Lpc2000
unnecessary external interrupt ( INT1 )
2006-05-11 by topandurangs
Hi all,
       In my application I am using INT1 as -ve edge trigger interrupt
( PINSEL0_bit.P0_3 = 0x3).I also need to check the status of the same
pin by configuring it as a GPIO( PINSEL0_bit.P0_3 = 0x0).
       But when i switching between GPIO & INT1 by using PINSEL ,I am
getting INT1 interrupt (unnecessary interrupt).
       What may be the reason for it & how should i overcome it.
Thanks & Regards,
Pandurang S.
Re: unnecessary external interrupt ( INT1 )
2006-05-11 by brendanmurphy37
I posted a message regarding this some time ago:
http://groups.yahoo.com/group/lpc2000/message/11212
There are several possible work-arounds:
1. disable interrupt when reading state of pin
2. just take the extra interrupt, knowing it's spurious
3. route signal to a 2nd GPIO pin, and use that to read state
The first two work OK in general, but there's a risk you'll miss a
genuine interrupt. Safest option (that I can think of) is 3.
I'm a bit surprised that this hasn't been documented by Philips at
this stage: it's been known for some time.
Brendan
--- In lpc2000@yahoogroups.com, "topandurangs" <pandurang@...> wrote:
> Hi all,
interrupt
same
am
> Thanks & Regards,
> Pandurang S.
