Lpc2000
Bootloader minor enhancment suggestion
2006-05-01 by John Heenan
I suggest a formal request be made to Philips with regard to their
bootloader for the following minor enhancements.
None of these suggestions are strictly necessasry. The suggestions
would simply make working with the LPC slightly easier. The
suggestions are to enable a programmable flash space and interrupt
remap location modelled on the ATMEL AVR system while retaining their
current bootloader (which I have never had a problem with) which
would of course carry out the required security processing before
handing over control. The current IAP features could still be called.
For example the CRP flash memory location could have bits read
similar to ATMEL fuse bits to decide
1. size of a special 'boot sector' at top of flash (AVRs typically
allow four fixed sizes)
2. whether interrupt vectors and so startup remaps to the start of
the special boot sector.
It would also be healthy to allow MEMMAP have another value to
indcate another remapped location for interrupt vectors.
There is clearly a lot of motivation for independent bootloaders. It
would make my programming tasks slightly easier. It could also solve
another problem by allowing independent assignment of the 'boot load'
pin, instead of pin 0.14 (which interferes with DCD input is used and
can be solved currently with the use of a hardware single logic OR
gate).
John Heenan
Re: Bootloader minor enhancment suggestion
2006-05-01 by Danish Ali
Hi John,
I think you have a good point. If we can agree how the bootloader
should be improved, and it remains compatible with existing
hardware*, perhaps they will find the time to do it.
One point though: I think the MEMMAP is done in hardware,
location 0xE01FC040 on lpc2292. So I don't see how a
bootloader rewrite can add an extra option here.
(It makes no sense to tell the bootloader to select the
RAM vectors since RAM could contain rubbish).
*this constraint could be a serious limitation. But Philips will
not want to break products made to their existing data sheets.
Danish
> gate).
> John Heenan
Even without MEMMAP modifcation we could still use interrupt vectors!
You are right to clarify the MEMMAP point, although I had meant
modifying whatever is behind MEMMAP at the register action level
also. While memory remapping is implemented with pure hardware, the
hardware required is minimal.
Without an additional MEMMAP option it is still possible to use
interrupt vectors as long as no interrupt handlers within the
bootloader are required after main application start. Bootloader
interrupt instructions and their load addresses can be copied to RAM
before the bootloader enables interrupts with MEMAP set for RAM
interrupts. Of course these RAM locations would be overwritten after
main program start.
In fact even the above issues can be worked around by saving the
start of RAM on the stack, as well as the contents of VIC registers,
if a rentry into a bootloader function wanted to use interrupts.
The attraction of a bootloader code only modifcation approach is that
we could upgrade our existing parts.
Think of it: USB bootloaders on our existing LPC214x parts that we
write ourselves!  Bootloader pin on whatever port we want or none at
all! Telling whiners to go away and produce something useful!
John Heenan
--- In lpc2000@yahoogroups.com, "Danish Ali" <danish@...> wrote:
> Hi John,
> Regards,
> Danish
their
suggestions
interrupt
their
called.
typically
of
It
solve
load'
and
OR
> > gate).
> > John Heenan
2006-05-02 by jayasooriah
I can see why Philips may not be in a position to acceed to this request:
1/  This requires hardware change to flash blocking.
2/  The boot sectors (I have seen) appear pretty full.
Unless they radically change their boot loader structure to something
like SILL (which is 2600 bytes), they are not likely to be able to get
their boot loader down in size without removing a lot of (extraneous?)
functionality.
Jaya
PS:  I am not saying the request is unreasonable.  I just cannot see
how it can be met if LPC boot loader structure is to be retained.
2006-05-02 by John Heenan
typically
of
request:
No. I guess you don't really get the point. I am not proposing
replacing the exising boot loader, just providing an option to 'opt
out' and continue booting elsewhere. The option to opt out and and
where to opt out decided according to bit choices at the CRP flash
location and before pin 0.14 is read. It would also be nice if we had
a documented 'opt in' again facility which bypassed their own pin
0.14 test.
See above. I am not suggesting it is used for any custoim boot loaders
For someone who is so full of praise for ATMEL your knowledge of
their well known techniques is very weak. There also appears to be an
industry wide consensus that unless you buy a lot of ATMEL product
you will get zero support. The fact that as a non production oriented
participant that you got any support from Philips is praiseworthy. If
you want support without buying prodcut try moving to PICs, Microchip
get consistent praise for their high level of support.
We know what is normal and we accept it. You don't.
With regard to REMAP issue, I have already indicated no changes are
necessary and so exising parts could have their bootloaders upgraded.
Additionally if Philips did not want all their parts to ship with
bootloader opt out options, they could provide us with a patched
version which could be massaged into production bootloading.
John Heenan
John,
ATMEL fuse bits relating to boot block size are for purposes of
determining the size of the block at the top of memory that is locked
down as boot block, and which is used to determine address to branch
to upon taking a reset.
I am the author of SAIL, the boot loader for ATMEL AVR series of
processors  and can find more information about this at
  http://www.cse.unsw.edu/~jayas/esdk/sail.html
It would be ludicrous suggest one could write a boot loader for AVRs
without intimate knowledge of ATMEL boot sector options and related
fuse bits.
Your (what appears to be a revised) enhancement request requires the
boot sector code to branch and then back.
As one who has been providing boot loaders for a variety of targets. I
know for a fact that boot loader designers frown on such a request.
The biggest problem is state preservation when the boot loader is
re-entered from user code.
A more sensible approach would be to have the methods implemented in
the boot loader itself and let the user select like in the case of CRP.
Me thinks getting Philips to patch boot loaders for your production is
quite queer.  Why patch when you can replace it.
Jaya
> 0.14 test.
> John Heenan
You have descended into rambling, confusion and irrelevancy again. I
will post a specific copy of a draft to Philips on the newsgroup
under a different subject title.
John Heenan
> John,
locked
> fuse bits.
targets. I
CRP.
is
> Jaya
to 'opt
and
flash
had
> > 0.14 test.
loaders
cannot see
retained.
be an
product
oriented
praiseworthy. If
Microchip
are
upgraded.
> > John Heenan
