JTAG issues again
2006-05-26 by Sutton Mehaffey
Anyone out there running the combo of Keil's compiler and JTAG with Embedded Artists 2148 board and prototype board? I have been using Philips Flash Utility to download code to the EA boards and it works perfectly. I got JTAG working several weeks ago for a couple of hours, but when I solved my problem, I went back to serially programming the flash (since I have a serial display in which I use to debug), which works all the time. I'm doing some display software development and need the JTAG for debugging. I keep getting the infamous 'JTAG Comm. Failure'. And this occurs on 2 sets of EA boards and 2 Keil ULINKs. I have downloaded the latest 2.53 compiler and looked at some of the forums which say to make sure that PINSEL2 - bit 3 is not set to '1' (which it isn't). There is only 1 jumper on the EA board to set and it is. With my code running, shouldn't I just be able to connect up the JTAG and say 'Debug' thru the uVision GUI? Under Flash Programming Tools, I have 'Use ULINK Debugger' set? Maybe JTAG is still disabled. Anyway to tell? Anything else? Thanks. Sutton
