LPC2129 Interrupt Problem
2006-04-25 by meepmeep24
Hi, I am using an LPC2129. My VPBDIV is set to '1'. I have been using EINT2 without a problem. I am able to set EXTPOLAR and EXTMODE without a problem. I am aware of the known errata about VPBDIV and EXTPOLAR so I set EXTPOLAR like this: SCB_VPBDIV = 0 // first you set VPBDIV to 0 SCB_EXTPOLAR = 0x4; // then set your EXTPOLAR bit SCB_VPBDIV = 1; // now, set VPBDIV back to what it originally was Life is good when I do this. The problem is when I want to use EINT0 and when I set EXTPOLAR for EINT0 to 1 my system appears to hang and I get no more serial port output. I set EXTPOLAR for EINT0 like this: SCB_VPBDIV = 0 SCB_EXTPOLAR = 0x1; SCB_VPBDIV = 1; .. but when I run my code I lock up. I can set EXTPOLAR to 0x2, 0x4, or 0x8 but NOT 0x1. If I comment out these lines my code will continue. Can someone help me with this? Am I not doing this correctly? Please help me set EXTPOLAR to 1 for EINT0 when I have a VPBDIV of 1. Thanks, Todd
