
If you however chose to, then this comes at no cost in my approach.
This is where I think you have not understood the code snippet that I
hoped will speak for itself.
The kernel is compiled with the interface header and in 32-bit mode.
There is only one instance of the kernel in memory.
The user code is compiled in 16- or 32-bit mode, and only one version
of its binary is in the system.  You can have one application compiled
in 16-bit mode, and another in 32-bit mode, coexist in the same
system, and use the same calls, with only one copy of the binary of
each of these applications.
If I had a penny every time I heard that, I would be rich! :)
efficient.
> Two points.
See benefits listed above.
> down?
Because the kernel handles all interrupt enable and disable
operations, this is where one starts looking for problems relating
interrupts disabled but not enabled thereafter.
No.  I provide the disableInt() and restoreInt() primitives to any
function, whether or not it is running in user or system mode.
There is no restriction that you leave the kernel mode with interrupt
disabled.
does
This is where I ask people to include memory protection in their
selection of targets for their application.
[soap box]
My biggest gripe with LPC family is not so much that it has no concept
of memory protection, but its flash operations are not protected
unlike any other system I have seen or have been told about.  The
absence of CDP gives rise to software causing the hardware to be
unusable in the case of LPC.
[end of soap box]
Jaya
2006-04-19 by Robert Adsett
Nonsense.  If the user application hangs up the fact that the user code is
in user mode but the kernal in system mode won't make recovery easier or
harder.  If the user application sets the output to short a 200A hour
battery through a FET capable of handling a 10A surge the placement of the
kernal will affect things not one whit.
There is zero extra protection available by placing the kernal in system
mode and the application in user mode.
Like what?  The closest example you have provided is ARM vs Thumb.  I don't
buy that as significant.  If you cannot recompile your library you
shouldn't be in this field.
How is that different from a linked library similarly equipped and more to
the point how does the user/system mode deal with it in a way that's
different from not using user mode.
Have they become standard with C99?  If so I'll probably consider them as a
replacement for some macros when C99 support becomes more widespread.
>programmer.
We've already disagreed on this point, no point in going over it again.
>user mode
The advantages listed above seem to everything to do with using a standard
kernal/support library and nothing to do with system/user mode.  There is
nothing I see there that has to do with CPU mode.
> > Let's see
> > vs
> > function call
>Remember I'm
>quibble
>it in
Taking into account the what? And who said anything about assembler?
My point exactly.  Just because you can turn something into a function
doesn't mean you should,  I've gone down the road you suggested with
AtomicFeed and come to the conclusion it offered no useful increase in
abstraction, it just obscured the intent of the code.  You've obviously
come to a different conclusion.
>Trivial if
You're right I don't.  I generally don't switch modes on a regular
basis.  On the LPC2000 family I don't see a reason to use thumb unless
there is a space issue.  I would be surprised to find projects that did
switch application modes often enough for this to be an issue.  I'd also be
very worried about their quality.
A compile switch is expensive?  Dammed if I can see how a SWI take less
space/time than a call.  Or how switching modes reduces code space.
>versions?
>you do not need to.
Well I see no need to ever design a system where one day I use ARM and the
next day Thumb.  And it is quite possible to have one application require
an ARM kernal for performance reasons and another to require a Thumb kernal
for space reasons.  The same reasons you would need to choose between the
two in the linked library case.  If you need to maintain two variants for
one case you are likely to need to for the other.
Ah, maybe I see where the difference is.
Maybe you are working in an environment where you are supporting a
multitude of simultaneous projects.
I and I suspect most others here work a little more serially.  Any one
project is only going to use a single mode. The time spent to compile the
support library appropriately is insignificant in this context.  Each
project must have it's own support library/kernal carried with it since
upgrading it will require retesting the application.
Of course
OK, now we are getting somewhere.  You are talking about the large system
similar to the RAM loaded case I was talking about in an earlier
post.  Different world entirely.  This would be possible to do with a jump
table but that's the same thing in less convenient clothing.  Here I see an
advantage and a big one.  It also explains why you'd want a unified image
for the kernal. All the applications I need to deal with run a single
application.  Multiple threads sometimes but a single application.
> > down?
OK, I can see what you are getting at,  You can instrument the function/SWI
calls.  That's how I would normally implement a disable/restore pair in any
case.  That still leaves the issue of finding the mismatched pair.   An
appropriate trigger on a trace could narrow it down in a hurry though.
I just normally refer to my support library as a support library and
reserve kernal for when I bring in task switching/threads whether
cooperative or preemptive.  Different word choices.
I'd like to have memory protection, but I've yet to see a small inexpensive
microcontroller with memory protection.  Actually I've yet to see a
microcontroller (IE only internal memory) with memory protection but I
freely admit there are many micros I've not perused.  Generally I/O is my
first consideration.
Robert
Robert,
Given my aim is to present an alternative view, but not to impose this
on anyone who does not appreciate its merits, I like pointing out only
what I believe has been grossly mistated or incorrect:
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@...> >
code is
easier or
> harder.
[example deleted]
If this were true, the notion of privilege or levels of privilage in
operating systems would meaningless.
system
You may not see them, but I do and we just have to agree to disagree.
[I tend to work towards clients requirements and not redefine them.
When they say they want to do this, I just show them how to.]
Jaya
2006-04-19 by brendanmurphy37
Jaya,
Robert is not incorrect.
The fact the LPC2k has different operating modes does not mean it
has the capability of implementing a privileged mode operating
system. Hence your comment "If this were true, the notion of
privilege or levels of privilege in operating systems would
meaningless" is itself meaningless.
The purpose of such operating systems is to have fortress-like walls
around the operating system/kernel facilities, memory and I/O space.
These walls are built using privileged processor modes and some form
of memory protection. The memory protection bit is absent on the
LPC2k.
The purpose of mechanisms like software interrupts is to provide a
controlled gateway through these walls. If these walls don't exist
(and they don't on the LPC2k, as it has no memory protection
mechanism), any application can simply bypass the gateway and wreck
havoc with the system. In other words, your carefully constructed
gateway has no functional use whatsoever (as Robert has pointed out).
The software interrupt mechanism has no protection in itself: it is
simply a mechanism to gain access through a protected barrier.
You are of course quite free to implement whatever modes and
features you want. However, if you think that by implementing
software interrupts and making use of user mode somehow offers you
any degree of protection, you are deluding yourself (and from what
you say, your clients). It simply isn't the case.
If I've stated anything factually incorrect above, I'm happy to
correct it.
Hopefully though, this will clarify matters, and prevent yet another
interminable discussion.
Brendan
wrote:
> Robert,
this
only
> --- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@> >
> code is
> easier or
> > harder.
> [example deleted]
in
> system
disagree.
> Cheers,
> Jaya
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
<brendanmurphy37@...> wrote:
> Jaya,
> correct it.
Oh no!  Not again!
Did I not tell you not address me Brendan?  Try it.  It is not hard to do.
Thanks for understanding.
Jaya
I wasn't addressing you: I was posting a message on an open forum to
correct some misinformation you posted on that same open forum.
As a matter of courtesy, I put your name at the top of the post to
clarify the exact message I was responding to: I'm happy to stop
doing this if it upsets you.
Best wishes
Brendan
> <brendanmurphy37@> wrote:
> > Jaya,
> > correct it.
> Oh no!  Not again!
to do.
> Jaya
>code is
>easier or
> > harder.
>[example deleted]
In those systems the privilege levels are supported by HW which restricts
access.  Sometimes as 'simple' as a MMU but often with restrictions on I/O
access as well.  Sometimes with restrictions on the way pointers to memory
can be passed between privilege levels.
W/O this hardware support, which is not present  on the ARM
microcontrollers we are talking about, there is indeed no protection
offered.  Indeed there were Unix variants for the PC before the protection
features of the '286 and they did suffer from this flaw.  User programs
could bring the system down so that a hard reset was required (system
programs sometimes caused similar problems but since most of them had been
tested on systems with MMU that would core dump in such an event most such
bugs had been stamped out) uCLinux will have the same issue.
That doesn't mean that in an environment with multiple applications on the
same processor there isn't any benefit in having a common 'shared' library
or kernal.  That just isn't the case we've been talking about,  at least I
haven't, but rather the more typical microcontroller case of a single
application on a microprocessor.
I work towards customer requirements as well but I do warn them when they
suggest something that's physically impossible.  And without hardware
support you cannot prevent an application bug from bringing down a
microcontroller.
There is one exception to this HW requirement and that is when all of the
programs access and I/O is mediated by SW by running in an
interpreter.  Essentially in that case the necessary HW is simulated.
With good design, appropriate tools and reviews you can avoid getting the
bug there in the first place but user/system mode on a LPC2000 isn't going
to get you any closer than a well designed library.
Robert
2006-04-20 by jayasooriah
Robert,
I think you are mixing privilege with protection.  I refer to
privilege as a policy without reference to mechanisms to enforce this
policy.
Whether or not you need protection to enforce a particular policy
depends on requirements:
* In the context of general purpose operating systems (like that on a
desktop), the requirement is that policy be enforced assuming the
tasks are hostile.
* In the context of embedded systems, the OS (or kernel) assumes that
the tasks are cooperative -- that they are making a kernel call not
because they do not have the means to do this on their own.
Just because a task can do anything it does not follow that having a
task do whatever it can do without reference to other tasks (current
and in the future) is a good idea.
For the above reason I do not find your argument relevant to the
original proposition: to recognise that even in embedded systems, the
notion of user vs system can be exploited to make the system easier to
describe and manage.
Jaya
restricts
on I/O
memory
> offered.
2006-04-20 by Robert Adsett
Where on earth did you get the idea I thought otherwise?
Yet again, this has nothing to do with system/user mode.  It just describes
a well designed library/kernal.  I agree, have always agreed, that a well
designed kernal with behaving tasks is a good idea.
You are arguing against a position I haven't taken.  A division of
responsibilities is a good thing,  A random sprinkling of I/O and control
code would, I agree, be a bad thing.  Limiting control to specific areas is
just good design.
The question is: what extra advantage running in user mode and making calls
to a system mode kernal provides over an application running in system mode
making calls to a system mode kernal?
I see no advantage just from having two different modes w/o any distinction
between them.
If you use SWI as the link mechanism,  you can in either case but it's a
natural fit with the user/system case, then I see the following breakdown.
SWI advantages
         decouples the calling routines from the implementing
routines.  This shows as an advantage in systems that have multiple
applications loaded or have applications loaded into memory at runtime
since they can share a common kernal implementation.
         Most natural implementations naturally provide the library as a
single block of memory.  An advantage if you are loading multiple
applications. perhaps but otherwise..?  Could be done straightforwardly
enough with the linker if it was really desired, I've done a similar thing
on a system with a fragmented memory map.
SWI disadvantages:
routines.  The normal type checking is broken across the SWI/IRQ
barrier.  Presumably a well written implementation of the stub library on
the caller side will substitute but it is still quite easy to change either
the caller stub or the implementing routine independently and break the
interface.  The same can happen with a linked library of course but you do
have that extra level of type checking in the interface.
In either case a well designed application will usually segregate I/O
functionality from processing functionality and base support routines will
be separate again.  Much of the base support is reusable on multiple
systems, some of the I/O functionality may be.
For a system with multiple applications I'd definitely consider SWI.  If I
used SWI theres a good chance I'd run the app in user mode as it's a
natural fit.  For a standard single application system though there is no
advantage(1).
My original question was prompted by the suggestion that I thought I saw in
tour post that user mode provided some significant protection.  If all it
is turns out to be that it fits naturally with SWI that's fine.  I just
don't see that being an advantage for your typical single application
microcontroller embedded system.
(1) There is a single application type I thought of while writing this that
would benefit from using SWI as a jump table.  That's the case where a
single application runs on multiple HW platforms and relies on the HW
platforms kernal to provide functionality that may be implemented
differently on each one.  Not the type of application I was thinking of though.
Robert
2006-04-20 by 42Bastian Schick
Robert Adsett schrieb:
I jump in late, so sorry if I repeat an arguement:
Even if there is no MMU/MPU which restricts access to memory, one vital
resource can be restricted: Interrupts.
In USR mode, you cannot modify the interrupt-bits whereas in SYS mode
you can.
Means, running tasks in USR mode lets the OS control the disabling of
interrupts.
42Bastian
 If I
> natural fit.
Although I do not know what you mean by "application" I do not
disagree with the above.
> advantage(1).
What you mean by "single application system" is important.
I prefer to look the "application" running on an embedded system as a
set of independent and cooperating tasks, where a task in an entity
that has a own state (stack), and which it returns to when it is
suspended (for any reason) and then resumed.
If by "single application system" you mean the system comprises of
only one task, then any monolithic system approach would do, and there
is little value in separating the things that the task does into
different baskets.
I did not think that any of the things that participants here are
doing with the LPC falls in the latter category.  This is why I
started with the SWI approach to my simple example atomic feed of
watchdog timer.
It does not matter to me what term is used to describe what happens on
the two sides of the SWI fence.  It could well be public vs private,
system vs user, kernel vs user, or infrastructure vs application.
Jaya
making calls
system mode
> you can.
> interrupts.
Thanks Bastian for pointing out Robert's questions I missed in my most
recent response.
My understanding of Robert's position (apologies if I misunderstood)
is that because there are other ways a rogue task running in user mode
can compromise the system why bother running any in user mode at all.
Given if one uses the SWI interface, it comes at no cost, I prefer to
question why not.
I can see why some chose to run all tasks in user mode to harness not
only the direct privilege differences you point out, but also ripple
down effects onto other things for control for coordination purposes.
Accepting embedded ARM users in general have different requirements,
my personal experience has been that that LPC users appear to have
somewhat different requirements compared to users of other variants.
Especially on on matters related to security, protection, and maybe
even watchdog requirements.
Jaya
Just as Jaya and I were winding down to a conclusion :)
> calls
> mode
>you can.
>interrupts.
I suggested that once as a possible advantage.  Jaya assured me that the
interrupt disable/restore was exposed as a function across the barrier in
his implementation.  That would rather negate the advantage.
I can see that (restricting the ability to disable interrupts) as an
advantage, especially for larger systems.  When I asked the question
originally it hadn't occurred to me to only disable interrupts in system
mode.  For most of the stuff I do I don't see it being worth the extra
trouble but that does make the distinction useful for a wider variety of
projects.  Of course once you had it set up like that for one project it
would be easy to carry across to smaller projects at little or no cost.
Robert
>question why not.
AHA!  Why didn't you say so ;)  I was under the impression the drive was
the other way around.  You had decided on user/system mode because of some
protection that user mode provided and that led you to use SWI.  If you are
using SWI then yes it makes a lot of sense to do it from user mode.
I was trying to figure out what that protection was.
That suggestion I made a few days back of reserving interrupt disabled code
just to the kernal is intriguing.  I'll have to noodle around with that a bit.
There's a lot of people here from small micros. Particularly the MSP430 for
some reason.
Robert
2006-04-21 by Robert Adsett
> > advantage(1).
Much the same as I do. A single application would be a single loadable
entity.  It could be one or more tasks.  But the threads of execution are
closely related.  There is a bit of a grey area between a single and
multiple applications, more so than there used to be.  Tasking if present
could be co-operative or pre-emptive.
The key differences are
         In a single application the threads are usually fairly tightly
coupled.  In a multiple application environment they are more loosely
coupled.  Not very precise, I know.
         In a single application the code for the tasks/threads are loaded
into the flash as a single unit. In a multiple applications the pieces can
be loaded separately. The latter case practically requires some sort of
BIOS/Kernal communicated with in some indirect fashion like SWI.
Indeed I have not seen a real time kernal (as opposed to a heavier real
time OS) that wasn't supplied as a linkable library.  Even ecos which is a
relative heavyweight is, I think,  a linkable library.  OS/Kernal is a
distinction I maintain but the distinction seems to have lost much of it's
meaning over the years with items like uCOS etc. referring to themselves as
RTOS's
As I said though, I am intrigued by the thought of restricting interrupt
off periods to a user mode protected kernal.  I don't find leaving
interrupts off to have been a big problem in my development but I am in
favour of anything that will protect me from myself, especially if it's
free.  I just have to figure out what exactly the benefits of restricting
that access will be compared to the cognitive cost of a decoupled interface
and loss of type checking across the SWI barrier.
>watchdog timer.
A monolithic single application.  I suspect there are.  I've used the LPC
to quickly prototype a monolithic app. It was overkill for it but for a
prototype it allowed a rather quick assembly of components.  There was a
time people used DOS for single monolithic embedded applications.  Actually
I suspect some people still do.  I would be surprised if the LPC family
wasn't being used in the same fashion.
>Jaya
>Yahoo! Groups Links
Just as a matter of information.  It may give some insight into some
portion of the membership here.  I doubt I'm unique in any of these
viewpoints although I may well be in a minority.
         Security - Don't need it.  To copy my SW they also have to
(generally ) copy the HW.  It's a lot easier to tell when they've done
that. For many products it's as easy to redesign as it is to copy.  Others
have different requirements although I suspect that in general people
overestimate the value of their SW.  Hey it's their sweat equity they have
every right to value it.
         Protection - I'll take whatever I can get for a reasonable
price.  Reasonable depends on the project. Ideally I'd like to restrict I/O
and memory access ranges to specific process for no extra memory or dollar
cost. :)  Likewise ESD and EMI/EMC protection,  Oscillator watchdogs etc..
         Watchdog - Depends on the project but for most I want a
watchdog.  It's not there as a normal guard against program bugs and such
but as a last attempt to get back to a safe starting point.  It might catch
items the ESD discharges that make it through the hole the customer put
into the enclosure with a forklift and changed the short timing loop into
an infinite loop;)  It certainly should never be part of normal operation
and it's one of the very last pieces put into place.
Robert
2006-04-22 by jayasooriah
> >question why not.
I think I did but not using these words.   I wish I had made this clearer.
So as not to risk keeping a thread going well beyond its use by date,
I will take up your follow on points as a separate thread.  Hope you
do not mind.
I will follow the "was" protocol to link the threads, and you (or
anyone else) responding can then strip the "was" component :)
Jaya
PS:  Bit snowed under at the moment, but wont be long.
