Lpc2000
JTAG programming
JTAG programming
2006-05-01 by ovidearistide
I am trying to program my flash memory via the JTAG interface.
However, I am unable to find enough documentation on the JTAG interface.
Can anyone give me a kickstart?
I am trying to flash in two ways:
1) From the flash itself (Firmware update).
2) Externally (initial flash).
Ad 1)
This is the most important one for me.
To achieve this I need to execute my firmware update code in RAM (and
make sure that interrupt vectors and such reside there as well).
I believe I have to use IAP. JTAG is also a serial interface, but I
don't think it is possible to connect ISP and JTAG (UART only). IAP is
not really a problem, but I do not know how to connect my IAP
implementation to the JTAG interface. So basically: How do I copy data
over the JTAG interface to RAM?
Ad 2)
I can use the Philips ISP flash tool to flash via the UART interface or
any commercially available tool via the JTAG interface. But I want to
be able to batch this process (and maybe configure it). I must use the
JTAG interface and I am the only budget available. :-)
Thanks in advance for any help,
Greetz,
David
Re: [lpc2000] JTAG programming
2006-05-04 by Tom Walsh
ovidearistide wrote:
>Hi,
>Ad 1)
In itsy-bitsy steps.  JTAG is merely a series of very long shift
register chains.  These shift registers allow access to the
micro-internals of the CPU.
Historically, JTAG was devised to meet two needs:
1. Auto Test Engineering (ATE) was faced with higher and higher density
boards that they needed to test.  The old "bed of nails" vacuum fixtures
were no longer able to work on these board.
2. Software / Hardware engineers found it difficult to use clumsy pods
to either clamp onto or replace the new surface mounted CPU chips.
So, JTAG was born.
There is a lot of information regarding JTAG on the net, it is an IEEE
standard.  You can purchase the document, or, find various tutorials +
docs for free on the net, or, you can take apart / work with JTAG
software as found on sourceforge and other sites offering OSS.
>Ad 2)
Well, you can save money, but you will spend time, lots of it, writing a
TAP controller to run the JTAG.
TomW
