Brendan
Number of issues with scheme proposed so far.
1. For parts with an enhanced bootloader, if Philips declared CRP
address 0x1FC to be a reserved address that may only contain 0x8765
4321, 0x1234 8765 or default flash erase value of 0xFFFF FFFF and
that anything else may lead to unpredictable results then Philips
does not have to document anything further, no matter what bootloader
enhancements are made. This would give time to iron out issues,
prepare documentation and even withdraw the enhancement if so decided.
2. For a bootloader upgrade to existing LPC2xxx parts the same
declaration would apply
3. Even if it was ensured the range of values in address 0x1FC all
resolved to undefined ARM and Thumb instructions for the purpose of
bootloader enhancement this is not good enough because it is
legitimate to use address 0x1FC to contain any data value.
4. In a sense Philips has already sacrificed address 0x1FC. Given
that there are two legitimate data values that cannot be placed at
address 0x1FC if CRP is not to be enabled (0x8765 4321 and 0x4321
8765).
4. The single biggest problem is the potential to lock an LPC2xxx
part up permanently without an erase mechanism. However Philips would
be covered by the simple statement 0x1FC is a reserved address that
can only contain three values and that anything else may lead to
unpredictable results including locking up the part.
5. The single biggest issue is the pin 0.14/DCD issue that currently
requires a hardware solution. This can be solved in software by the
proposal. The proposal also allow pin 0.14 functionality to be
relocated.
6. With regard to other enhancements enabled by the proposal (such as
independent bootloading using IAP and interrupts) none of them
require the proposal. Bootloading through USB or any other data
source can be done right now. The proposal simply makes programming
and management slightly easier.
Basically it is just a proposal that would provide extra flexibility.
I don't need it as I have no use for the DCD pin. I am not going to
make it a cause and don't really want to spend time on making it a
cause! There are marketing advantages. ATMEL gets a lot of mileage
form its AVR bootload sectors with some extra hardware issues thrown
in!
In summary
- The proposed bootloader enhancements are easy to implement, add
minor programming convenience and can relocate the bootload pin.
- Philips does not need to provide any further documentation with
such an enhanced bootloader other than stating address 0x1FC is
reserved and can only contain three values.
- Philips has already sacrificed address 0x1FC anyway from some
legitimate data values.
- There are marketing advantages.
John Heenan
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
<brendanmurphy37@...> wrote:
> John,
> Interesting idea. Although simple in theory, I think you're
actually
> asking quite a lot of Philips. Just think of all the documentation
> that would have to be updated to reflect the change. This all takes
> time, effort and cost that would have to be justified (ongoing
costs
> as well in terms of updated training, support materials etc.)
> Can you give some specific examples of what features and functions
> could be implemented if the loader were changed as you suggest? I
> think it would help both others and Philips to support such a move
> if there was more information on what could be achieved by such a
> change.
> Brendan
> --- In lpc2000@yahoogroups.com, "John Heenan" <l10@> wrote:
> > Below is a draft of a possible sensible formal request we could
> make
> > to Philips with regard to bootloader enhancement. It is simple
and
> > practical.
> > If Philips agrees we can use interrupts by copying interrupt
> > instructions and constant addresses to the start of RAM and
> setting
> > MEMMAP to RAM mode. We can still use IAP features of the
> bootloader.
> > There is no sense in replacing the bootloader if you accept it
> does
> > its job as is: why chuck IAP when it works great and can be used
> to
> > advantage in an enhancement, such as with USB enhanced
bootloading?
> > John Heenan
> > Dear Philips
> > This is a formal request with regard to the bootloader of the
> LPC2xxx
> > series of microcontrollers.
> > We are requesting a small enhancement to the bootloader whose end
> > functionality is to
> > - give us an option to bypass the pin 0.14 test by the bootloader
> > when there has been an external reset
> > - perform our own bootload tasks taking advantage of IAP if we
> want to
> > - rejoin the bootloader informing the bootloader what we now want
> it
> > to do or what we have done
> > For existing LPC2xxx parts with flash based bootloaders we are
> > requesting you make an upgrade to the bootloader available to us.
> > For the bootloader to decide to bypass four items of information
> are
> > necessary
> > 1. Whether to bypass
> > 2. Where to bypass to (in supervisor mode expecting ARM
> instructions)
> > 3. Where we need to return to if we want to return ('BX LR' is a
> good
> > option)
> > 4. What should be specified in a register on return
> > On return perhaps R0 could have a value to indicate one of the
> above
> > - conduct a normal pin 0.14 test
> > - bypass pin 0.14 test as if test is true
> > - bypass pin 0.14 test as if test was false
> > - we have used IAP functions to conduct our own bootloading:
> please
> > restart the bootloader as if there was an external reset
> > Currently address 0x1FC is used to store the CRP value. If this
> value
> > is 0x8765 4321 (or 0x4321 8765) then Code Read Protection (CRP )
is
> > enabled.
> > If CRP is not enabled then we request that if the CRP value is
> 0x4321-
> > --- or 0x----4321 where ---- represents four hexadecimal digits
> then
> > these hexadecimal digits be used to decide a multiple of 4kB to
> jump
> > to. For example if the CRP value is 0x4321 001E or 0x001E 4321
> then
> > this is interpreted to call address 0x1E (decimal 30) times 4kB =
> > 0x0007 B000. This is the start of sector 25 on the LPC2148 and is
> the
> > start of the last 8kB of flash on the LPC2148.
> > Given that no flash sector can be less than 4kB for erase
purposes Show quoted textHide quoted text
> > (they are either 4kB or 32kB) then there is no advantage in
> > specifying a finer resolution than 4kB as a multiple for call
> purposes
> > This request has the support of the following members of the
> LPC2000
> > newsgroup on http://groups.yahoo.com/group/lpc2000/
> > John Heenan
> > Add your name if you support such a request!
