Lpc2000
Can andyone solve this program problem?
2005-05-02 by 김동휘
The following source code :
             Partition table entry structure
typedef struct _tagPTINFO {
             uint8_t                 active;                //446
             uint8_t                 start_h;               // 447
             uint8_t                 start_cs_l;          // 448
             uint8_t                 start_cs_h;         // 449
             uint8_t                 type;                   // 450
             uint8_t                 end_h;                // 451
             uint8_t                 end_cs_l;            // 452
             uint8_t                 end_cs_h;           // 453
             uint8_t                 start_0;               // 454
             uint8_t                 start_1;               //455
             uint8_t                 start_2;               //456
             uint8_t                 start_3;               // 457
             uint8_t                 size_0;                // 458
             uint8_t                 size_1;               //459
             uint8_t                 size_2;                //460
             uint8_t                 size_3;                // 461
} PTINFO, *PPTINFO;
             Master Boot Record structure
typedef struct _tagMBR {
             uint8_t bootcode[0x1be];              // boot sector
             PTINFO ptable[4];                         // four partition table structures
             uint8_t sig_55;                               // 0x55 signature byte
             uint8_t sig_aa;                               // 0xaa signature byte
} MBR, *PMBR;
             uint32_t result;
             PMBR mbr = (PMBR) scratchsector;
             result = (uint32_t) mbr->ptable[pnum].start_0 |
               (((uint32_t) mbr->ptable[pnum].start_1) << 8) |
               (((uint32_t) mbr->ptable[pnum].start_2) << 16) |
               (((uint32_t) mbr->ptable[pnum].start_3) << 24);
Assembled code of above source code :
-            0x215c   <DFS_GetPtnStart+76>:                               add        r6, r7, r8, lsl #4
-            0x2164   <DFS_GetPtnStart+84>:                               ldrb       r5, [r6, #457]
-            0x2168   <DFS_GetPtnStart+88>:                               ldrb       r4, [r6, #458]
-            0x216c   <DFS_GetPtnStart+92>:                               ldrb       r0, [r6, #456]
-            0x2170   <DFS_GetPtnStart+96>:                               ldrb       r1, [r6, #459]
-            0x2184   <DFS_GetPtnStart+116>:                orr         r1, r1, r4
-            0x2188   <DFS_GetPtnStart+120>:                orr         r0, r0, r5
-            0x2194   <DFS_GetPtnStart+132>:                orr         r5, r0, r1
To work properly, assembled code must be like below :
-            0x2164   <DFS_GetPtnStart+84>:                               ldrb       r5, [r6, #455]
-            0x2168   <DFS_GetPtnStart+88>:                               ldrb       r4, [r6, #456]
-            0x216c   <DFS_GetPtnStart+92>:                               ldrb       r0, [r6, #454]
-            0x2170   <DFS_GetPtnStart+96>:                               ldrb       r1, [r6, #457]
That is, ‘mbr->ptable[pnum].start_0’ of source code doesn’t point a correct position.
it may be a allign problem
How can I solve this problem.
Dong-hwi Kim(金桐煇)
Senior Engineer of FAE Team.
Syncoam Co., Ltd.
TEL : 82-31-788-7843
FAX : 82-31-788-7846
E-mail : dhkim@...
Re: [lpc2000] Can andyone solve this program problem?
2006-05-02 by Dave Hylands
> } MBR, *PMBR;
It's probably a packing issue.
Structures are generally aligned on 32 bit boundaries, so you'll
probably find 2 bytes of pad are being inserted between bootcode and
ptable.
You'll need to use the appropriate directoves for your compiler to
select 8-bit or 16-bit packing.
Dave Hylands
Vancouver, BC, Canada
http://www.DaveHylands.com/
