Lpc2000
LPC2103.h file from Keil
2006-04-11 by rggmns
Sorry about de last post.
It seems Keil has replaced the old LPC2103.h with a new one.
This last version generates correct addresses.
The code is not running, included the "very difficult code".
#include	<lpc2103.h>
void	main()
	unsigned long i;
	unsigned long j=0x0000ff00;
	IODIR=0x0000ff00;	//set pin direction
	while	(1)
		i=IOPIN & 0x00ff0000 + 1; //delay value
		IOCLR=j;                  //toggle I/O pins
		j=~j;
		IOSET=j;
		while	(i!=0)            //time delay
		i=i-1;
It runs fine on the LPC2138.
What is wrong?
Me again
RE: [lpc2000] LPC2103.h file from Keil
2006-04-12 by Andrew Berney
I assume these pins are set as GPIO then? (We can't see Pinsel here).
Also, what do you actually mean by 'not running' - it strikes me you could
effectively be toggling the pin outputs rather quickly depending on your
inputs.
Andy
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of rggmns
Sent: 11 April 2006 17:29
To: lpc2000@yahoogroups.com
Subject: [lpc2000] LPC2103.h file from Keil
void	main()
	unsigned long i;
	while	(1)
		j=~j;
		IOSET=j;
		i=i-1;
What is wrong?
Me again
Yahoo! Groups Links
Re: LPC2103.h file from Keil
2006-04-12 by rggmns
Hello,
problem is solved.
It's the philips manual that sucks.
It does not explain in de pin description that p0.14 is used to select
between run mode and isp mode.
Without proper interfacing my controller never got in the run mode,
but stayed in the isp mode.
Problem is solved.
Greatings
could
> inputs.
> Andy
> Of rggmns
> void	main()
> 	unsigned long i;
> 	while	(1)
> 		j=~j;
> 		IOSET=j;
> 		i=i-1;
> What is wrong?
> Me again
