LPC2103 watchdog issues
2006-05-19 by Langosta39
I'm having trouble hitting the watchdog on the 2103. It works just fine without IRQs, but after I enable interrupts I can no longer feed it. I am disabling interrupts around the feed so it is atomic, and I know the feed works becasue I call the same code in the init function. I've tried using the standard __enable_interrupt __disable_interrupt functions in IAR and I've tried directly manipulating the CPSR as per the errata sheet with no luck. Any advice? Andy
