Lpc2000
LED & Button connection
2006-05-26 by Иван Кончаловский
Hello All.
  I have two questions for you:
  1. Is it possible to connect LED (super bright 1mA) to port pin
  without additional current limiting resistor?
  2. Is it possible to connect button between port pin and
  ground while configuring this port pin as output with
  high level and read its state (button pressed or not)?
Best regards,
 Hummel
Re: [lpc2000] LED & Button connection
2006-05-26 by Leon Heller
From: "\ufffd\ufffd\ufffd\ufffd \ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd" <Hummel-80@...>
To: <lpc2000@yahoogroups.com>
Sent: Friday, May 26, 2006 4:14 PM
Subject: [lpc2000] LED & Button connection
> Hello All.
Of course you can do it, if you want!
You can do that, as well!
Read the data sheet.
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Re: LED & Button connection
2006-05-26 by c.barbaro
--- In lpc2000@yahoogroups.com, Èâàí Êîí÷àëîâñêèé <Hummel-80@...> wrote:
> Hello All.
> Best regards,
>  Hummel
Are you an enemy of resistors?
Nevertheless they aren't big or costly components...
lpcusb and mcb2140
2006-05-26 by Erick Damasceno
Has anyone succed porting lpcusb for keil mcb2140?? I tried many things but doesn't work. If anyone have succed, please, send me the code or tell me what i have to do.
thanks,
Erick
Novidade no Yahoo! Mail: receba alertas de novas mensagens no seu celular. Registre seu aparelho agora!
2006-05-26 by Gus
I don't know what Leon is trying to do here but no you can't do
that. If you know electronics well you will know why but if you are
hobbyist then just follow the many examples and schematics out there.
I agree you should read the data sheet but to newbies, data sheets
are nightmares LOL
Gus
--- In lpc2000@yahoogroups.com, "Leon Heller" <leon.heller@...>
wrote:
> From: "Èâàí Êîí÷àëîâñêèé" <Hummel-80@...>
> > Hello All.
> Leon
responsibility
are
Re: [lpc2000] Re: LED & Button connection
Sent: Friday, May 26, 2006 5:58 PM
Subject: [lpc2000] Re: LED & Button connection
are nightmares LOL
He asked if he could do it. The point I was making was that he could if he
wanted to, but if he read the data sheet he'd see that it wasn't advisable.
Leon
2006-05-26 by newmanrf@originarea.com
Hummel,
    These guys are pulling your leg. That means they are teasing you for
not knowing any better.
    It is not eloquent to connect a led to a i/o pin without a resistor if
your pin can source or sink more current than your device can
withstand and survive. Yes it will work for a while but then either
your led or your pin driver will fail so no you should not do it.
    If your led only takes 1mA, and that seems really small to me normally
leds take 20ma (0.020A), then use the formulas you learned in school
to determine your resistor. In this case you use R=V/I where R is the
resistor resistance your looking for and V is your power supply
voltage that the CPU which you are attaching your led is attached to
one of its i/o pins and I is the current which your thing needs to run
correctly which in this case is a led that takes 20ma or 0.020A. So
the formula  3.3vdc / 0.020A gives us 165 Ohms and in my box of parts
I have 220 Ohms so I pick that and use it which makes the led work but
just a little less dim than had I had 150, 160 or 180 Ohm resistors.
    So this answers your led question and here is a web page that talks
about other related subjects which your probably going to need to know
also:
http://www.music.columbia.edu/~douglas/classes/microcontrollers/part3.html
If I were you I would start at the beginning of that class web page and
read the whole thing through, its good stuff and the basics are important.
    I hope this helped you and if you have any additional questions which
the link above did not address or you need clarification simply post
another follow up question.
Richard Newman
Pittsburgh PA USA
2006-05-26 by rtstofer
> are nightmares LOL
> Gus
Leon is correct!  For a short period of time...
According to the LPC2141_42_44_46_48 Datasheet, Iohs (HIGH-state
short-circuit current is -45 mA and note 8 applies.  Note 8 says "Only
allowed for a short time period."  So, it can be done.
It is a poor idea and I wouldn't do it even if I could limit the time
period.  But the correct answer to the question is yes, it can be done.
I would have to dig deeper to resolve the LED issue.  I have seen it
done with multiplexed displays and I have done it myself.  It works
ok.  But, I don't have to guarantee my work.
As to the issue of reading datasheets - if you don't understand the
numbers, ask.  Somebody will be able to help.  Every number in the
datasheet serves to limit the way in which the device may be applied.
and is included for that specific reason.
A more important question is why anyone would want to short the
output.  It just seems wrong, somehow.  Even for a short period of time...
Richard
2006-05-26 by Tom Walsh
>>are nightmares LOL
>>Gus
That depends on the driver used, some of those multiplexed dot matrix
driver chips have internal current limiters and can withstand a dead
short.  This is unlike a CPU port pin, the short-circuit current spec is
typically for ATE testing purposes.  Understanding that spec can assist
you in debugging a logic problem, watch the signal on a 'scope and then
tap it with a voltage lead to see if it moves type of thing (e.g. "is
this shorted to ground?").
Having said that, you can eliminate current limiting resistors if you
"pop" (pulse) current into the LEDs.  I'm sure that a steady state drive
would fry the LEDs, though you can "hit" them with a pulse of current
designed to make them "ignite" and remove the current before the
internal junction temp gets too high.
It does mean that you have to read the datasheet and understand the
parameters of the parts.
TomW
newmanrf@... wrote:
>Hummel,
Something that I did not realize from the LED datasheets, until I did a
dot matrix display bar, was that LEDs have a max current and a max
voltage rating (breakdown voltage).  That breakdown voltage is
surprisingly small!  IIRC, the VF parameter is the maximum voltage
across the LED junction, exceeding that value will cause the junction to
be punctured.
If you think of the LED as a current device and use series limiting
resistors, you are ok.  This is because the resistor soaks up some of
the voltage in the loop (kirchoff's law).  When you "burn out" an LED
due to too small a resistor, it becomes a question of did you apply too
much current and overheated the junction -- OR -- did you overvoltage
the junction?
I typically calculate the VF (voltage across the junction) to be within
80% of the rating, then subtract that voltage from the applied voltage
of the circuit.  Once I have that "excess voltage", I then calculate the
resistance needed to "soak" up that excess votage.
TomW
--- In lpc2000@yahoogroups.com, newmanrf@... wrote:
> Hummel,
Not at all!  I wouldn't do that...
The question re: shorting the output was VERY specific and implied the
knowledge that such a thing was NOT a good idea.
I answered the question directly from the datasheet - YES, you can do
it "for a short period of time".  But I did go to the trouble to look
it up instead of blowing it off.  Mostly because Leon had said it was
possible and, therefore, he had read something I had missed and I
wanted to know what it was.  Seems I am always playing catch-up!
I also pointed out that I wouldn't personally do it, even if I could
control the time.
Richard
Sent: Friday, May 26, 2006 8:02 PM
>> Hummel,
> control the time.
I did check the data sheet myself before my somewhat tongue in cheek
response. The OP did look a bit like trolling to me.
Leon
2006-05-27 by unity0724
Umm... Cool down... guys... that heat generated here is enough to
burn the 2pcs tiny 0603 resistors.... :)
Everyone is right!
- You should be able to pulse high the pin for few uS and read the
  switch status.
- You can pulse LED at about 40-100mA.  Typical rated current for
  LED is 20mA
I think everybody here will not "intentionally" want to remove
those 2 resistors. May be as some "quick fix" for some mistakes in
design after PCB fabricated...
Also, if you must do it... do it on some LPC 4-5mA MOS output
driving pins and not some AVR 20-30mA type
wrote:
> From: "rtstofer" <rstofer@...>
> > --- In lpc2000@yahoogroups.com, newmanrf@ wrote:
> >> Hummel,
teasing you for
implied the
can do
look
it was
could
> > control the time.
cheek
> Leon
responsibility
are
2006-05-29 by Иван Кончаловский
Hello All.
First of all thanks to everybody for your answers.
Secondly i am not a newby in electronics and MCUs (as i
think). So why i was asking this question? Lately i worked
with PIC18 MCU, as you probably know it has port B with
internal pull-up resistors. I use to connect buttons and
LEDs to it without any resistors (of course). In Philips`
datasheets i found no port schematics and decided to ask in
this conference.
Best regards,
 Hummel
2006-05-29 by c.barbaro
I don't know the the PIC18 port hardware details but,
regarding your question 2, why configure the port pin as
output?
Usually the switch is connected between the pin and gnd,
the pin is an input and you read high when switch is off and
low when switch is on.
Regarding the LED, I can't easily imagine how it is connected:
is it lit by the CPU internal pullup resistor and turned
off driving the port pin low?
The processors in LPC family have some pins open collector
(see the I2C interface pins), but unfortunately no internal
pullup resistor.
Best regards
> Hello All.
> this conference.
> Best regards,
>  Hummel
