Lpc2000
Virtual Com with IAR
2006-04-10 by ebreuilly
I download the virtualcom.zip file from keil and I try to compile it
with IAR with LPC2148 IAR board. There are many difference between Keil
and IAR source (ex __irq doesn't exist in IAR) so I can't compile this
correctly.
Do anyone have already compile this example with IAR ?
Thank you for your help,
Loïc CHEVALIER
Re: [lpc2000] Virtual Com with IAR
2006-04-10 by Robert Nelson
> correctly.
> Lo\ufffdc CHEVALIER
Well to get you started, add this chunk of code to the USB_Init function
in the "usbhw.c" file after the initializing of the PCONP setting.  This
will turn on the USB connect transistor on the LPC-2148-E board, that
isn't present with the keil board.  This will allow you to build the
software with Keil's evaluation version and get you started on
development.  For the moment there is no direct port to IAR.
" /* Addes IAR LPC2148-E compatibility */
  #define P0_23 (1<<14)	 /* Enable Vbus */
  #define P0_31 (2<<30)	 /* Enable USB Connect */
  PINSEL1 = (P0_23 | P0_31);   /* Enable Vbus and USB Connect */
*/Robert Nelson/*//
Applications Engineer
robert.nelson@...
Re: Virtual Com with IAR
2006-04-11 by ebreuilly
--- In lpc2000@yahoogroups.com, Robert Nelson
<robert.nelson.work@...> wrote:
it
between Keil
this
> > correctly.
> > Loïc CHEVALIER
function
This
that
> Regards,
> */Robert Nelson/*//
> robert.nelson@...
Thanks for your answer, now the USB seems works. The yellow Led
become ON and the HID class is create in peripheric PC, but not com3
& com4. So I can't test this exemple with an hyperterminal.
If you have any idea for help me ?
Thank you in advance,
Loïc CHEVALIER
Re: [lpc2000] Re: Virtual Com with IAR
2006-04-11 by Robert Nelson
> Lo\ufffdc CHEVALIER
On my system, as soon as the USB cable was plugged in i loaded the
virtual comm drivers from the build directory, then two com's (com7 and
com8) are created, but the system needs to be rebooted after first
install.   After that i had no issues loading hyper terminal on com8
(usb) and communicating to another hyper terminal on com1 using the On
board RS232_1 connector.  ASCII data would transfer just as easily.
Robert Nelson
Digi-Key
robert.nelson@...
