Lpc2000
LPC214x USB Problem
LPC214x USB Problem
2006-05-16 by philipp1024@web.de
Hi all,
I have a question about isochronous Endpoints with the LPC214X. Because if I implement two endpoints (0x6 for Out and 0x83 for In) I’ am able to sent Data to the PC but I have no idea how to receive data.
There is no EP interrupt generated.
Does anyone has an idea what’s going on, or how isochronous out transfers?
Thanks in advance.
Best Regards
Philipp
_______________________________________________________________
SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
Re: [lpc2000] LPC214x USB Problem
Oh, I forgot :
At the moment I’m using the IAR Development kit and the IAR USB Stack. On the PC side I’m currently using Jungo-Win-Driver but I will also try it with libusb-win32.
> Von: lpc2000@yahoogroups.com
> Gesendet: 16.05.06 09:53:02
> An: lpc2000@yahoogroups.com
> Betreff: [lpc2000] LPC214x USB Problem
> Hi all,
> Thanks in advance.
> Best Regards
> Philipp
Re: LPC214x USB Problem
2006-05-19 by frodri123123
In isochronous transfers data is sent in preassigned slots at each frame (and never more
than once in a frame).  For this reason a dedicated interrupt is not rquired.
From the manual: " Isochronous endpoint will have one packet of data to be transferred in
every frame. So the data transfer has to be synchronized to the USB frame rather than
packet arrival. So, for every 1 ms there will be an interrupt to the system."
What you should do is use the start of frame interrupt, and poll to see how much data has
arrived in your endpoint then:
So something like this should do it:
FRAME INTERRUPT HANDLER:
if (size=ReadEndPoint(3, &Buffer))
   Process your data
--- In lpc2000@yahoogroups.com, philipp1024@... wrote:
> Hi all,
implement two endpoints (0x6 for Out and 0x83 for In) I' am able to sent Data to the PC
> Does anyone has an idea what's going on, or how isochronous out transfers?
> Thanks in advance.
> Best Regards
> Philipp
