Lpc2000
Good C code
Good C code
2006-05-05 by jk jlkj
Hi Friends,
  Did anyone came accross such a code.
  INT32U is unsigned int.
  #define  BSP_UNDEF_INSTRUCTION_VECTOR_ADDR   (*(INT32U *)0x00000004L)
  I really think this is a neat code. This is in the code given by ucos-ii.
  Isnt this similar to declaring a pointer variable.
  I am unable to understand the meaning of the type cast (*(INT32U *))
  Can some one please tell me what does this type cast imply.
  Jerome
 Yahoo! India Answers: Share what you know. Learn something new. Click here
Re: Good C code
2006-05-05 by brendanmurphy37
There's two things going on here.
1. INT32U is being used as a short-hand for "unsigned int". There are
two reasons I can think for defining this: (a) its quicker and
simpler to write and, more importantly, (b) if the definition is in
an include file, the file can be constructed or altered to suit
different platforms. Thus on some platforms INT32U might be defined
as "unsigned long int". Done this way, the main body of code doesn't
have to change: if you want an unsigned 32-bit integer, you just use
the defined type "INT32U". By the way, using upper case as a type
name is a somewhat old practice (derived from using MACROs to define
types before "typedef" was part of the langaue).
2. The construct "(*(INT32U *) VALUE)" is a very common way of
enabling a constant integer value to be used as an address (i.e.
pointer) type. The "(INT32U *) VALUE" part says "treat VALUE as
a "pointer to an unsigned int". The extra "*" then says de-reference
this pointer. It lets you write code like:
BSP_UNDEF_INSTRUCTION_VECTOR_ADDR = 0;
This stores the value 0 at the address 0x00000004.
A variation on this is to define a MACRO such as:
#define REG(addr) (*(volatile unsigned int *)(addr))
You can use this like:
#define VICIntEnable (0xFFFFF010)
REG(VICIntEnable) = 0x40;
Brendan
--- In lpc2000@yahoogroups.com, jk jlkj <njad2002@...> wrote:
> Hi Friends,
0x00000004L)
ucos-ii.
>   Regards,
>   Jerome
Click here
Re: [lpc2000] Good C code
2006-05-05 by vineet jain
 To put simply:
Say for example:
unsigned int *ram_ptr  =  ( unsigned int * ) 0x000000F0;
So, to store something at this address you would write something like:
*ram_ptr  = 36;
The above statement means that ram_ptr is pointing to memory location 0x000000F0.
Now when you write
it means BSP_UNDEF_INSTRUCTION_VECTOR_ADDR is the content of the memory address 0x00000004L.
Here to store a value at the 0x00000004L address you would write
BSP_UNDEF_INSTRUCTION_VECTOR_ADDR = 36;
Vineet.
jk jlkj <njad2002@...> wrote:    Hi Friends,
   Jerome
        SPONSORED LINKS
                                                    Microcontrollers                                       Microprocessor                                       Intel microprocessors
   YAHOO! GROUPS LINKS
Yahoo! Mail goes everywhere you do.  Get it on your phone.
