Lpc2000
Interrupt in LPC22XX
2006-05-10 by poland459
Hi am new to this forum.I am using "free" KEIL evalution software as
my IDE to work on LPCE2214 OLIMEX board. Am able to work on TIMER and
serial port in "polling" mode. But when I enable ISR functions using
VIC,my program in not jumping to ISR.but in debug mode i could see
the jump to ISR. also I have DefaultISR in my code.here am attaching
my code with this mail.
// This program is created for LPC-E2214 board
#include "lpc22xx.h"
#define OSCILLATOR_CLOCK_FREQUENCY 14745600 //in MHz
#define PLOCK 0x400 //in MHz
void Initialize(void);
void feed(void);
void UART0Initialize(unsigned int baud);
void UART0WriteChar(unsigned char ch0);
unsigned char UART0ReadChar(void);
unsigned char UART0ReadChar_nostop(void);
unsigned int processorClockFrequency(void);
unsigned int peripheralClockFrequency(void);
void tc0(void)__irq;
static void DefDummyInterrupt(void)__irq;
void init_timer(void);
void InitVIC(void);
long volatile timeval;
void wait (void) /* wait function */
unsigned long i;
i = timeval;
while ((i + 10) != timeval); /* wait 100ms */
int main()
/**** VARIABLES ****/
unsigned char ch0 = 0x0;
unsigned char ch1 = 0x0;
long i=0;
/**** INITIALIZATION ****/
// Frequency initialization
Initialize();
// UART initialization
UART0Initialize(9600);
init_timer();
InitVIC();
while(1)
UART0WriteChar('3');
wait();
UART0WriteChar('2');
wait();
// Setting Multiplier and Divider values
PLLCFG=0x23;
feed();
// Enabling the PLL */
PLLCON=0x1;
feed();
// Wait for the PLL to lock to set frequency
while(!(PLLSTAT & PLOCK)) ;
// Connect the PLL as the clock source
PLLCON=0x3;
feed();
// Enabling MAM and setting number of clocks used for Flash memory
fetch (4 cclks in this case)
MAMCR=0x2;
MAMTIM=0x4;
// Setting peripheral Clock (pclk) to System Clock (cclk)
VPBDIV=0x1;
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
/* Setup the Timer Counter 0 Interrupt */
void init_timer (void) {
T0MR0 = 149999; // 10mSec = 150000-1 counts
T0MCR = 3; // Interrupt and Reset on MR0
T0TCR = 1; // Timer0 Enable
VICVectAddr0 = (unsigned long)tc0; // set interrupt vector in 0
VICVectCntl0 = 0x20 | 4; // use it for Timer 0 Interrupt
VICIntEnable = 0x00000010; // Enable Timer0 Interrupt // Timer0 Enable
/* Timer0 Compare-Match Interrupt Handler (ISR) */
/* Timer Counter 0 Interrupt executes each 10ms @ 60 MHz CPU Clock */
void tc0 (void) __irq
++timeval;
T0IR = 1; // Clear interrupt flag
VICVectAddr = 0; // Acknowledge Interrupt
void InitVIC()
VICDefVectAddr = (unsigned long)DefDummyInterrupt;
/**** UART0 ****/
unsigned int divisor = peripheralClockFrequency() / (16 * baud);
U0LCR = 0x83;
//devisor
U0DLL = divisor & 0xFF;
U0DLM = (divisor >> 8) & 0xFF;
U0LCR &= ~0x80;
//set functionalite to pins: port0.0 -> TX0, port0.1 -> RXD0
PINSEL0 = PINSEL0 & ~0xF | 0x5;
//when U0LSR_bit.THRE is 0 - U0THR contains valid data.
while ((U0LSR && 0x20) == 0);
U0THR = ch0;
//when U0LSR_bit.DR is 1 - U0RBR contains valid data
while ((U0LSR && 0x01) == 0);
return U0RBR;
//return real processor clock speed
return OSCILLATOR_CLOCK_FREQUENCY * (PLLCON & 1 ? (PLLCFG & 0xF) +
1 : 1);
//VPBDIV - determines the relationship between the processor clock
(cclk)
//and the clock used by peripheral devices (pclk).
unsigned int divider;
switch (VPBDIV & 3)
case 0: divider = 4; break;
case 1: divider = 1; break;
case 2: divider = 2; break;
return processorClockFrequency() / divider;
Please look into this and It would be a great help for me as i have
been trying for it from past 2 weeks.
I think, abviously iam missing some things. I did not changed any
things in startup.s file.I will post the start up code if any body
wanted to look in
please guide me.appreciate your help.
Thanks
Re: Interrupt in LPC22XX
2006-05-10 by fordp2002
Pop this code in and call enableIRQ in main :-
static inline unsigned asm_get_cpsr(void)
  unsigned long retval;
  asm volatile (" mrs  %0, cpsr" : "=r" (retval) : /* no inputs */  );
  return retval;
static inline void asm_set_cpsr(unsigned val)
  asm volatile (" msr  cpsr, %0" : /* no outputs */ : "r" (val)  );
unsigned enableIRQ(void)
  unsigned _cpsr;
  _cpsr = asm_get_cpsr();
  asm_set_cpsr(_cpsr & ~IRQ_MASK);
  return _cpsr;
I got it from the WinARM site a good place for examples.
You may have other problems too, I did not read your code in detail.
Let us know how you get on ;)
FordP
Good
> void feed(void);
> void InitVIC(void);
> unsigned long i;
> i = timeval;
> int main()
> long i=0;
> Initialize();
> init_timer();
> InitVIC();
> while(1)
> wait();
> wait();
> PLLCFG=0x23;
> feed();
> PLLCON=0x1;
> feed();
> PLLCON=0x3;
> feed();
> MAMCR=0x2;
> MAMTIM=0x4;
> VPBDIV=0x1;
> void feed(void)
> PLLFEED=0xAA;
> PLLFEED=0x55;
> ++timeval;
> void InitVIC()
> /**** UART0 ****/
> U0LCR = 0x83;
> //devisor
> U0LCR &= ~0x80;
> U0THR = ch0;
> return U0RBR;
> 1 : 1);
> (cclk)
> switch (VPBDIV & 3)
> wanted to look in
> Thanks
RE: [lpc2000] Interrupt in LPC22XX
2006-05-10 by Andrew Berney
Errrm I've not looked at the data sheets for that particular part, but it
doesn't appear that you're turning on the serial IRQ...
on the 2129 I'm currently working on it'd be something like:
  VICVectCntl1 = 0x00000026; // IRQ 6 enabled - the IRQ for UART0
  VICVectAddr1 = (unsigned)UART0_Irq; // Function to run as IRQ
  VICIntEnable |= 0x00000040; // flick its bit on to show we want this IRQ
firing...
likewise for UART1:
  VICVectCntl2 = 0x00000027; // IRQ 7 enabled
  VICVectAddr2 = (unsigned)UART1_Irq;
  VICIntEnable |= 0x00000080;
I imagine it's probably the same for yours...
One other thing to note is that your watchdog feed is currently not an
atomic instruction - ie if you get interrupted between the two writes you're
doing the watchdog will trip... (better to disable the IRQ's when kicking
the dog then turn them back on). Personally I simply use one of the on chip
timers to give me an interrupt every so often and then kick the watchdog
inside it's IRQ handler...
Andy
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of poland459
Sent: 10 May 2006 05:59
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Interrupt in LPC22XX
void feed(void);
void InitVIC(void);
unsigned long i;
i = timeval;
int main()
long i=0;
Initialize();
init_timer();
InitVIC();
while(1)
wait();
wait();
PLLCFG=0x23;
feed();
PLLCON=0x1;
feed();
PLLCON=0x3;
feed();
MAMCR=0x2;
MAMTIM=0x4;
VPBDIV=0x1;
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
++timeval;
void InitVIC()
/**** UART0 ****/
U0LCR = 0x83;
//devisor
U0LCR &= ~0x80;
U0THR = ch0;
return U0RBR;
1 : 1);
(cclk)
switch (VPBDIV & 3)
wanted to look in
Thanks
Yahoo! Groups Links
Actually, just checked and you'll also need:
  U0IER   = 0x00000001;     //enable rx data available interrupt
as well...eg:
  VPBDIV  = 0x00000001;		//Set PClk to 60Mhz
  // UART0
  U0LCR   = 0x00000083;     // 8 bits, no Parity, 1 Stop bit
  U0DLL   = 0x000000C2;     // 19,200 Baud Rate @ 60MHz VPB Clock
  U0DLM   = 0x00000000;
  U0LCR   = 0x00000003;     // DLAB = 0
  U0FCR   = 0x00000001;		//Enable FIFO & trigger level to 1 byte
Hope that helps...
Andy
Of Andrew Berney
Sent: 10 May 2006 09:42
Subject: RE: [lpc2000] Interrupt in LPC22XX
firing...
likewise for UART1:
Andy
Of poland459
void feed(void);
void InitVIC(void);
unsigned long i;
i = timeval;
int main()
long i=0;
Initialize();
init_timer();
InitVIC();
while(1)
wait();
wait();
PLLCFG=0x23;
feed();
PLLCON=0x1;
feed();
PLLCON=0x3;
feed();
MAMCR=0x2;
MAMTIM=0x4;
VPBDIV=0x1;
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
++timeval;
void InitVIC()
/**** UART0 ****/
U0LCR = 0x83;
//devisor
U0LCR &= ~0x80;
U0THR = ch0;
return U0RBR;
1 : 1);
(cclk)
switch (VPBDIV & 3)
wanted to look in
Thanks
Yahoo! Groups Links
Yahoo! Groups Links
2006-05-10 by brendanmurphy37
watchdog
> Andy
Andy,
Can you explain more about how you're using the watchdog, as what you
say sounds a bit strange if you take it at face value?
One of the functions of a watchdog is to reset a system to a known
state to recover from (previously unknown) software (or indeed
hardware induced) errors. If the software error involves entering an
infinite loop then a timer interrupt that just feeds the watchdog
won't recover the system: the watchdog will never expire.
No doubt you're doing something else: for example in the timer
interrupt you could check one or more status fields that are
continuously updated by parts of the application and only feed the
watchdog if everything is looking good.
Also, you still need to ensure interrupts are disabled for the feed
sequence, unless you don't allow nested interrupts.
Just in case anyone reading your post gets the wrong idea it might be
worth clarifying these points.
Brendan.
RE: [lpc2000] Re: Interrupt in LPC22XX
Sorry yes, to clarify we do exactly as you said - the IRQ for the timer
checks the state of all the registered subsystems (which for the current
project are quite limited) - assuming they're all ok (or simply degraded but
still running well enough to allow continued operation) it kicks the
watchdog - and we don't allow nested IRQs although both FIQ and IRQ are
disabled anyway for the feed sequence.
Andy
Of brendanmurphy37
Sent: 10 May 2006 10:22
Subject: [lpc2000] Re: Interrupt in LPC22XX
watchdog
> Andy
Andy,
Brendan.
Yahoo! Groups Links
Thanks for your reply..I have added the asm code and called enableIRQ
after the timer is enabled.. But the program is not jumping to ISR...
I forgot to mention in my first post that, iam using UART0 in polling
mode and TIMER0 in ISR..(ISR is not triggered even if I use only
TIMER0 in ISR).
here is the asm code..
static __inline unsigned long asm_get_cpsr(void) __arm
  __asm { mrs retval, CPSR };
   return retval;
static __inline void asm_set_cpsr(unsigned long value)  __arm{
  value = value;              // avoid warning: unused parameter
  __asm { msr CPSR_c, R0 };   // value passed in R0
unsigned long enableIRQ(void)
   unsigned long _cpsr;
   return _cpsr;
Thank you.
> FordP
> Good
as
and
using
see
attaching
> > void feed(void);
> > void InitVIC(void);
> > unsigned long i;
> > i = timeval;
> > int main()
> > long i=0;
> > Initialize();
> > init_timer();
> > InitVIC();
> > while(1)
> > wait();
> > wait();
> > PLLCFG=0x23;
> > feed();
> > PLLCON=0x1;
> > feed();
> > PLLCON=0x3;
> > feed();
memory
> > MAMCR=0x2;
> > MAMTIM=0x4;
> > VPBDIV=0x1;
> > void feed(void)
> > PLLFEED=0xAA;
> > PLLFEED=0x55;
Enable
Clock */
Clock */
> > ++timeval;
> > void InitVIC()
> > /**** UART0 ****/
> > U0LCR = 0x83;
> > //devisor
> > U0LCR &= ~0x80;
> > U0THR = ch0;
> > return U0RBR;
> > 1 : 1);
clock
> > (cclk)
> > switch (VPBDIV & 3)
have
body
> > wanted to look in
> > Thanks
Ok... I spent a little more time and actually read through your code
properly. I'm not actualy quite sure what you're trying to achieve however
there's a few obvious things.
1) are you trying to actually use the watchdog? I can't see any reference to
setting up WDTC or WDMOD so are you sure it's actually switched on?
2) if you are actively using it you don't have any form of kick for it
inside your main while loop (one of the reasons I decouple it to a timer IRQ
that acts as an internal system check to look at running statuses).
3) Can't remember off the top of my head, but don't you also have to reset
the count for the timer when you initialise it?
ie:
	T0PR  = 0x1;      // set the prescaler to the pclk frequency 60MHz
	T0TCR = 0x2;      // reset the counter to 0
	T0MCR = 0x3;      // on match generate an IRQ
	T0MR0 = 0x600000; // count 0x600000 hex cycles per IRQ
	T0TCR = 0x1;      // enable timer
	VICVectCntl0 = 0x24;            // IRQ 4 + Enabled bit
	VICVectAddr0 = (unsigned)T0ISR; // address of IRQ handler
	VICIntEnable |= 0x10;           // Turn on IRQ 4
4) Have you checked the UART parameters to ensure your clock and divisors
etc are giving you the correct baud rate?
Andy
Of poland459
Sent: 10 May 2006 11:40
TIMER0 in ISR).
   return retval;
   return _cpsr;
Thank you.
> FordP
> Good
as
and
using
see
attaching
> > void feed(void);
> > void InitVIC(void);
> > unsigned long i;
> > i = timeval;
> > int main()
> > long i=0;
> > Initialize();
> > init_timer();
> > InitVIC();
> > while(1)
> > wait();
> > wait();
> > PLLCFG=0x23;
> > feed();
> > PLLCON=0x1;
> > feed();
> > PLLCON=0x3;
> > feed();
memory
> > MAMCR=0x2;
> > MAMTIM=0x4;
> > VPBDIV=0x1;
> > void feed(void)
> > PLLFEED=0xAA;
> > PLLFEED=0x55;
Enable
Clock */
Clock */
> > ++timeval;
> > void InitVIC()
> > /**** UART0 ****/
> > U0LCR = 0x83;
> > //devisor
> > U0LCR &= ~0x80;
> > U0THR = ch0;
> > return U0RBR;
> > 1 : 1);
clock
> > (cclk)
> > switch (VPBDIV & 3)
have
body
> > wanted to look in
> > Thanks
Yahoo! Groups Links
Thanks for your time.
1&2]Am not using watchdog timer. And i didnot touched watch dog
timer.as am learning this LPC, my aim is to send bytes to
hyperterminal for every 10ms with a 9600 baud rate.
3]I forgot to reset the counter value.Its noted but its not help ful
in my problem. Thank you
4]I have checked the UART condtions, everything looks fine. Am able
to receive bytes before the timer is being initialised.
Thanks again.
however
reference to
it
timer IRQ
to reset
> ie:
60MHz
divisors
> Andy
Behalf
> Of poland459
enableIRQ
ISR...
polling
> TIMER0 in ISR).
>    return retval;
>    return _cpsr;
> Thank you.
detail.
> > FordP
> > Good
software
> as
TIMER
> and
> using
> see
> attaching
> > > void feed(void);
> > > void InitVIC(void);
> > > unsigned long i;
> > > i = timeval;
> > > int main()
> > > long i=0;
> > > Initialize();
> > > init_timer();
> > > InitVIC();
> > > while(1)
> > > wait();
> > > wait();
> > > PLLCFG=0x23;
> > > feed();
> > > PLLCON=0x1;
> > > feed();
> > > PLLCON=0x3;
> > > feed();
> memory
> > > MAMCR=0x2;
> > > MAMTIM=0x4;
> > > VPBDIV=0x1;
> > > void feed(void)
> > > PLLFEED=0xAA;
> > > PLLFEED=0x55;
> Enable
> Clock */
> Clock */
> > > ++timeval;
> > > void InitVIC()
> > > /**** UART0 ****/
> > > U0LCR = 0x83;
> > > //devisor
> > > U0LCR &= ~0x80;
> > > U0THR = ch0;
> > > return U0RBR;
> > > 1 : 1);
> clock
> > > (cclk)
> > > switch (VPBDIV & 3)
> have
any
> body
> > > wanted to look in
> > > Thanks
2006-05-10 by Bennett Scharf
Kicking the watchdog in an interrupt routine is as bad an idea as I have
ever heard.   The only thing that has to be healthy in the microprocessor at
the time is a valid stack pointer and the interrupt routine itself..
  _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf Of
Andrew Berney
Sent: Wednesday, May 10, 2006 2:42 AM
firing...
likewise for UART1:
Andy
Of poland459
void feed(void);
void InitVIC(void);
unsigned long i;
i = timeval;
int main()
long i=0;
Initialize();
init_timer();
InitVIC();
while(1)
wait();
wait();
PLLCFG=0x23;
feed();
PLLCON=0x1;
feed();
PLLCON=0x3;
feed();
MAMCR=0x2;
MAMTIM=0x4;
VPBDIV=0x1;
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
++timeval;
void InitVIC()
/**** UART0 ****/
U0LCR = 0x83;
//devisor
U0LCR &= ~0x80;
U0THR = ch0;
return U0RBR;
1 : 1);
(cclk)
switch (VPBDIV & 3)
wanted to look in
Thanks
Yahoo! Groups Links
SPONSORED LINKS
Microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2
=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PM
g>
Microprocessor
<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=M
icroprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ>
Intel
<http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrolle
rs&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5qu
Agrl5w>  microprocessors
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> "
on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
  _____
If you'd care to read the reply I explained exactly what we use that for...
and yes, the original description was unfortunately misleading but has
already been explained so as to avoid any misinterpretation by people such
as yourself.
Andy
Of Bennett Scharf
Sent: 10 May 2006 16:20
  _____
Andrew Berney
firing...
likewise for UART1:
Andy
Of poland459
void feed(void);
void InitVIC(void);
unsigned long i;
i = timeval;
int main()
long i=0;
Initialize();
init_timer();
InitVIC();
while(1)
wait();
wait();
PLLCFG=0x23;
feed();
PLLCON=0x1;
feed();
PLLCON=0x3;
feed();
MAMCR=0x2;
MAMTIM=0x4;
VPBDIV=0x1;
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
++timeval;
void InitVIC()
/**** UART0 ****/
U0LCR = 0x83;
//devisor
U0LCR &= ~0x80;
U0THR = ch0;
return U0RBR;
1 : 1);
(cclk)
switch (VPBDIV & 3)
wanted to look in
Thanks
Yahoo! Groups Links
SPONSORED LINKS
Microcontrollers
g>
Microprocessor
Intel
  _____
YAHOO! GROUPS LINKS
on the web.
  _____
Yahoo! Groups Links
Sorry Andy. I joined the group yesterday and did not read your reply until
after I sent mine!.
Bennett
  _____
Andrew Berney
Sent: Wednesday, May 10, 2006 9:30 AM
as yourself.
Andy
Of Bennett Scharf
  _____
Andrew Berney
firing...
likewise for UART1:
Andy
Of poland459
void feed(void);
void InitVIC(void);
unsigned long i;
i = timeval;
int main()
long i=0;
Initialize();
init_timer();
InitVIC();
while(1)
wait();
wait();
PLLCFG=0x23;
feed();
PLLCON=0x1;
feed();
PLLCON=0x3;
feed();
MAMCR=0x2;
MAMTIM=0x4;
VPBDIV=0x1;
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
++timeval;
void InitVIC()
/**** UART0 ****/
U0LCR = 0x83;
//devisor
U0LCR &= ~0x80;
U0THR = ch0;
return U0RBR;
1 : 1);
(cclk)
switch (VPBDIV & 3)
wanted to look in
Thanks
Yahoo! Groups Links
SPONSORED LINKS
Microcontrollers
g>
Microprocessor
Intel
  _____
YAHOO! GROUPS LINKS
on the web.
  _____
Yahoo! Groups Links
SPONSORED LINKS
Microcontrollers
g>
Microprocessor
Intel
  _____
YAHOO! GROUPS LINKS
on the web.
  _____
Re: [lpc2000] Interrupt in LPC22XX
2006-05-10 by 3gpabko
Here are some points to mention:
1. As I see you are running from FLASH. Correct? If
yes you need to set MEMMAP = 1, at initialization.
2. In this case ensure that at address 0x00000018 you
have this:
 ldr pc, [pc, #-0xFF0]
or similar code.
Zdravko Dimitrov
> work on TIMER and
> functions using
> mode i could see
\u0417\u043d\u0430\u043d\u0438\u0435\u0442\u043e \u0435 \u043b\u0438\u0447\u043d\u043e \u043f\u0440\u0435\u0436\u0438\u0432\u044f\u043d\u0430 \u0438\u0441\u0442\u0438\u043d\u0430.
Do You Yahoo!?
http://mail.yahoo.com
2006-05-10 by ghetto_shinobi
Ive taken look into ur code and since u are using Keils IDE its
pointless to call this function
This piece of code is embedded into startup code and u can configure
speed of Mcu(PLL and VPBDIV and MEM either by editing startup code or
by using Configuration Wizard.
Regards!!
2006-05-11 by poland459
Hi Zdravko Dimitrov,
Thank you very much for your valid suggestion.
At last its working..really Its 2 weeks struggle..I thought I have
initialised "MEMMAP = 1" but forgot to initialise. Am very thank ful
to you and everyone who tried to help me out.
> have this:
> or similar code.
> Regards
> Zdravko Dimitrov
> > work on TIMER and
> > functions using
> > mode i could see
> \u0417\u043d\u0430;\u043d\u0438\u0435\u0442\u043e \u0435
\u043b\u0438\u0447\u043d&#1086;
&#1080;\u0441\u0442\u0438\u043d\u0430.
> Do You Yahoo!?
2006-05-11 by Tom OE6TKT
You don't need to OR this register with itself, just write:
VICIntEnable = 0x00000080;
(to clear this interrupt use VICIntEnClear = 0x00000080;)
Thomas
