Lpc2000
UART current limits
UART current limits
2006-04-27 by Andrew Berney
Does anybody know if the UART TX line on the LPC2129 is capable of supplying
2.2mA, as I need it to drive an optocoupler for isolation
Cheers
Andy
Re: UART current limits
2006-04-27 by theothervmax
> Cheers
> Andy
I haven't got the datasheet right for this part.
If you have one you may search there for "IOH" and "IOL" in "Static characteristics" section.
Most likely the minimum values for these parameters will be "-4 mA" and "4 mA" accordingly, as for LPC2106 and LPC2148 for example.
Well, the short answer is "yes".
Max
Re: [lpc2000] UART current limits
2006-04-27 by Peter Jakacki
Yes, I have implemented isolated coms using HP2531s via 220R resistors
without any problems. Vol/Voh are not as relevant as Iol/Ioh when
driving leds and optos. The values given in the datasheet of 4ma just
means that you can draw that much and still have the output voltage
within logic levels *if* you were also driving other logic inputs.
  In your case it doesn't matter if the voltage is not at a logic level
as long as it supplies the current required (within limits). CMOS
outputs are very forgiving when driving low-resistance loads, just don't
expect it to maintain logic highs and lows if you push it.
*Peter*
2006-04-27 by Mukund Deshmukh
What is maximum baud rate achievable in isolated RS232. We are unable to get
more than 38400.
Best Regards,
Mukund Deshmukh.
Beta Computronics Pvt Ltd
10/1, IT Park, Parsodi,
Nagpur-440022
Cell - 9422113746
2006-04-27 by Herbert Demmel
>more than 38400.
That depends very heavily on the optocoupler you use; some of them can be
used for 9600 baud only, some are very fast. Have a look in the specs of
the couplers (I currently do not have a recommendation for you).
Herbert
>Best Regards,
>Mukund Deshmukh.
>Nagpur-440022
>Cell - 9422113746
>SPONSORED LINKS
><http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PMg>Microcontrollers
><http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ>Microprocessor
><http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5quAgrl5w>Intel
>microprocessors
>YAHOO! GROUPS LINKS
>    *  Visit your group "<http://groups.yahoo.com/group/lpc2000>lpc2000"
> on the web.
>    *  To unsubscribe from this group, send an email to:
> <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>lpc2000-unsubscribe@yahoogroups.com
>    *  Your use of Yahoo! Groups is subject to the
> <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
demmel products
Radnitzkygasse 43
A-1100 Vienna / Austria / Europe
Voice: +43-1-6894700-0
Fax: +43-1-6894700-40
Email: dh@...
WWW: http://www.demmel.com
> more than 38400.
That depends on your choice of opto, drive and load resistors more than
anything else, these are your limiting factors. Assuming the opto is
fast enough and sensitive enough (Tplh/Tphl and CTR) then you should
drive the optos as hard as you can as you will need as low a value
collector load resistor as possible to achieve a fast low to high on the
opto collector ...... and so on.
??? That's ok, if you want speed, don't use unbuffered optos, go for
something with a logic buffers built-in, these are designed for speed.
*Peter*
Can you suggest some opto coupler for 115200 baud rate?
Best Regards,
Mukund Deshmukh.
Nagpur-440022
Cell - 9422113746
2006-04-27 by donhamilton2002
http://www.analog.com/en/prod/0,2877,ADuM1201,00.html
Max. Data Rate 	25Mbps
http://www.analog.com/en/subCat/0,2879,767%255F827%255F0%255F%255F0%255F,00.html
2006-04-27 by David Hawkins
>>more than 38400.
Analog devices makes a product line called iCoupler. It can
be used as a replacement for optoisolators (they're magnetic
isolators). They operate up to may Mbps. Check out this link
or Google for iCoupler and it'll show up.
I haven't used this for rs232 links, but I don't see any reason
why it wouldn't work. Maxim also has some isolated parts.
Cheers
Dave
