Lpc2000
Writing 1 bit/byte to the Flash
2006-05-02 by vlads4377
Due to LPC user manual I can write to flash in resolution of 512 bytes
and more (That's mean not less than sector).
I'm looking for way to change single bit (from 1 to 0), or at least
one byte.
Any idea welcomed.
Thanks.
Re: [lpc2000] Writing 1 bit/byte to the Flash
2006-05-02 by Dominic Rath
You could mask out bits you don't want to change with 0xff, but that only
works up to the CRC granularity. IIRC every 16 byte are protected by a CRC
value, and thus can't be written more than once, as the CRC would have to be
re-written.
Dominic
On Tuesday 02 May 2006 08:28, vlads4377 wrote:
> Hi,
> one byte.
> Any idea welcomed.
> Thanks.
Re: Writing 1 bit/byte to the Flash
Thank you !!!
does it mean that I can re-write sector and to put the bytes that I
don't want to change as 0xff.
btw, I want to re-write it only once.
Vlad
--- In lpc2000@yahoogroups.com, Dominic Rath <Dominic.Rath@...>
that only
by a CRC
have to be
> re-written.
> Regards,
> Dominic
> > Hi,
bytes
least
> > one byte.
> > Any idea welcomed.
> > Thanks.
