Lpc2000
Keil JTAG with Embedded Artists board
2006-05-03 by Sutton Mehaffey
Anyone out there running the combo of Keil's compiler and JTAG with
Embedded Artists 2148 board and prototype board?  I can and have been
using Philips Flash Utility to download code to the EA boards and it
works perfectly.
However, now that I am trying to debug software, I can't seem to be
able to debug using Keil's JTAG.  Is there a compatibility problem?  I
get 'Memory Mismatch' Errors just about every time I go into Debug
Mode.  I'm using the Keil Eval Kit Version 2.40a with uVison 3.21.  In
this instance, I'm simply trying to 'debug' the Keil sample program
'Blinky' to get a feel for the debugging process.
Here's an example Error from the loading process of Blinky.hex:
At 53% loading, the message 'Memory Mismatch', Address 0x00000118,
Value = 0x03, Expected = 0x01.  Also in the compile line, there is a
error 125: AGDI: memory write failed (0x00000118).
Is there something I'm missing on the setup?
Sutton
Re: Keil JTAG with Embedded Artists board
2006-05-03 by kristianstad2001
Hi Sutton,
Please check with Keil. They have published a patch for their JTAG
interface - it has to do with the reset signal.
I do not know if this is the problem in your case, but you should
definitively have the patch.
Another thing to try is to decrease the JTAG clock frequency.
Best Regards,
Anders Rosvall
Embedded Artists AB
been
it
> works perfectly.
problem?  I
3.21.  In
a
> Sutton
