external memory on LPC2214
2006-04-25 by Timo Bruderek
Hi All !! I am a student at University of applied science Augsburg and currently working on my Final Year Project. It is a Webserverboard based on a LPC2214 with 4MB external SRAM to be able to run uCLinux. I build the board and tested the external memory using a little test routine. I wrote a value to a pointer in the external SRAM and read it back. Everything looks ok so far, but if i load ucLinux in the SRAM, i get an interrupt for an undefinded intstruction. If i use OpenOCD and have a look at the memory, i saw, that the content is not right. The upper half-word is on a different address the the lower half-word. It looks like that the upper half-words have on offset. If i write to memory using a pointer in a C-routine, everthing looks ok !! Even if i check the content of the memory with OpenOCD. !! Has anybody an idea, where i can have a look for the error ?? Thanks, Timo
